Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > GSMServer Products > SigmaKey
Old 02-05-2021, 04:53   #1 (permalink)
parengBok's Avatar
Member: 696820
Sonork: 100.1684793
Thanks Meter: 256
Hwv32 Au Japan.. What pack is required?
Gudday mates,
got here Hwv32 Au for unlock..
Pack 1: Not activated
Pack 2: Activated
Pack 3: Activated
Pack 4: Activated
Pack 5: Not activated
--------- 2021-02-05 11:52:08 ---------
SigmaKey 2.40.01 HiSi: Direct unlock
Android Adapter PCUI (COM74), Provider: Huawei Incorporated, Driver ver.: 2.0.6.725, Date: 12/28/2015, USB\Vid_12D1&Subclass_13&Prot_22
Connecting....
....You should activate required PACK to work with this model.
For more information visit www.sigmakey.com
i have packs 2,3,4..
thanks,
Old 02-05-2021, 10:09   #2 (permalink)
GSM_Support's Avatar
Member: 121052
Sonork: 100.107126
Thanks Meter: 77,434
@ parengBok,
Huawei HWV32 is supported for the following operations:
For Pack3 + Pack4 users
  • Change Vendor/Country/Model
  • ENABLE DOWNGRADE (TESTPOINT)
  • FLASH (factory, fastboot, upgrade) not all versions support this feature
  • Huawei ID remove
  • Load fastboot
  • Read/Write Huawei certificate
  • Software testpoint ON/OFF
  • Unlock
For Pack3 + Pack4 + Pack5 users
  • Enable Huawei certificate/calibrations sharing
For Pack1 users
  • Change Sim card mode (single-dual)
  • Repair IMEI, WI-FI, Bluetooth, serial numbers (Manufacture mode)
  • Unlock (Manufacture mode)
  • Work with Bootloader (Manufacture mode)
  • Wrong Code Counter Reset
For Pack3 users
  • FRP REMOVE
  • READ / Write OEM info (testpoint)
For Pack4 users
  • Downgrade / Change firmware (if downgrade file exists)
  • RESCUE MODE Entering (up to Android 9.x)
  • Write full OTA UPDATE files
Best Regards
GSMServer team
The Following User Says Thank You to GSM_Support For This Useful Post:
Old 02-05-2021, 10:15   #3 (permalink)
parengBok's Avatar
Member: 696820
Sonork: 100.1684793
Thanks Meter: 256
what mode am i going to use for pack 3 and 4 user? i dont have pack 1.. maybe this explains the error..
"You should activate required PACK to work with this model.
For more information visit www.sigmakey.com"
Old 02-05-2021, 10:21   #4 (permalink)
malka4u's Avatar
Member: 1626780
Thanks Meter: 1,043
You have 3+4 activated .. you can unlock this phone by software testpoint method or you can also use hardware testpoint method.
The Following 3 Users Say Thank You to malka4u For This Useful Post:
Old 02-05-2021, 10:59   #5 (permalink)
Member: 121052
Sonork: 100.107126
@ parengBok,
As it was already mentioned by malka4u, you can service phone via software or hardware testpoint operation.
Refer to this link for the detailed manual.
Best Regards
GSMServer team
Old 02-06-2021, 01:55   #6 (permalink)
parengBok's Avatar
Member: 696820
Sonork: 100.1684793
Thanks Meter: 256
Update:
unlocking error before downgrade:
logs
SigmaKey v.2.40.01
xxxxxxxxx Sigma dongle 2.40, Initializing...OK
Pack 2: Activated
Pack 3: Activated
Pack 4: Activated
--------- 2021-02-06 08:10:13 ---------
HUAWEI USB COM 1.0 (COM77), Provider: HUAWEI Incorporated, Driver ver.: 2.0.6.725, Date: 11/6/2015, USB\VID_12D1&PID_3609&REV_0100
HiSilicon: Kirin 65x
Phone model: HWV32
Version: ANE-L12JPZ 9.1.0.281(C791E16R1P7)
SN: 3JQ7N18C28001035
IMEI1: 868565032360813
IMEI2: 868565032360813
MEID: 00000000000000
Phone model: HWV32
Build number: ANE-L12JPZ 9.1.0.281(C791E16R1P7)
Please send
C:\Users\x\Documents\SigmaKey\temporary backup\0234494180\868565032360813_000000000000000_Huawei_HWV32_ANE-L12JPZ 9_1_0_281(C791E16R1P7).skb
file to [email protected]
Failed
same error after downgrade:
logs
 --------- 2021-02-06 08:41:24 ---------
Phone model: HWV32
Version: HWV32 8.0.0.120(C791)
Phone model: HWV32
Build number: HWV32 8.0.0.120(C791)
Please send
C:\Users\x\Documents\SigmaKey\temporary backup\0234494180\868565032360813_000000000000000_Huawei_HWV32_HWV32 8_0_0_120(C791).skb
Failed
Old 02-06-2021, 03:06   #7 (permalink)
parengBok's Avatar
Member: 696820
Sonork: 100.1684793
Thanks Meter: 256
need tested file for unlock for this device..
current firmware of the phone is : Huawei ANE-L12JPZ 8.0.0.120(C791)
Old 02-08-2021, 10:39   #8 (permalink)
Member: 121052
Sonork: 100.107126
@ parengBok,
Upload temporary backups read from this phone to any filesharing web site and post link for them in a current thread.
Best Regards
GSMServer team
Old 02-09-2021, 01:53   #9 (permalink)
parengBok's Avatar
Member: 696820
Sonork: 100.1684793
Thanks Meter: 256
Originally Posted by GSM_Support View Post
@ parengBok,
Best Regards
GSMServer team
Hwv32 Temp Backups
Old 02-11-2021, 03:56   #10 (permalink)
parengBok's Avatar
Member: 696820
Sonork: 100.1684793
Thanks Meter: 256
gudday mates,
still no luck.. no update ?? temporary backup has been uploaded already..
Powered by Searchlight © 2021 Axivo Inc.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
Page generated in 0.16097 seconds with 7 queries
