Register | FAQ | Donate | Forum Rules | Root any Device | ★iPhone Unlock★ | ★ Wholesale Unlock ★ | Direct Unlock Source | Search | Today's Posts | Mark Forums Read |
HUA GOLD Old BY HUA TEAM |
![]() | #1 (permalink) |
Product Manager ![]() ![]() ![]() ![]() ![]() Join Date: Apr 2013 Location: IRAN Age: 37
Member: 1911891 Status: Offline Thanks Meter: 6,241 | ★★★★IF u need any help and manuals for asansam box request here only★★★★ |
The Following User Says Thank You to Asansam Box For This Useful Post: |
![]() | #2 (permalink) |
Member: 1911891 Status: Offline Thanks Meter: 6,241 | How To imei repair galaxy S III i9300? 1-Select model 2-Select interface port in select port part 3-Goto general service 4-Insert imei in IMEI1 5-Press repair imei button 6-Remove usb and insert uart cable to phone(step2) 7-Repair successfully Dont forget check setting before use imei repair button |
![]() | #3 (permalink) |
Freak Poster ![]() ![]() ![]() ![]() Join Date: Aug 2009 Location: Chile
Member: 1101802 Status: Offline Sonork: 1615049 Thanks Meter: 50 | Hi, Please post How To Unlock Samsung T999 T-Mobile Thanks. Br ..:: MASRSYSTEM ::.. |
The Following User Says Thank You to .:MASRSYSTEM:. For This Useful Post: |
![]() | #4 (permalink) | |
Member: 1911891 Status: Offline Thanks Meter: 6,241 | Quote:
-select model -Type *#7284# and choose Modem for both options. -Type *#9090# and choose USB Diag. -Reboot phone. -Connect USB cable, install drivers. -Select diagnostic port in port settings. -Press "Unlock" button in unlock tab | |
![]() | #5 (permalink) |
Junior Member ![]() Join Date: Apr 2012 Location: Cabimas/Venezuela Age: 39
Member: 1750170 Status: Offline Thanks Meter: 0 | ![]() hello masrsytem master like him I have problems trying to unlock T999 here I show you some pictures and realize what basis this answer [IMG=http://img18.imageshack.us/img18/9053/img2013041100102.jpg][/IMG] There you can see the menu in * # 7284 # the program as you say but the menu * # 9090 # does not appear like the rest try the same procedure but fails [IMG=http://img442.imageshack.us/img442/4039/marsej.jpg][/IMG] think it takes to access another menu -Type *#9090# and choose USB Diag. Greetings and I hope to solve that took 2 days working hard and trying to Give you the unlock this computer |
![]() | #6 (permalink) |
Member: 1911891 Status: Offline Thanks Meter: 6,241 | please check via root again GS3_debugfs-root_r2.7z |
![]() | #7 (permalink) |
Member: 1750170 Status: Offline Thanks Meter: 0 | ![]() friend here as you can tell this perfectly done the root to T999 ![]() In this second picture you can notice that the error persists masrsytem miguel ah assisted me to see if we can solve this problem but we were unable to find the error on our hands porpias hopefully can lend aid and obtain the solution to share with our colleagues and customers in this box asansam best regards |
![]() | #14 (permalink) | |
please attached full report here | |
![]() | #15 (permalink) |
Freak Poster ![]() ![]() ![]() ![]() Join Date: Mar 2005 Age: 47
Member: 129953 Status: Offline Thanks Meter: 2 | why the box does not read IMEI and Baseband Version, as the information about the state's info exists both phones imei baseband version. may be a problem with the box? or what else? ----------------------------------------------------------------------------------------------- Turn-on the Phone Goto 'Settings > Application > Development' And Check 'Usb Debugging' Then Connect Usb Cable To Phone And Install Needed Driver. ----------------------------------------------------------------------------------------------- Prepairing ...OK Device Found! Model : GT-I9300 Manufacturer : samsung Brand : samsung CPU info1: : armeabi-v7a CPU info2: : armeabi Serial No. : 4df1d2bb3baf6f29 Baseband Version : NULL GSM Baseband Version : I9300BUELL1 Bootloader Version : I9300XXELLA Build Version : 4.1.2 Country : IT Language : en CID : NULL Build ID : JZO54K Time-Zone : Europe/Rome IMEI : NULL IMSI : NULL Root User : se.infra Sales Code : OMN Country Code : OMN Built Date : Sat Dec 22 17:07:58 KST 2012 ----------------------------------------------------------------------------------------------- Operation Completed Operation Time: 00:00:13 ----------------------------------------------------------------------------------------------- |
