Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > HUA Team Products > HUA GOLD Old
HUA GOLD Old BY HUA TEAM
Old 01-01-2014, 11:07   #1 (permalink)
Asansam Box's Avatar
Member: 1911891
Thanks Meter: 6,241
How to fix Emergency Calls Only n7100/i9300 4.3 with asansam box+[success reports]
How to fix Emergency Calls Only n7100 4.3 with asansam box?
You can use this solution if you have a VALID IMEI number, but are still getting Emergency Calls Only.
Open asansam(dont forget full wipe before use)
select model same i9500
download this file and write on phone in download mode
reboot phone in custom recovery
copy file1 and file2 in sdcard and apply zip files in recovery mode
phone rebooted and working now
tanx to @johnyp
The Following 7 Users Say Thank You to Asansam Box For This Useful Post:
Old 01-01-2014, 15:03   #2 (permalink)
johnysofts's Avatar
Member: 319956
Thanks Meter: 124
select model
flash stock 4.3 version on phone(all version)
press on unbirck button in asansam
select Patch1 and press unbrick
select patch2 and press unbrick
tanx to @johnyp
sir unbrick button is hide how to unhide it
Old 01-01-2014, 15:11   #3 (permalink)
Member: 1911891
Thanks Meter: 6,241
The Following User Says Thank You to Asansam Box For This Useful Post:
Old 01-01-2014, 15:20   #4 (permalink)
johnysofts's Avatar
Member: 319956
Thanks Meter: 124
my model is n7100 can i use i9500
and on support only 1 patch file of n7100
Old 01-01-2014, 16:53   #5 (permalink)
Member: 1911891
Thanks Meter: 6,241
read here carefully and step to step and dotn forget you can write with odin and all xxxxxx box
Old 01-14-2014, 18:42   #6 (permalink)
Member: 1911891
Thanks Meter: 6,241
mk4 other link
Patched_N7100_MK4_KERNEL.zip_??????|??? ??-?????
Old 01-14-2014, 19:03   #7 (permalink)
..::MobiLinks::..'s Avatar
Member: 614141
Sonork: 100.1618541
Thanks Meter: 21
sir what is the procedure for i9300 4.3
Old 01-14-2014, 19:52   #8 (permalink)
Member: 1911891
Thanks Meter: 6,241
download this file and extract to c:/
i9300 4.3 network problem
write cwm recovery on phone in download mode
reboot phone to recovery
copy zip files to sdcard and apply in recovery mode 1-apply kernel 2-apply modem
reboot system now
The Following 3 Users Say Thank You to Asansam Box For This Useful Post:
Old 01-15-2014, 21:42   #9 (permalink)
Member: 614141
Sonork: 100.1618541
Thanks Meter: 21
reboot system now
thanks so much it works.......but i think it should b updated on asansam tool so that can b very easy......
Old 01-15-2014, 22:04   #10 (permalink)
Member: 1284574
i have one piece tomorrow i will test and answer , thanks
Old 01-16-2014, 11:03   #11 (permalink)
Member: 614141
Sonork: 100.1618541
Thanks Meter: 21
tanx to @johnyp
this method works 100%but phone not works properly it gets hang and restart automatically so kindly give any proper solution....
Old 01-16-2014, 11:27   #12 (permalink)
blaiseid's Avatar
Member: 37735
Sonork: 100.103255
Thanks Meter: 205
This work only if your IMEI is correct, 35xxxxxxxxxxxxx,not for 0049xxxxxxxxxxxxxx
Old 01-23-2014, 19:20   #13 (permalink)
Member: 2064138
I repaired "no network" problem with flashing patched kernel and modem, but now Wifi it's not working. In phone I have this stock ROM - N7100XXUEMK9_N7100OXXEMK4_N7100XXUEMJ9 (4.3 ETL). Any ideas what to do ?
Old 01-23-2014, 21:16   #14 (permalink)
Member: 1911891
Thanks Meter: 6,241
http://forum.gsmhosting.com/vbb/f716...m-box-1760233/
Old 01-23-2014, 22:32   #15 (permalink)
Member: 2064138
Thanks, but I tried this and it's not working. Wifi still not works.
Page generated in 0.22760 seconds with 8 queries
