08-26-2021, 14:37 | #1 (permalink) |
Junior Member Join Date: Aug 2018
Member: 2855835 Status: Offline Thanks Meter: 7 | Firmware versions with closed Hardware TP [solved] ؟؟؟؟؟؟؟؟؟؟؟؟؟؟ Last edited by sahrawigsm; 08-26-2021 at 14:44. |
The Following User Says Thank You to sahrawigsm For This Useful Post: |
08-27-2021, 11:18 | #3 (permalink) |
Product Supporter Join Date: Feb 2005 Location: GSMserver Team
Member: 121052 Status: Offline Sonork: 100.107126 Thanks Meter: 80,766 | @ sahrawigsm, Such an issues are getting investigated by developers team. Best Regards GSMServer team |
The Following 2 Users Say Thank You to GSM_Support For This Useful Post: |
08-28-2021, 11:44 | #4 (permalink) |
No Life Poster Join Date: Aug 2011 Location: bagmati pradesh
Member: 1626780 Status: Offline Thanks Meter: 1,275 | the simple answer is just analyze the time frame between the "hilisilicon new security release" and release of this (now) working "testpoint solution" .. you will get the eta |
09-01-2021, 13:19 | #6 (permalink) |
Product Supporter Join Date: Feb 2003 Location: gsmserver
Member: 21077 Status: Offline Thanks Meter: 116,312 | We know about the devices with closed hardware testpoint and analyze it. As you may know, we service devices from Android 1 to Android 11 |
The Following User Says Thank You to Gsmserver For This Useful Post: |
09-01-2021, 19:49 | #7 (permalink) |
No Life Poster Join Date: May 2015 Location: mumbai Age: 27
Member: 2401939 Status: Offline Thanks Meter: 682 | for now one solution is - find clk of device and shot ground and connect without battery ,device will 100 percent make com 1.0 port then connect battery but u need better hardware idea for finding clk line or point on resistor |
The Following User Says Thank You to owais a For This Useful Post: |
09-05-2021, 07:36 | #11 (permalink) | |
No Life Poster Join Date: Nov 2006 Location: (United States Of Islam) Age: 37
Member: 399832 Status: Offline Sonork: Faheem Anjum Thanks Meter: 24,308 | Quote:
dont be harry wait for solution | |
09-05-2021, 13:49 | #12 (permalink) |
Freak Poster Join Date: Aug 2003 Location: Abidjan
Member: 38050 Status: Offline Thanks Meter: 61 | Firmware versions with closed Hardware TP Hi I have 2 phones with the same condition describe by hamzamohd JNY-L21 10.1.0.338(C185E5R6P1) anyway to remove huawei ID? |
The Following User Says Thank You to dan0007 For This Useful Post: |
09-06-2021, 09:52 | #13 (permalink) |
No Life Poster Join Date: Mar 2018 Location: Future.... ✌️
Member: 2825953 Status: Offline Thanks Meter: 246 | Firmware versions with closed Hardware TP --------- 2021-09-06 10:49:42 --------- SigmaKey 2.40.11 HiSi: Get device info Bootloader unlocked: NO FB unlocked: NO Battery voltage: 3.75 V Phone model: JNY-LX1 Build number: JNY-L01 10.1.0.338(C316E5R3P1) Vendor/Country: vodacom/za System version: Skipped Android version: 10 Base version: JNY-LGRP2-OVS 10.1.0.338 Custom version: JNY-L01-CUST 10.1.0.5(C316) Preload version: JNY-L01-PRELOAD 10.0.1.1(C316R3) Huawei-Over-the-Air info: C_version: C316 D_version: D000 PLMN: 65510 BoardID: 1940 DeviceName: JNY-L01 Done |
The Following User Says Thank You to -=P.F.U=- For This Useful Post: |
09-06-2021, 14:00 | #14 (permalink) |
Freak Poster Join Date: Jan 2009
Member: 956406 Status: Offline Thanks Meter: 55 | Firmware versions with closed Hardware TP TP is not working for this phone..... --------- 2021-09-06 15:48:26 --------- SigmaKey 2.40.11 HiSi: Get device info Bootloader unlocked: NO FB unlocked: NO Battery voltage: 4.23 V Phone model: ANA-NX9 Build number: ANA-N29 11.0.0.194(C432E5R5P3) Vendor/Country: hw/eu System version: Skipped Android version: 10 Base version: ANA-LGRP4-OVS 11.0.0.194 Custom version: ANA-N29-CUST 11.0.0.5(C432) Preload version: ANA-N29-PRELOAD 11.0.0.3(C432R5) Huawei-Over-the-Air info: C_version: C432 D_version: D000 PLMN: 22601 BoardID: 9490 DeviceName: ANA-N29 Done How can I remove Huawei ID with Sigma from this phone ? Thank you in advance for your help ! |
The Following User Says Thank You to ADIVASRO For This Useful Post: |
09-06-2021, 18:36 | #15 (permalink) |
No Life Poster Join Date: Jun 2015 Location: the planet earth
Member: 2406539 Status: Offline Thanks Meter: 101 | P30 Pro hardware test point is no more working with android 11 version.. please add support to remove frp for latest security patch. |
The Following 4 Users Say Thank You to TMAC1122 For This Useful Post: |
