HUA GOLD Old BY HUA TEAM |
05-14-2013, 21:49 | #1 (permalink) |
No Life Poster Join Date: Dec 2006 Location: Saudi Arabia Age: 45
Member: 417778 Status: Offline Sonork: 100.1603326 Thanks Meter: 116 | I9300 Baseband / Imei Null Problem...[ANSWERED] it is same after repair with UB Tool if any solution is there plz Post Prepairing ...OK Device Found! Reading Phone Informations ... Model : GT-I9300 Android Version : 4.0.4 PDA Version : I9300XXALE9 CS Version : I9300OJVALE9 Phone Version : NULL IMEI : NULL Baseband Version : NULL GSM Baseband Version : NULL Checking Root ...OK Phone Root OK. Continue.. STEP1 ... OK STEP2 ... OK Phone Reset Done! -------------------------------------------- Operation Completed Operation Time: 00:00:07 Regards, Adnan Last edited by dr_moosavi; 08-10-2013 at 20:46. |
05-14-2013, 22:56 | #4 (permalink) |
No Life Poster Join Date: Sep 2004 Location: UK, London
Member: 82666 Status: Offline Sonork: 100.108210 Thanks Meter: 284 | Try to -Flash with Orignal Firmware -do factory Reset -then check iF imei & Baseband still Unknown THEN this HARDWARE PROBLEM BR. |
The Following User Says Thank You to ZoHaiB_(FoneGSM) For This Useful Post: |
05-15-2013, 07:37 | #5 (permalink) | |
Product Manager Join Date: Apr 2013 Location: IRAN Age: 38
Member: 1911891 Status: Offline Thanks Meter: 6,241 | Quote:
i9300 baseband problem is rf ic always but try write efs or check via other firmware too | |
The Following User Says Thank You to Asansam Box For This Useful Post: |
05-15-2013, 15:29 | #7 (permalink) |
Member: 1911891 Status: Offline Thanks Meter: 6,241 | ubtool method is final solution and you must check hardware and dont forget http://forum.gsmhosting.com/vbb/9265006-post27.html |
05-15-2013, 15:30 | #8 (permalink) | |
08-10-2013, 08:55 | #9 (permalink) |
No Life Poster Join Date: Sep 2011 Location: Dubz
Member: 1651733 Status: Offline Thanks Meter: 21 | hi im tryng to repair mine still null and i do all procedure Turn-on the Phone Goto 'Settings > Application > Development' And Check 'Usb Debugging' Then Connect Usb Cable To Phone And Install Needed Driver. Note: Phone Must be Rooted and be in AirPlane Mode For Restore PB Operation You Must Install Busybox in additional of all this ----------------------------------------------------------------------------------------------- Prepairing ...OK Device Found! Reading Phone Informations ... Model : GT-I9300 Android Version : 4.0.4 PDA Version : I9300XXBLFB CS Version : I9300OXABLFB Phone Version : NULL IMEI : NULL Baseband Version : NULL GSM Baseband Version : NULL Checking Root ...OK Phone Root OK. Continue.. Repairing EFS ... OK EFS Repair Done Phone Reset Done! Operation Completed Operation Time: 00:00:18 ------------------------------- |
02-19-2014, 12:36 | #11 (permalink) |
No Life Poster Join Date: Oct 2008 Location: Singapore Age: 37
Member: 888712 Status: Offline Thanks Meter: 308 | Prepairing ...OK Device Found! Reading Phone Informations ... Model : GT-I9300 Android Version : 4.1.2 PDA Version : I9300XXELKC CS Version : I9300OXXELK4 Phone Version : NULL IMEI : NULL Baseband Version : NULL GSM Baseband Version : NULL Checking Root ...OK Phone Root OK. Continue.. Prepairing... OK Restoring... OK PB Restore Done! Operation Completed Operation Time: 00:00:05 everything ok ok ok but not succees what problem asangsm box eating money only |
02-19-2014, 12:36 | #12 (permalink) |
02-19-2014, 13:57 | #14 (permalink) | |
