03-05-2021, 18:30 | #1 (permalink) |
Junior Member Join Date: Jun 2016 Location: Georgia
Member: 2590969 Status: Offline Thanks Meter: 29 | Huawei P30 Pro VOG-L29 Downgrade SigmaKey 2.40.02 HiSi: Get device info Bootloader unlocked: NO FB unlocked: NO Battery voltage: 3.69 V Phone model: VOG-L29 Build number: VOG-L29 10.1.0.203(C10E13R5P1) Vendor/Country: hw/ru System version: Skipped Android version: 10 Base version: VOG-LGRP2-OVS 10.1.0.203 Custom version: VOG-L29-CUST 10.0.0.13(C10) Preload version: VOG-L29-PRELOAD 10.0.0.1(C10R5) Huawei-Over-the-Air info: C_version: C10 D_version: D000 PLMN: 25099 BoardID: 8559 DeviceName: VOG-L29 I found this version for downgrade VOGUE-L29C 10.1.0.151(C10E11R5P1) Firmware EMUI10.1.0 05015SPM In manual from sigmakey.com it says i need 6 files from firmware and 1 file from support from downgrade section. Inside sigmakey it says 6 files needed and 1 for downgrade but not necessary? Can i skip using this file or no? Only downgrade found at support is VOG-L29C_10.0.0_C10.skf, but it is for 10.0.0 android and i have 10.1.0. And what is this file for? Question, will it work for me, or it will broke phone. Is this downgrade file only for 10.0.0? |
03-06-2021, 14:07 | #2 (permalink) |
Product Supporter Join Date: Feb 2003 Location: gsmserver
Member: 21077 Status: Offline Thanks Meter: 116,329 | I would recommend you to downgrade the phone following this guide: Enable downgrade using SW or HW testpoint |
03-15-2021, 18:15 | #3 (permalink) |
Member: 2590969 Status: Offline Thanks Meter: 29 | For software testpoint i need firmware 10.1.0.203 or higher. But only lower firmwares i could find. So what is my solution, only hardware testpoint? Here is saying https://forum.gsmhosting.com/vbb/14293730-post6.html that testpoint for vog-AL00 and is not the same vog-l29. |
The Following 3 Users Say Thank You to greggh For This Useful Post: |
