07-21-2020, 13:52 | #1 (permalink) |
Freak Poster Join Date: Apr 2015 Location: Morocco
Member: 2384687 Status: Offline Thanks Meter: 14 | JKM-LX1 9.1.0.230(C185E2R1P1) help for frp plaese i can't remove frp in this phone is there any easy solution ? SigmaKey 2.37.00b3 HiSi: Get device info Bootloader unlocked: NO FB unlocked: NO Battery voltage: 3.80 V Phone model: JKM-LX1 Build number: JKM-LX1 9.1.0.230(C185E2R1P1) Vendor/Country: hw/meafnaf System version: JKM-LX1 9.0.1.162(SP62C185E1) Android version: 9 Base version: JKM-LGRP2-OVS 9.1.0.230 Custom version: JKM-LX1-CUST 9.1.0.2(C185) Preload version: JKM-LX1-PRELOAD 9.1.0.1(C185R1) Huawei-Over-the-Air info: C_version: C185 D_version: D000 PLMN: 60400 BoardID: 7681 DeviceName: JKM-L21 Done thank you |
The Following User Says Thank You to xboy_6 For This Useful Post: |
07-21-2020, 14:28 | #2 (permalink) |
No Life Poster Join Date: Aug 2011 Location: bagmati pradesh
Member: 1626780 Status: Offline Thanks Meter: 1,275 | STEP 1: Prepare original update.app flash file It must exactly match the smartphone’s firmware version: You may take it from update_sd_base firmware folder You may use original FullOtaUpdate file from this website If you use higher firmware version than the phone has, then we recommend reflashing the phone in fastboot mode with a full firmware after finishing all service operations. So make sure that you will have all files needed for flashing. Don't forget to write down for yourself original firmware version of the device STEP 2: Software testpoint - ON Select "HISILICON" platform from the tab menu in the upper left side of the software Go to the "Service" bookmark Connect the phone to PC using USB cable in Upgrade mode: Android 10: Press and hold VOL+ and Power ON buttons. Select "Upgrade mode -> USB upgrade" from the menu that will appear. Android 9 and lower: vol+vol- and connect USB cable Important: SD-card should be removed from the phone. Press "Software Testpoint ON.../OFF" button Select original update.app flash file in the menu that will appear (main file) The device should now enter "Factory mode - HUAWEI USB COM 1.0" Now you are free to run different service operations, like Remove FRP or Huawei ID, Read/Write operations, etc. |
07-21-2020, 15:12 | #3 (permalink) | |
No Life Poster Join Date: Mar 2006 Location: Central Europe Age: 39
Member: 239548 Status: Offline Thanks Meter: 2,781 | Quote:
The Following User Says Thank You to mcandre For This Useful Post: |
07-21-2020, 15:17 | #4 (permalink) |
Member: 2384687 Status: Offline Thanks Meter: 14 | i succed with test point method --------- 2020-07-21 15:06:48 --------- SigmaKey 2.37.00b3 HiSi: Remove FRP / Huawei ID HUAWEI USB COM 1.0 (COM96), Provider: HUAWEI Incorporated, Driver ver.: 2.0.6.725, Date: 2015-11-06, USB\VID_12D1&PID_3609&REV_0100 HiSilicon: Kirin 710 Phone model: JKM-LX1 Version: JKM-LX1 9.1.0.230(C185E2R1P1) Removing FRP lock...Done Removing Huawei ID....Done Restarting phone...OK thank you |
07-21-2020, 15:51 | #7 (permalink) |
Product Supporter Join Date: Feb 2003 Location: gsmserver
Member: 21077 Status: Offline Thanks Meter: 116,340 | You may use original FullOtaUpdate files from this website |
The Following User Says Thank You to Gsmserver For This Useful Post: |
