09-12-2020, 10:36 | #1 (permalink) |
No Life Poster Join Date: Sep 2008 Location: Bohicon (Rep of Benin)
Member: 862014 Status: Offline Sonork: 100.1608307 Thanks Meter: 64 | Huawei MHA-L29 how to remove FRP? Bootloader unlocked: NO FB unlocked: NO Battery voltage: 6.64 V Phone model: MHA-L29 Build number: MHA-L29 9.1.0.275(C432E7R1P8) Vendor/Country: hw/eu System version: Skipped Android version: 9 Base version: MHA-LGRP2-OVS 9.1.0.275 Custom version: MHA-L29-CUST 9.0.1.7(C432) Preload version: MHA-L29-PRELOAD 9.0.1.8(C432R1) Huawei-Over-the-Air info: C_version: C432 D_version: D000 IMSI: 61603 BoardID: 5509 DeviceName: MHA-L29 Done --------- 2020-09-12 10:32:15 --------- SigmaKey 2.39.00 HiSi: Remove FRP / Huawei ID Phone model: MHA-L29 Version: MHA-L29 9.1.0.275(C432E7R1P8) Preparing...The phone is NOT connected properly. Read the manual at the official site for details. Note that operation will fail for new Android security patch levels. |
09-12-2020, 10:42 | #2 (permalink) |
Freak Poster Join Date: Oct 2008
Member: 879490 Status: Offline Thanks Meter: 10 | you must use testpoint to remove frp/huawei id. disassembly the phone and use the tp point to view phone in diagnostic mode (usb 1.0) tp point https://www.boot-loader.com/app/webr...HUAWEI_HMA.jpg short circuit the point with ground and connect usb cable to phone.......when you see HUAWEI USB COM 1.0 the frp/huawei id is possible. Last edited by diffusore1976; 09-12-2020 at 10:48. |
09-12-2020, 10:53 | #3 (permalink) |
Product Supporter Join Date: Feb 2005 Location: GSMserver Team
Member: 121052 Status: Offline Sonork: 100.107126 Thanks Meter: 80,766 | @ roni2, According to the provided log file, operation is getting performed in a wrong way. Repeat Remove FRP operation via software or hardware testpoint operation. Detailed manual on how to service phones via software/hardware testpoint can be found by this link. Best Regards GSMServer team |
09-12-2020, 11:04 | #4 (permalink) |
Member: 862014 Status: Offline Sonork: 100.1608307 Thanks Meter: 64 | samething with FLA-AL20 SigmaKey 2.39.00 HiSi: Get device info SN: YAUNW18316035451 IMEI1: 867420032455869 IMEI2: 867420032455869 MEID: A000008C6BDD9C Bootloader unlocked: NO FB unlocked: NO Battery voltage: 3.50 V Phone model: FLA-AL20 Build number: FLA-AL20 8.0.0.175(C00) Vendor/Country: all/cn System version: FLA-AL20 8.0.0.175(C00) Android version: 8.0.0 Base version: Skipped Custom version: Skipped Preload version: Huawei-Over-the-Air info: C_version: C00 D_version: D000 IMSI: 61603 FirmWare: FLA-AL20 8.0.0.175(C00) DeviceName: FLA-AL20 Done --------- 2020-09-12 11:03:03 --------- SigmaKey 2.39.00 HiSi: Remove FRP / Huawei ID Phone model: FLA-AL20 Version: FLA-AL20 8.0.0.175(C00) Preparing...The phone is NOT connected properly. Read the manual at the official site for details. Note that operation will fail for new Android security patch levels. |
09-12-2020, 12:34 | #6 (permalink) |
Member: 121052 Status: Offline Sonork: 100.107126 Thanks Meter: 80,766 | @ roni2, FLA-AL20 is HiSilicon Kirin 659 based phone model, it requires to be serviced via software/hardware testpoint. Check this link for more details, please. Best Regards GSMServer team |
09-12-2020, 17:15 | #7 (permalink) | |
Member: 862014 Status: Offline Sonork: 100.1608307 Thanks Meter: 64 | Quote:
think bro for your help but after the test point and during the unlocking it ask me on *.xml file. where see it bcz this tuto : Procedure:
09-12-2020, 17:35 | #8 (permalink) |
Member: 879490 Status: Offline Thanks Meter: 10 | you must select kirin 960( if you go in info system you can view the cpu phone). excuse me the tp that i suggest is wrong. hma and mha not are the same! the right tp is here https://www.boot-loader.com/app/webr...MATE-9_MHA.jpg |
09-12-2020, 17:42 | #9 (permalink) | |
No Life Poster Join Date: Dec 2003
Member: 46387 Status: Offline Thanks Meter: 139 | Quote:
09-12-2020, 18:22 | #10 (permalink) | |
i allready try all and for 980 it display: 223580492 Sigma dongle 2.39, Initializing...OK Pack 1: Activated Pack 2: Activated Pack 3: Activated Pack 4: Not activated Pack 5: Not activated --------- 2020-09-12 18:14:13 --------- SigmaKey 2.39.00 HiSi: Remove FRP / Huawei ID HUAWEI USB COM 1.0 (COM31), Provider: HUAWEI Incorporated, Driver ver.: 2.0.6.725, Date: 10/08/2014, USB\VID_12D1&PID_3609&REV_0100 HiSilicon: Kirin 980 You should activate required PACK to work with this model. For more information visit www.sigmakey.com apparently I need to activate other packs. but which one really because we still have the 4 and the 5. really | |
09-12-2020, 18:28 | #11 (permalink) | |
Freak Poster Join Date: Aug 2009 Location: neighborhood
Member: 1097964 Status: Offline Thanks Meter: 157 | You need pack4 to service Kirin980 devices Quote:
