11-07-2013, 22:16 | #3 (permalink) | |
No Life Poster Join Date: Nov 2011 Location: mexico
Member: 1681847 Status: Offline Thanks Meter: 103 | Did not work with IMEI calculation. Telcel Mexico doesnt work. Have to do direct unlock Quote:
02-11-2014, 01:35 | #4 (permalink) |
Junior Member Join Date: Oct 2012 Age: 41
Member: 1833175 Status: Offline Thanks Meter: 1 | goodnight sorry to bother as the direct release of this team lograstes ... trajieron me today one of the company Telcel Mexico but gave manually generate error code if you could guide of how you did your I thanks for your help and compression. |
02-11-2014, 08:05 | #5 (permalink) |
Product Supporter Join Date: Feb 2005 Location: GSMserver Team
Member: 121052 Status: Offline Sonork: 100.107126 Thanks Meter: 80,766 | @ TheSirJn, Please explain in more details what an issue you're dealing with. If you have SigmaKey, just calculate unlock codes with it and unlock your phone. Best Regards GSMServer team |
02-11-2014, 21:05 | #6 (permalink) |
Member: 1833175 Status: Offline Thanks Meter: 1 | Ok .. I will calculate the income section of the model selected Alcatel-OT800 Provider 8000A-2ETGMX1 IMEI: 013488000429201 already pressed calculate these codes are generated and inserted into the cell to the code turns out to be wrong. insert the code leaving 6 attempts in the cell. sorry to bother fails to upload the screenshot image here. |
02-12-2014, 08:37 | #7 (permalink) | |
No Life Poster Join Date: Mar 2006 Location: Central Europe Age: 39
Member: 239548 Status: Offline Thanks Meter: 2,781 | Quote:
02-12-2014, 08:38 | #8 (permalink) |
Member: 121052 Status: Offline Sonork: 100.107126 Thanks Meter: 80,766 | @ TheSirJn, just run Direct Unlock operation in order to unlock your phone. In case you want to unlock phone with the codes: double check phone's Provider ID and select proper PID from the list is the Sigma Software. Also, you can try to Master Reset phone before entering Unlock codes. Best Regards GSMServer team |
02-12-2014, 17:40 | #9 (permalink) |
Member: 1833175 Status: Offline Thanks Meter: 1 | Ok ... I'll have to change the ROM other than the one here in Mexico since the company telcel blocks or prevents us from such access, the function also will do direct unlock. and taking the log is attached here to see how it was me. Greetings and thanks for your support. |
02-13-2014, 08:45 | #10 (permalink) |
Member: 121052 Status: Offline Sonork: 100.107126 Thanks Meter: 80,766 | @ TheSirJn, There is no need to change ROM. Just run Direct Unlock operation according to this manual and unlock your phone. Best Regards GSMServer team |
02-13-2014, 09:45 | #11 (permalink) |
Member: 239548 Status: Offline Thanks Meter: 2,781 | TheSirJn, I've seen on Spanish forums that they have positive experience of unlocking of Alcatel OT-8000 (Telcel). So don't hesitate to perform direct unlock |
06-11-2014, 14:48 | #12 (permalink) |
No Life Poster Join Date: Nov 2004 Location: Dominican Republic Age: 49
Member: 92317 Status: Offline Sonork: 100.1591991 Thanks Meter: 223 | ot-8000a not unlocking SigmaKey v.2.02.01 3088xxxx Sigma dongle 2.02, Initializing...OK Pack 1: Not activated --- 2014-06-11 09:44:00 --- SigmaKey 2.02.01 Qcom: Direct unlock * daemon not running. starting it now * * daemon started successfully * ^ ROMaster Composite ADB Interface Version: Linux version 3.4.0-gb6e9cf0-00003-g8bd95a3 (android-bld@5001136-1) (gcc version 4.6.x-google 20120106 (prerelease) (GCC) ) #1 SMP PREEMPT Fri Aug 9 13:46:24 CST 2013 Phone model: TCT ALCATEL ONE TOUCH 8000A Firmware: JZO54K Date: Tue Sep 24 09:40:46 CST 2013 Reading security block...Not found any help pleases br cdmagsm03 |
