Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > GSMServer Products > SigmaKey
Old 07-27-2020, 14:33   #16 (permalink)
belaidabed's Avatar
Member: 2594157
Sonork: 100.1679874
Thanks Meter: 121
i can rebrand it full
Old 12-09-2020, 10:52   #17 (permalink)
Member: 1822937
Sonork: salye
8x max
636
how to revive this?
Old 10-27-2021, 20:52   #18 (permalink)
Member: 310418
Thanks Meter: 13
i need help phone is dead, only qualcomm 9008 please help ...
Old 10-28-2021, 00:27   #19 (permalink)
Member: 310418
Thanks Meter: 13
when im trying fo flash firmware (dont realy know if the firmware is good for the set) i get:
Operation : Format FS
Checking for existing devices...Found
Port : Qualcomm HS-USB QDLoader 9008 (COM4)
Driver Info : Qualcomm Incorporated, qcusbser.sys, 2.1.2.7
Opening Port...OK
Init Handshake Sequence...OK
Hardware ID : E1C00800 [8976] 69001500
OPK_DATA : F12E055978792825880C5C3730B1E9E35187524B1A1FC782B5 3ECAF30816C871
Initializing Protocol...OK
Sending Loader [prog_emmc_firehose.mbn]...Done
Executing Loader...OK
Detecting Chip Type...OK
Hardware : MSM8996, EMMC, ERASED GPT
WARNING! High Speed Driver is not installed.
Please install driver from QcFire\Drivers folder using Device Manager.
Payload Info : In: 65536 [4096], Out: 131072, Sector Size: 512
Reading Partition Table...OK
SYSTEM partition is missing!
Partition data missing!
Operation Failed.
QcFire Ver. 7.3
Old 10-28-2021, 00:28   #20 (permalink)
Member: 310418
Thanks Meter: 13
re
im working on one firmware and one loader, so im not suer the emmc is bad or something else?
Old 10-28-2021, 02:06   #21 (permalink)
Member: 310418
Thanks Meter: 13
other firmware :
Operation : Flash
Checking for existing devices...Not Found
Turn Off phone, hold Vol UP + Vol DOWN and insert USB cable.
Some phones may need Special Boot Cable or TestPoint for EDL mode.
Found Port : Qualcomm HS-USB QDLoader 9008 (COM4)
Connecting to phone...OK
Waiting for response...OK
Writing [xbl.elf] -> [xbl] ...Done
Writing [tz.mbn] -> [tz] ...Failed
Operation Finished.
QcFire Ver. 7.3
Old 11-05-2021, 03:20   #22 (permalink)
Member: 1015360
flash board firmware, now imei null, pink screen
Old 11-05-2021, 10:57   #23 (permalink)
GSM_Support's Avatar
Member: 121052
Sonork: 100.107126
Thanks Meter: 80,766
@ dangduy123,
Please provide us with more details on an issue you have.
What phone model exactly you have?
What an issue it originally had?
What firmware version phone originally had?
What Firmware version did you use for the flashing purposes?
Best Regards
GSMServer team
Page generated in 0.17664 seconds with 8 queries
