Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > GSMServer Products > SigmaKey
Old 08-14-2013, 03:22   #1 (permalink)
Member: 176714
Thanks Meter: 33
Alcatel OT-8000A unlocked success....
just select unit, provider and imput imei....
the log....
thanks sigma team...
The Following User Says Thank You to bobot For This Useful Post:
Old 11-07-2013, 20:54   #2 (permalink)
Member: 1681847
Thanks Meter: 103
Did not work for me. I put IMEI and provider correct but did not work
Old 11-07-2013, 22:16   #3 (permalink)
Member: 1681847
Thanks Meter: 103
Did not work with IMEI calculation. Telcel Mexico doesnt work. Have to do direct unlock
--- 2013-11-07 13:54:15 ---
SigmaKey 1.30.07 MTK: Get unlock codes
Puerto de comunicaciones (COM1), Provider: Microsoft, Driver ver.: 6.1.7600.16385, Date: 20/06/2006, ACPI\PNP0501
Baud rate: autodetect
Cancelled
--- 2013-11-07 13:54:24 ---
SigmaKey 1.30.07 Qcom: Get unlock codes
Connecting.......Cancelled
--- 2013-11-07 13:58:43 ---
Missing response from phone
--- 2013-11-07 14:07:07 ---
ALCATEL HS-USB Android DIAG 9018 (COM37), Provider: ALCATEL Incorporated, Driver ver.: 2.1.0.5, Date: 05/12/2012, USB\VID_1BBB&PID_9018&REV_0233&MI_00
Phone model: Alcatel
Firmware: 8X25-SSNSKOLYM-2035
Date: Jul 16 2013 13:51:56, Apr 12 2013 01:00:00, SSNSKOLY
IMEI: 013488000286692
Bluetooth address: 000000000000
Reading unlock codes...Done
--- 2013-11-07 14:07:16 ---
SigmaKey 1.30.07 Qcom: Direct unlock
Security area saved to "C:\Users\revolution Cel\Documents\SigmaKey\security backup\013488000286692_.skb"
Unlocking phone...Done
Restarting phone....Done
Old 02-11-2014, 01:35   #4 (permalink)
Member: 1833175
Question
goodnight
sorry to bother as the direct release of this team lograstes ... trajieron me today one of the company Telcel Mexico but gave manually generate error code if you could guide of how you did your I thanks for your help and compression.
Old 02-11-2014, 08:05   #5 (permalink)
GSM_Support's Avatar
Member: 121052
Sonork: 100.107126
Thanks Meter: 80,766
@ TheSirJn,
Please explain in more details what an issue you're dealing with.
If you have SigmaKey, just calculate unlock codes with it and unlock your phone.
Best Regards
GSMServer team
Old 02-11-2014, 21:05   #6 (permalink)
Member: 1833175
Exclamation
Ok ..
I will calculate the income section of the model selected Alcatel-OT800 Provider 8000A-2ETGMX1 IMEI: 013488000429201
already pressed calculate these codes are generated and inserted into the cell to the code turns out to be wrong.
insert the code leaving 6 attempts in the cell.
sorry to bother fails to upload the screenshot image here.
Old 02-12-2014, 08:37   #7 (permalink)
mcandre's Avatar
Member: 239548
Thanks Meter: 2,781
Originally Posted by TheSirJn View Post
Ok ..
why won't you use direct unlock?
Old 02-12-2014, 08:38   #8 (permalink)
Member: 121052
Sonork: 100.107126
@ TheSirJn,
just run Direct Unlock operation in order to unlock your phone.
In case you want to unlock phone with the codes: double check phone's Provider ID and select proper PID from the list is the Sigma Software.
Also, you can try to Master Reset phone before entering Unlock codes.
Best Regards
GSMServer team
Old 02-12-2014, 17:40   #9 (permalink)
Member: 1833175
Ok ... I'll have to change the ROM other than the one here in Mexico since the company telcel blocks or prevents us from such access, the function also will do direct unlock.
and taking the log is attached here to see how it was me.
Greetings and thanks for your support.
Old 02-13-2014, 08:45   #10 (permalink)
Member: 121052
Sonork: 100.107126
@ TheSirJn,
There is no need to change ROM.
Just run Direct Unlock operation according to this manual and unlock your phone.
Best Regards
GSMServer team
Old 02-13-2014, 09:45   #11 (permalink)
mcandre's Avatar
Member: 239548
Thanks Meter: 2,781
TheSirJn, I've seen on Spanish forums that they have positive experience of unlocking of Alcatel OT-8000 (Telcel). So don't hesitate to perform direct unlock
Old 06-11-2014, 14:48   #12 (permalink)
Member: 92317
Sonork: 100.1591991
Thanks Meter: 223
ot-8000a not unlocking
SigmaKey v.2.02.01
3088xxxx Sigma dongle 2.02, Initializing...OK
Pack 1: Not activated
--- 2014-06-11 09:44:00 ---
SigmaKey 2.02.01 Qcom: Direct unlock
* daemon not running. starting it now *
* daemon started successfully *
^ ROMaster Composite ADB Interface
Version: Linux version 3.4.0-gb6e9cf0-00003-g8bd95a3 (android-bld@5001136-1) (gcc version 4.6.x-google 20120106 (prerelease) (GCC) ) #1 SMP PREEMPT Fri Aug 9 13:46:24 CST 2013
Phone model: TCT ALCATEL ONE TOUCH 8000A
Firmware: JZO54K
Date: Tue Sep 24 09:40:46 CST 2013
Reading security block...Not found
any help pleases
br
cdmagsm03
Old 06-11-2014, 14:51   #13 (permalink)
mcandre's Avatar
Member: 239548
Thanks Meter: 2,781
You should select diagnostic interface, not adb interface.
Old 06-11-2014, 15:07   #14 (permalink)
mcandre's Avatar
Member: 239548
Thanks Meter: 2,781
So what is the result? Did you manage to unlock this phone?
Old 06-11-2014, 15:43   #15 (permalink)
Member: 92317
Sonork: 100.1591991
Thanks Meter: 223
not yet bcuse i can not enter to Diagnostic mode activation: dial *#2618#
i have the ot-8000a and the 5020n here
any solution
cdmagsm03
Page generated in 0.23403 seconds with 8 queries
