HUA GOLD Old BY HUA TEAM |
09-05-2013, 11:07 | #1 (permalink) |
Product Manager Join Date: Apr 2013 Location: IRAN Age: 38
Member: 1911891 Status: Offline Thanks Meter: 6,241 | How to repair imei GT-i9500 galaxy s4? 2-Select interface port in select port part 3-Goto general service 4-Insert imei in IMEI1 5-Press repair imei button 6-Remove usb and insert uart cable to phone(step2) 7-Repair successfully please tested this code after repair for fix network Last edited by Asansam Box; 09-05-2013 at 12:05. |
The Following 7 Users Say Thank You to Asansam Box For This Useful Post: |
09-05-2013, 14:08 | #2 (permalink) |
Junior Member Join Date: Jun 2009
Member: 1059051 Status: Offline Thanks Meter: 10 | imei repair ok but no network register, maybe his luck then me, how to solve repair network problem thx for advance... |
The Following 2 Users Say Thank You to gsmtech_tr For This Useful Post: |
09-05-2013, 14:50 | #3 (permalink) | |
Member: 1911891 Status: Offline Thanks Meter: 6,241 | Quote:
About Not register on network problem Before or after change imei --------------------------------------------------------- Contact to 100.1587178 if you have this problem and need Fix Need Asansam orginal box/Root/USB/S7070 uart red cable | |
The Following User Says Thank You to Asansam Box For This Useful Post: |
09-05-2013, 15:14 | #5 (permalink) |
No Life Poster Join Date: Feb 2011 Location: (BaNgLaDeSh).(U.A.E,AD)
Member: 1511441 Status: Offline Sonork: 100.1604057 Thanks Meter: 1,162 | http://forum.gsmhosting.com/vbb/9602714-post1.html Asansam Box can solve this problem - if yes guide here step by step for Asansam Box user |
The Following User Says Thank You to riajul1988 For This Useful Post: |
09-05-2013, 15:39 | #6 (permalink) | |
contact to me 100.1587178 | |
09-05-2013, 15:54 | #8 (permalink) | |
contact to me for fix(100.1587178) Last edited by Asansam Box; 09-05-2013 at 21:05. | |
09-05-2013, 19:56 | #9 (permalink) |
Insane Poster Join Date: Jul 2004 Location: turkey/istanbul Age: 51
Member: 72847 Status: Offline Sonork: 100.1614232 Thanks Meter: 16 | network problem he use in the video nother imei but have network this imeii not orginal i9500 or wht mean special imei Model : GT-I9500 Android Version : 4.2.2 PDA Version : I9500XXUAMDK CS Version : I9500OJVAMDK Phone Version : I9500XXUAMDK IMEI : NULL Disabling Security ...Done! Rebooting... OK! Now Remove USB Cable and Wait Phone Powering Up Completely (Media Scanners Passed) Then insert UART cable to Phone to Continue Delay 60 Seconds... Searching for phone on COM13 ... Phone Found Reading Data from phone... Model : GT-I9500 S/W Version : I9500XXUAMDK Unique ID : CV3006704930D30 Memory ID : - IMEI : none Verifying MSL ... OK Bypassing MSL ... OK Preparing to write Special IMEI. Generating IMEI... OK Writing IMEI ... OK Reset Done! Operation Completed Operation Time: 00:01:27 |
The Following User Says Thank You to arkun20 For This Useful Post: |
09-05-2013, 21:07 | #10 (permalink) | |||
solution: i can fix this problem for you contact to me on sonork | |||
09-05-2013, 23:26 | #11 (permalink) |
Insane Poster Join Date: Sep 2002 Age: 45
Member: 15141 Status: Offline Thanks Meter: 30 | pls solved fix network problem. I waittt. imei repair ok but no network. pls give fix network code... video yu ekleyen arkadaşım bizede yardımcı olabilirmisin bu konuda. şimdiden teşekkürler... Last edited by scorpions_72; 09-05-2013 at 23:32. |
09-06-2013, 01:19 | #12 (permalink) |
Freak Poster Join Date: Dec 2005
Member: 215288 Status: Offline Thanks Meter: 65 | Sure, Master. I added the video with friends, TA and can take the adv,, I think your ****ing with us. can take the adv can not solve, so how does the octopus + z3x + spt he'd be lying if I said I was not surprised. I tried doing the network device 10 does not work bro. Link them to my pc, I see they do it. regards to all of you. |
09-06-2013, 08:01 | #13 (permalink) | |||
this problem is for your country only solution for you: i can fix for you but one phone only(contact to 100.1587178) Quote:
open eyes and read carefully about 2.3.3 update only http://forum.gsmhosting.com/vbb/9707600-post1.html Quote:
