02-16-2023, 12:32 | #1 (permalink) |
Freak Poster Join Date: Jul 2019 Location: Pakistan
Member: 2919541 Status: Offline Sonork: Tasawariqbal110 Thanks Meter: 50 | Els-nx9 huawei id 2. Phone battery fully charged + connected 3. My modified cabel 100% ok 👉 also cabel change same issue. pc change same issue 4. Board is ok everything fine 5. ++ if u argue security Not supported then ur argue is ****T , because 👉 these same error having many other huawri old securities 👉Here is info SigmaKey 2.46.01 HiSi: Get device info Bootloader unlocked: NO FB unlocked: NO Battery voltage: 4.00 V Phone model: ELS-NX9 Build number: ELS-N29 12.0.0.218(C185E3R6P3) Vendor/Country: hw/meafnaf System version: Skipped Android version: 10 Base version: ELS-LGRP4-OVS 102.0.0.266 Custom version: ELS-N29-CUST 102.0.0.3(C185) Preload version: ELS-N29-PRELOAD 102.0.0.3(C185R6) Huawei-Over-the-Air info: C_version: C185 D_version: D000 PLMN: 41004 BoardID: 9592 DeviceName: ELS-N29 Done 👉Here is errors --------- 2023-02-16 15:53:39 --------- SigmaKey 2.46.01 HiSi: Remove Huawei ID HUAWEI USB COM 1.0 (COM7), Provider: HUAWEI Incorporated, Driver ver.: 2.0.6.725, Date: 11/6/2015, USB\VID_12D1&PID_3609&REV_0100 The battery must be connected to the phone's board and fully charged. [YES] HiSilicon: P40/P40Pro (boot 1) Sending boot...Failed --------- 2023-02-16 15:55:36 --------- SigmaKey 2.46.01 HiSi: Load FastBoot HUAWEI USB COM 1.0 (COM7), Provider: HUAWEI Incorporated, Driver ver.: 2.0.6.725, Date: 11/6/2015, USB\VID_12D1&PID_3609&REV_0100 HiSilicon: P40/P40Pro (boot 1) Sending boot...Error writing to serial port --------- 2023-02-16 15:55:59 --------- SigmaKey 2.46.01 HiSi: Remove Huawei ID HUAWEI USB COM 1.0 (COM7), Provider: HUAWEI Incorporated, Driver ver.: 2.0.6.725, Date: 11/6/2015, USB\VID_12D1&PID_3609&REV_0100 The battery must be connected to the phone's board and fully charged. [YES] HiSilicon: P40/P40Pro (boot 3) Sending boot...Failed |
02-17-2023, 08:05 | #4 (permalink) |
Junior Member Join Date: Jul 2017 Location: Jhelum
Member: 2742439 Status: Offline Thanks Meter: 0 | SigmaKey v.2.46.00 build 01 729698669 Sigma dongle 2.46, Initializing...OK Huawei Edition PowerPack: Activated --------- 2023-02-15 16:17:06 --------- SigmaKey 2.46.00b1 HiSi: Read secure data (certificate)... HUAWEI USB COM 1.0 (COM75), Provider: Huawei Incorporated, Driver ver.: 2.0.6.725, Date: 28/11/2016, USB\VID_12D1&PID_3609&REV_0100 HiSilicon: Kirin 990 5G Sending boot...Error writing to serial port --------- 2023-02-15 16:17:55 --------- SigmaKey 2.46.00b1 HiSi: Load FastBoot HUAWEI USB COM 1.0 (COM75), Provider: Huawei Incorporated, Driver ver.: 2.0.6.725, Date: 28/11/2016, USB\VID_12D1&PID_3609&REV_0100 HiSilicon: Kirin 990 5G Sending boot...Error writing to serial port --------- 2023-02-15 16:19:28 --------- SigmaKey 2.46.00b1 HiSi: Load FastBoot HUAWEI USB COM 1.0 (COM75), Provider: Huawei Incorporated, Driver ver.: 2.0.6.725, Date: 28/11/2016, USB\VID_12D1&PID_3609&REV_0100 HiSilicon: Kirin 990 5G Sending boot...Error writing to serial port |
02-17-2023, 16:33 | #5 (permalink) |
Member: 2919541 Status: Offline Sonork: Tasawariqbal110 Thanks Meter: 50 | [QUOTE=Haseeb08201;14745122]SigmaKey v.2.46.00 build 01 729698669 Sigma dongle 2.46, Initializing...OK Huawei Edition PowerPack: Activated --------- 2023-02-15 16:17:06 --------- SigmaKey 2.46.00b1 HiSi: Read secure data (certificate)... HUAWEI USB COM 1.0 (COM75), Provider: Huawei Incorporated, Driver ver.: 2.0.6.725, Date: 28/11/2016, USB\VID_12D1&PID_3609&REV_0100 HiSilicon: Kirin 990 5G Sending boot...Error writing to serial port --------- 2023-02-15 16:17:55 --------- SigmaKey 2.46.00b1 HiSi: Load FastBoot HUAWEI USB COM 1.0 (COM75), Provider: Huawei Incorporated, Driver ver.: 2.0.6.725, Date: 28/11/2016, USB\VID_12D1&PID_3609&REV_0100 HiSilicon: Kirin 990 5G Sending boot...Error writing to serial port --------- 2023-02-15 16:19:28 --------- SigmaKey 2.46.00b1 HiSi: Load FastBoot HUAWEI USB COM 1.0 (COM75), Provider: Huawei Incorporated, Driver ver.: 2.0.6.725, Date: 28/11/2016, USB\VID_12D1&PID_3609&REV_0100 HiSilicon: Kirin 990 5G Sending boot...Error writing to serial port[/Q Brother waste team. I have also mui 11 same issue old sec |
02-22-2023, 00:18 | #7 (permalink) |
Freak Poster Join Date: Jul 2004 Location: casablanca Age: 57
Member: 75223 Status: Offline Thanks Meter: 62 | MY experience with such errors and p40 pro id harmony done first of all we must thank the honorable team that was the first to find servicing new kirin of huawei must remember that instead of that we could be fighting on downgrading at the risky methods guys and returning to errors error writng to serial port could be due to 1 battery 2 kirin annnd the thing that i've found is the connector of phones and the components around it just look at this side also error during flashing is battery for sure also during booting ...always check concerning remove id p40 pro harmony os other models than highest kirins is simple if version lower is very simple just use the modified cable if not just dongrade with the same contry and oem info if u done the id before u'll find it done after downgrade if it is 990 5G or similar must not go to version 10.1 directly just do the 11 hard reset handset and do the ID remove sometimes more than once don't forget to buck up the hole flash here is one log Pack 3: Activated Pack 4: Activated Pack 5: Activated --------- 2023-02-21 23:24:29 --------- SigmaKey 2.46.01 HiSi: Remove Huawei ID HUAWEI USB COM 1.0 (COM36), Provider: HUAWEI Incorporated, Driver ver.: 2.0.6.725, Date: 05/12/2014, USB\VID_12D1&PID_3609&REV_0100 The battery must be connected to the phone's board and fully charged. [YES] HiSilicon: P40/P40Pro 5G (boot 2) Phone model: ELS-NX9 Version: ELS-N29 11.0.0.151(C432E3R6P4) SN: K5J0220422000534 OEM Info IMEI1: 8609xxxxxxxxxx59 OEM Info IMEI2: 860xxxxxxxxxxxx8 MEID: A00000B67A9E3B Phone model: ELS-NX9 Build number: ELS-N29 11.0.0.151(C432E3R6P4) Security area saved to "C:\Users\d\Documents\SigmaKey\security backup\0507256652\860ffffffffff59_860FFFFFFFFFF58_ Huawei_ELS-NX9_ELS-N29 11_0_0_151(C432E3R6P4).skb" Removing Huawei ID...Done eh if it is version 10.1 use boot 1 11 boot 2 12 boot 3 correct me if i'm wrong always thank hard working team instead of ... regards all |
02-23-2023, 01:59 | #10 (permalink) | |
Member: 75223 Status: Offline Thanks Meter: 62 | Quote:
First time i did os 10.1 And it didn't worked bro And i upgrade to next level 11 And it worked for the first try after factory reset I saw someone here in forum did it at the third try after factory for sure If you want i will bring logs from sigma folder ..your case is error writing to serial port.. I faced it many times but it was only battery.. But i agree that there are some handsets that couldn't be serviced even with good level of charge and good connectors Even tried with changing kirin pc and so on Once i bought an frp for mate 20 x There are a few pieces and I think it's from the manufacturer Br | |
The Following 3 Users Say Thank You to lasfar For This Useful Post: |
02-24-2023, 18:51 | #11 (permalink) |
Freak Poster Join Date: Aug 2022 Location: ua Age: 38
Member: 3019648 Status: Offline Sonork: uploads Thanks Meter: 81 | Pack 3: Activated Pack 4: Activated Pack 5: Activated --------- 2023-02-24 19:50:34 --------- SigmaKey 2.46.01 HiSi: Видалити Huawei ID HUAWEI USB COM 1.0 (COM2), Провайдер: HUAWEI Incorporated, Версія драйвера: 2.0.6.725, Дата: 06.11.2015, USB\VID_12D1&PID_3609&REV_0100 Батарея повинна бути під’єднана до плати телефона і повністю заряджена. [ТАК] HiSilicon: P40/P40Pro 5G (boot 3) Відправка загружчика...Помилка запису через порт |
02-24-2023, 20:31 | #12 (permalink) | |
bro did you checked connector and so on? | |
