09-09-2020, 14:20 | #1 (permalink) |
No Life Poster Join Date: Oct 2005 Location: georgia tbilisi
Member: 194939 Status: Offline Sonork: 100.168.25.6 Thanks Meter: 623 | emui 10.1 frp remove Checking fastboot device.....OK Reading info.....OK Device Model: ELE-L29 Device Firmware: :ELE-L29 10.1.0.149(C636E7R3P4) Base Firmware: :ELE-LGRP2-OVS 10.1.0.149 Custom Firmware: :ELE-L29-CUST 10.1.0.7(C636) Preload Firmware: :ELE-L29-PRELOAD 10.0.0.4(C636R3) Device FB Lock: LOCKED Device USER Lock: LOCKED sigma supports this firmware version? i cant find this firmware i have this firmware ELLE-L29B 10.0.0.190(C636E4R3P4)_Firmware_EMUI10.0.0_05015TJ Q when try software testpoint on\off promts downgrade is this safe? or better find firmware? first my question is sigma supports remove frp by softyware tespoint for emui 10.1? |
09-09-2020, 14:41 | #2 (permalink) |
Product Supporter Join Date: Feb 2005 Location: GSMserver Team
Member: 121052 Status: Offline Sonork: 100.107126 Thanks Meter: 80,766 | @ laduka, Yes, you can service current phone. For servicing purposes you can use software or hardware testpoint operation, for more detailed manual refer to this link, please. Here you can find user report of successful phone servicing. Best Regards GSMServer team |
09-09-2020, 14:48 | #3 (permalink) |
Member: 194939 Status: Offline Sonork: 100.168.25.6 Thanks Meter: 623 | https://forum.gsmhosting.com/vbb/f71...sigma-2891886/ i this link phone is dissasembled i want make software tp but firmware not supported so, if i will downgrade to ELLE-L29B 10.0.0.190(C636E4R3P4)_Firmware_EMUI10.0.0_05015TJ Q is safe or not? br |
09-09-2020, 15:08 | #5 (permalink) |
Member: 121052 Status: Offline Sonork: 100.107126 Thanks Meter: 80,766 | @ laduka, It is recommended to use same or higher firmware version. ELE-L29 10.1.0.126(C185) and ELLE-L29B 10.0.0.190 are lower firmware versions, you can try using them at your own risks. Best Regards GSMServer team |
The Following User Says Thank You to GSM_Support For This Useful Post: |
