03-13-2021, 06:18 | #1 (permalink) |
Junior Member Join Date: Nov 2020 Location: America
Member: 2972562 Status: Offline Thanks Meter: 0 | Can't remove FRP from Alcatel OT-4060a SigmaKey 2.40.03 Qcom: Remove FRP / Huawei ID Phone model: OT-4060A Connecting...Phone not found Phone is off and plugged in to PC USB port. What am I doing wrong? |
03-13-2021, 09:41 | #2 (permalink) |
No Life Poster Join Date: Mar 2005 Location: Pakistan
Member: 123458 Status: Offline Sonork: 100.1594535 Thanks Meter: 3,421 | Procedure: Select "Qualcomm" platform from the tab menu in the upper left side of the software Go to "Service" tab Select your model in the right “Phone model” drop-down list Turn the phone OFF Connect your phone to PC with USB cable Wait up to 30 seconds while the diagnostic port appears (your phone will be in charging mode). If diagnostic port is not detected, power the phone ON and activate it by dialing ##2324#. Then select diag port in the ports tab. Install required drivers Select diagnostic port Press “Remove FRP” button The message "Removing FRP lock...Done" indicates that procedure has been completed successfully Warning: This feature will erase all phone’s data and accounts If after FRP removal user data was not wiped automatically, perform this procedure manually in the recovery mode. |
