Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > HUA Team Products > HUA GOLD Old
HUA GOLD Old BY HUA TEAM
Old 04-10-2013, 11:48   #1 (permalink)
Asansam Box's Avatar
Member: 1911891
Thanks Meter: 6,241
How To imei repair galaxy S III i9300(Manual)
How To imei repair galaxy S III i9300?
1-Select model
2-Select interface port in select port part
3-Goto general service
4-Insert imei in IMEI1
5-Press repair imei button
6-Remove usb and insert uart cable to phone(step2)
7-Repair successfully
Dont forget check setting before use imei repair button
The Following User Says Thank You to Asansam Box For This Useful Post:
Old 08-13-2013, 11:07   #2 (permalink)
Member: 565409
Thanks Meter: 21
sir how can use this dongal
asansam dongal ver 1.7.8 and 2.2.8 beta ver
i m canfuse witch ver use this dongal
[email protected] plz explane and gide me
Old 08-13-2013, 12:46   #3 (permalink)
Member: 1911891
Thanks Meter: 6,241
What is your problem?
all is same(dongle and box)
Old 08-13-2013, 14:12   #4 (permalink)
Member: 565409
Thanks Meter: 21
this prob
sir function hiden
Old 08-13-2013, 14:33   #5 (permalink)
Member: 1911891
Thanks Meter: 6,241
Sir function hidden = not supported this model(unlock/imei/service)
Old 08-14-2013, 07:32   #6 (permalink)
Member: 565409
Thanks Meter: 21
Sir function hidden all model
product suppoter sir i m purchage dongal in after 10 to 12 month but i m use only 2 and 3 set another model is not support and gone in model list
Old 08-14-2013, 07:55   #7 (permalink)
Member: 1911891
Thanks Meter: 6,241
please read here again???
Qualcomm:Flash/unlock/imei repair/full service
broadcom:flash/reset user code/full service
swift/sysol:flash/unlock/read unlock code/imei repair/full service
android:flash/unlock/imei/full service
Old 08-15-2013, 10:54   #8 (permalink)
Member: 565409
Thanks Meter: 21
sir i agere but function is hidden . flash . info phone ets
Old 08-23-2013, 17:09   #9 (permalink)
Member: 1750170
help me pls
Old 08-23-2013, 21:02   #10 (permalink)
Member: 1911891
Thanks Meter: 6,241
what is your phone problem?
i think phone dont have good sn or imei is damaged or msl is unknown?
Old 08-24-2013, 20:26   #11 (permalink)
Member: 1750170
Realize ubtool self through the repair efs and all well but when trying to write the imei stays there in the verifying step msl
and I write this imei imei is original equipment because for one my client handling damage efs and thus the way to state null / null repaired at 00499901064000001 efs stay
then proceeded to place the original cable is c3300k there asansam use version 2.2.9 beta box with root access equipment installed busybox verified airplane mode and try without also await your prompt response thank you very much
Old 08-24-2013, 21:50   #12 (permalink)
Member: 1911891
Thanks Meter: 6,241
No need busybox or everything = imei repair
ubtool is for repair unknown baseband only(your phone have baseband or modem when uart cable connection)
your phone dont have msl and cannot repair without msl address
solution and warning :
contact to me on sonork for check and dont forget read here carefully and send request again
http://forum.gsmhosting.com/vbb/f716...-only-1640214/
Old 10-06-2013, 13:06   #13 (permalink)
Member: 201113
Thanks Meter: 63
Please can you write (or send url) what kind of UART cable will I need to repair IMEI on i9300. Thanks.
Old 10-06-2013, 15:24   #14 (permalink)
Member: 1911891
Thanks Meter: 6,241
S7070 cable(red color)powered by gpg
http://www.gsmsp.com/products/Servic...209_16502.html
Old 04-03-2014, 09:18   #15 (permalink)
qpraba's Avatar
Member: 112404
Thanks Meter: 21
Prepairing ...OK
Device Found!
Reading Phone Informations ...
Model : GT-I9300
Android Version : 4.1.1
PDA Version : I9300UBDLJ1
CS Version : I9300ZTODLJ2
Phone Version : I9300UBDLI2
IMEI : NULL
Checking Root ...OK
Phone Root OK. Continue..
Disabling Security ...Done!
Rebooting... OK!
Now Remove USB Cable then Insert Micro UART Cable to Phone to Continue..
Delay 40 Seconds...
Searching for phone on COM22 ... Phone Found
Reading Data from phone...
Model : GT-I9300
S/W Version : I9300UBDLJ1
Unique ID : CVTF1943011B96F
Memory ID : -
IMEI : corrupted!!
MSL Addr : p›#A2‘T
Verifying MSL ...
why cannot repair imei with asansambox i tried more then 10 phones but all got this error but those all the phones i repaired with z3 box .no use for
asansam box
Page generated in 0.29186 seconds with 9 queries
