HUA GOLD Old BY HUA TEAM |
02-20-2014, 17:43 | #1 (permalink) |
Insane Poster Join Date: Aug 2005
Member: 167956 Status: Offline Thanks Meter: 2 | i9300 imei repair done with asansam box.tanx Model : GT-I9300 Android Version : 4.3 PDA Version : I9300XXUGMK6 CS Version : I9300VFGGMK4 Phone Version : I9300BUUGMK1 IMEI : NULL Checking Root ...OK Phone Root OK. Continue.. Reading Data From Phone ...OK [Err:2] Permission denied! Operation Completed Operation Time: 00:01:24 Anyone know how can i fix this ? Phone hardware is 100% working Last edited by Asansam Box; 02-21-2014 at 08:59. |
02-20-2014, 18:36 | #3 (permalink) |
Member: 167956 Status: Offline Thanks Meter: 2 | i reflashed now phone to 4.1.2 ----------------------------------------------------------------------------------------------- Turn-on the Phone Goto 'Settings > Application > Development' And Check 'Usb Debugging' Then Connect Usb Cable To Phone And Install Needed Driver. ----------------------------------------------------------------------------------------------- Prepairing ...OK Device Found! Reading Phone Informations ... Model : GT-I9300 Android Version : 4.1.2 PDA Version : I9300XXEMF6 CS Version : I9300OJVEMF1 Phone Version : I9300XXEMA5 IMEI : NULL Checking Root ...OK Phone Root OK. Continue.. Disabling Security ...Done! Rebooting... OK! Now Remove USB Cable then Insert Micro UART Cable to Phone to Continue.. Delay 40 Seconds... Searching for phone on COM1 ... Fail So when i insert RJ45 UART nothing happend , i tryed on both ports but same problem |
02-20-2014, 18:43 | #4 (permalink) |
Product Manager Join Date: Apr 2013 Location: IRAN Age: 38
Member: 1911891 Status: Offline Thanks Meter: 6,241 | select model set interface port in port setting enabel use uart in asansam setting press repair insert usb to phone insert s7070 rj45 red cable in step2 finished now |
02-20-2014, 18:48 | #6 (permalink) |
Member: 1911891 Status: Offline Thanks Meter: 6,241 | Buy this cable and try again GSMSP | Z3X BOX UART auto ignition Cable powered by GPGIndustries |
02-20-2014, 18:52 | #8 (permalink) |
Member: 1911891 Status: Offline Thanks Meter: 6,241 | Sorry we dont have other solution for you(we have 100XXX success report in all sites) http://forum.gsmhosting.com/vbb/f716...-here-1498612/ FINAL SOLUTION: CHECK CONNECTION ON PC OR CONTACT ON SONORK 100.1640605 |
02-20-2014, 18:53 | #9 (permalink) |
Member: 167956 Status: Offline Thanks Meter: 2 | Model : GT-I9300 Android Version : 4.1.2 PDA Version : I9300XXEMF6 CS Version : I9300OJVEMF1 Phone Version : I9300XXEMA5 IMEI : NULL Checking Root ...OK Phone Root OK. Continue.. Disabling Security ...Done! Rebooting... OK! Now Remove USB Cable then Insert Micro UART Cable to Phone to Continue.. Delay 40 Seconds... Searching for phone on COM2 ... Phone Found Reading Data from phone... Now im stuck on reading data .... Can be worst than that |
02-20-2014, 18:55 | #10 (permalink) | ||
Member: 1911891 Status: Offline Thanks Meter: 6,241 | attach cable picture here please? Quote:
after contact to team viewer: remove run as admin and check again Last edited by Asansam Box; 02-20-2014 at 20:16. | ||
02-21-2014, 08:13 | #11 (permalink) |
Member: 167956 Status: Offline Thanks Meter: 2 | Prepairing ...OK Device Found! Reading Phone Informations ... Model : GT-I9300 Android Version : 4.1.2 PDA Version : I9300XXEMF6 CS Version : I9300OJVEMF1 Phone Version : I9300XXEMA5 IMEI : NULL Checking Root ...OK Phone Root OK. Continue.. Disabling Security ...Done! Rebooting... OK! Now Remove USB Cable then Insert Micro UART Cable to Phone to Continue.. Delay 40 Seconds... Searching for phone on COM13 ... Phone Found Reading Data from phone... Model : GT-I9300 S/W Version : I9300XXEMF6 Unique ID : CVTF116A429C05F Memory ID : - IMEI : none MSL Addr : 0000000000 Verifying MSL ... OK Bypassing MSL ... OK Writing IMEI ... OK Reset Done! Operation Completed Operation Time: 00:01:18 Thanks Asansam !! After removing shield its works perfect Phone done ! Thanks |
