10-28-2021, 00:27 | #19 (permalink) |
Freak Poster Join Date: Jul 2006 Location: W-no
Member: 310418 Status: Offline Thanks Meter: 13 | when im trying fo flash firmware (dont realy know if the firmware is good for the set) i get: Operation : Format FS Checking for existing devices...Found Port : Qualcomm HS-USB QDLoader 9008 (COM4) Driver Info : Qualcomm Incorporated, qcusbser.sys, 2.1.2.7 Opening Port...OK Init Handshake Sequence...OK Hardware ID : E1C00800 [8976] 69001500 OPK_DATA : F12E055978792825880C5C3730B1E9E35187524B1A1FC782B5 3ECAF30816C871 Initializing Protocol...OK Sending Loader [prog_emmc_firehose.mbn]...Done Executing Loader...OK Detecting Chip Type...OK Hardware : MSM8996, EMMC, ERASED GPT WARNING! High Speed Driver is not installed. Please install driver from QcFire\Drivers folder using Device Manager. Payload Info : In: 65536 [4096], Out: 131072, Sector Size: 512 Reading Partition Table...OK SYSTEM partition is missing! Partition data missing! Operation Failed. QcFire Ver. 7.3 |
10-28-2021, 02:06 | #21 (permalink) |
Member: 310418 Status: Offline Thanks Meter: 13 | other firmware : Operation : Flash Checking for existing devices...Not Found Turn Off phone, hold Vol UP + Vol DOWN and insert USB cable. Some phones may need Special Boot Cable or TestPoint for EDL mode. Found Port : Qualcomm HS-USB QDLoader 9008 (COM4) Driver Info : Qualcomm Incorporated, qcusbser.sys, 2.1.2.7 Connecting to phone...OK Waiting for response...OK Init Handshake Sequence...OK Hardware ID : E1C00800 [8976] 69001500 OPK_DATA : F12E055978792825880C5C3730B1E9E35187524B1A1FC782B5 3ECAF30816C871 Initializing Protocol...OK Sending Loader [prog_emmc_firehose.mbn]...Done Executing Loader...OK Detecting Chip Type...OK Hardware : MSM8996, EMMC, ERASED GPT WARNING! High Speed Driver is not installed. Please install driver from QcFire\Drivers folder using Device Manager. Payload Info : In: 65536 [4096], Out: 131072, Sector Size: 512 Writing [xbl.elf] -> [xbl] ...Done Writing [tz.mbn] -> [tz] ...Failed Operation Finished. QcFire Ver. 7.3 |
11-05-2021, 10:57 | #23 (permalink) |
Product Supporter Join Date: Feb 2005 Location: GSMserver Team
Member: 121052 Status: Offline Sonork: 100.107126 Thanks Meter: 80,766 | @ dangduy123, Please provide us with more details on an issue you have. What phone model exactly you have? What an issue it originally had? What firmware version phone originally had? What Firmware version did you use for the flashing purposes? Best Regards GSMServer team |
