07-26-2022, 11:03 | #1 (permalink) |
No Life Poster Join Date: Apr 2004 Location: POland
Member: 60746 Status: Offline Thanks Meter: 56 | ele-l29 compatible certificate problem i cannot write secure data to p30 ele-l29 --------- 2022-07-26 11:54:11 --------- SigmaKey 2.45.01 HiSi: Write secure data (certificate)... To use compatible certificates from other platforms, please activate Pack 5 i did read form my another p30 on december 2021 - the same sigmakey dongle here is log --------- 2021-12-10 14:13:00 --------- SigmaKey 2.41.05 HiSi: Read secure data (certificate)... SN: XPHPH20911000005 OEM Info IMEI1: 865584048695206 OEM Info IMEI2: 865584048695396 MEID: A00000BA87478A Phone model: ELE-L29 Build number: ELE-L29 10.0.0.178(C431E22R2P5) Security area saved to "C:\Users\Fujitsu i7\Desktop\p30 ele-l29\Cert_Kirin980_865584048695206_865584048695396_ Huawei_ELE-L29_ELE-L29 10.0.0.178(C431E22R2P5).skb" |
07-26-2022, 12:02 | #2 (permalink) |
Product Supporter Join Date: Feb 2005 Location: GSMserver Team
Member: 121052 Status: Offline Sonork: 100.107126 Thanks Meter: 80,766 | @ zaskar, According to the provided data your SigmaKey doesn't have Pack 5 activation. If Pack 5 is not activated certificate files can be used with the same SigmaKey box / dongle , software version it was read by. Best Regards GSMServer team |
07-27-2022, 09:34 | #4 (permalink) |
Product Supporter Join Date: Feb 2003 Location: gsmserver
Member: 21077 Status: Offline Thanks Meter: 116,346 | Huawei firmware/security versions do not stand still, so in order to fully work with certificates, we need to regularly make improvements and changes. There are also internal limitations of our software architecture. Therefore, the transition to new stages of development requires changes. Sometimes this affects the list of required packs. 21.10.2021 (Sigma v.2.41.04) important changes and improvements have been made to how certificates work. Known bugs with certs were fixed, lots of improvements were implemented. On the one hand, if you want to fully work with the certificates (sharing, compatibility mode), you need to have Pack 5. On the other hand, you get the opportunity to use certificates from other platforms. List of platforms with compatible certificates: Kirin 710 / 710A / 810 / 820 / 980 / 985 / 990 / 990 5G Last edited by Gsmserver; 07-27-2022 at 11:49. |
07-28-2022, 08:33 | #5 (permalink) |
Member: 60746 Status: Offline Thanks Meter: 56 | ok but if i buy pack 5 then i can use my stored files ....... like i said .... nice move you wrote long time ago that with pack 5 we can use security files from others, can sharing these files i dont want to use files from others now i cant use my stored files also..... i understand bussines is bussines......... cheers! |
07-28-2022, 11:01 | #6 (permalink) |
Member: 21077 Status: Offline Thanks Meter: 116,346 | Please activate Pack 5 and you will be able to use your stored files with latest Sigma version that contains all important improvements and fixes regarding Sigma certificates. |
