Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > zZKey
Old 06-27-2014, 01:02   #16 (permalink)
Member: 1607814
Sonork: 100.1658107
Thanks Meter: 10
Conecte el Modem y me salio esto, Pero cuando le doy a Unlock It No lo Libera, Pruebo metiendo las SIM y nada No libera, ni me da para introducir el NCK.
Que puede ser?
Log:
Modem: HUAWEI E5836
Imei: 356210031231546
Waiting for init...
Serial: HHA4CC1112205576
Firmware: ^RSSI:0
^RSSI:23
^RSSI:23
^SRVST:2
^MODE:3,3
^RSSI:23
696.11.73.01.111
Date: Jul 21 2010, 22:47:38
Voice Feature: Disabled!
Calculating Unlock Codes...
NCK (old) : 42594469
NCK (new) : 47009399
Flash Code: 44852346
Reading Backup...
Reading Simlock Status...
Simlock Status: UNLOCKED!
Counter Status: ^RSSI:15
^CARDLOCK: 2 times remainder.
Disconnected Done..
Detecting Modem...
err:[]: Failed Initializing APP Port.
err:[]:Unable to open com port (win error code: 170)
Detecting Modem...
err:[]: Modem not Found.
Detecting Modem...
err:[]: Failed Initializing DiagPort.
Detecting Modem...
Old 06-27-2014, 01:27   #17 (permalink)
elcapitel's Avatar
Member: 166270
Sonork: 100.1579747
Thanks Meter: 12,673
Esta bien extranno su problema. Has una cosa, fuerza los puertos por debajo del 16 y reintenta, pega aca el resultado.
Saludos cordiales
Equipo zZKey
Que puede ser?
Log:
Modem: HUAWEI E5836
Waiting for init...
Firmware: ^RSSI:0
^RSSI:23
^RSSI:23
^SRVST:2
^MODE:3,3
^RSSI:23
696.11.73.01.111
Reading Backup...
Disconnected Done..
Detecting Modem...
Detecting Modem...
Detecting Modem...
Detecting Modem...
Old 06-27-2014, 04:23   #18 (permalink)
Member: 1607814
Sonork: 100.1658107
Thanks Meter: 10
Me da este error. He bajado y subido las velocidades en los puertos y nada.
Detecting Modem...
PIN Status Not Ready.
err:[]: Modem not Detected
Detecting Modem...
Old 06-27-2014, 05:26   #19 (permalink)
elcapitel's Avatar
Member: 166270
Sonork: 100.1579747
Pero cambiale los puertos desde "Administrador de Dispositivos".. las velocidades no toques nada de eso, quita y pon el cable y/o reincia la PC, y reintenta.
Deja el Qcom marcado en seleccion automatica, es decir no escojas tu los puertos.
Saludos cordiales
Equipo zZKey
Detecting Modem...
Detecting Modem...
Old 06-28-2014, 18:00   #20 (permalink)
Member: 1607814
Sonork: 100.1658107
Thanks Meter: 10
Conecte en Mi otra laptop con Win7 aqui lo detecta. Pero al Darle Unlock It o Restar Counters, Me da Error: "Failed Modem Detection. Disconnect/Connect Modem and try again." Aun no puedo Postear Una Imagen para que lo Vea.
zzQCOM v0.502 Flying in the Galaxy.
zzDongle SN: 76XXXXXX
Getting internal zZ dongle internal firmware...
Main zzInternal Firmw: v0.27
Checking authorize update in dongle...
Dongle Counter Status: 63%
zZ WORLD PREMIER CREDITS :16
Detecting Modem...
Detecting Modem...
Modem: HUAWEI E5836
Waiting for init...
Serial:
Firmware: 696.11.73.01.111
Reading Backup...
Simlock Status: LOCKED
Counter Status: 0 times remainder.
Restart Counters Started...
Restarting...
err:[]: Restart Failed!
Direct Unlock Started...
Unlocking...
err:[]: Unlock Failed!
Unlocking...
Old 07-01-2014, 00:27   #21 (permalink)
Member: 740033
Thanks Meter: 6
ST26i Los datos de bloqueo están dañados
ST26i Los datos de bloqueo están dañados. desea repararlos ???
se hizo rot con vroo.
error backup y error en operación
alguna solución
Old 07-02-2014, 03:39   #22 (permalink)
Shensohau's Avatar
Member: 1377783
Sonork: 100.1611724
Thanks Meter: 3,336
Hola nuestros servers estan bajo migracion a nuevos equipos estamos mejorandolos para ofrecer nuevos servicios no te preocupes amigo, pronto estaran online nuevamente
Old 07-06-2014, 12:59   #23 (permalink)
Member: 1023134
Sonork: 100.1656920
Thanks Meter: 19
cuando de se va a poder repair imei de huawei p6-u06
The Following User Says Thank You to luisgonzalez197 For This Useful Post:
Old 07-06-2014, 14:34   #24 (permalink)
Shensohau's Avatar
Member: 1377783
Sonork: 100.1611724
Thanks Meter: 3,336
hola amigo estamos trabajando con muchos modelos nuevos, descuida pronto habra muchas sorpresas.... saludos!!!
Old 07-12-2014, 18:13   #25 (permalink)
Member: 1343269
Thanks Meter: 21
Unlock Huawei u9120 (help)
Porfavor ayudenme a Liberar este phone de linea Movilnet Venezuela,cuando lo conecto aparentemente los driver se instalan sin problemas pero el programa no me lo reconoce, hay que colocarlo en algun modo para que lo reconozca??
gracias por adelantando
Old 07-13-2014, 14:02   #26 (permalink)
Shensohau's Avatar
Member: 1377783
Sonork: 100.1611724
Thanks Meter: 3,336
hola amigo pepoxxx si te fijas pulsa el boton help y alli veras las instrucciones a seguir para este equipo... saludos
The Following User Says Thank You to Shensohau For This Useful Post:
Old 07-14-2014, 00:50   #27 (permalink)
karunkrsna's Avatar
Member: 1286646
Thanks Meter: 12
Porfavor requiero el Firmware del tablet s7 106
Nesecito este firmware para reparar imei dell s7 106
Old 07-14-2014, 18:26   #28 (permalink)
Member: 2006163
Hola necesito ayuda , instale mi zz_key en otra pc y se bloqueo . Ahora no funciona ni en la pc que estaba instalada originalmente. Espero me puedan ayudarme.
Dongle SN:XXXXXXX .
Gracias
Old 07-15-2014, 14:22   #29 (permalink)
Shensohau's Avatar
Member: 1377783
Sonork: 100.1611724
Thanks Meter: 3,336
Hola gear amigo por favor no vuelvas a postear tu S/N aca o seras bloqueado por un buen tiempo, esta PROHIBIDO postear las S/N, envia el correo a la direccion de mail que aparece en el log y en breve podras desbloquearla, hay que revisar por que motivo se bloqueo tu dongle, saludos!!!
Dongle SN:XXXXXXX .
Gracias
Old 07-15-2014, 14:56   #30 (permalink)
Shensohau's Avatar
Member: 1377783
Sonork: 100.1611724
Thanks Meter: 3,336
Enviame el S/N de tu dongle y la direccion de email con que la registraste via PM para enviarte el firmware amigo!!!
Saludos Cordiales
Equipo zZKey
Page generated in 0.25026 seconds with 9 queries
