01-10-2023, 07:42 | #1 (permalink) |
No Life Poster Join Date: Feb 2007 Location: Ethiopia
Member: 449991 Status: Offline Thanks Meter: 933 | LON-AL00huawei id remove faild help pls SigmaKey 2.46.00b1 HiSi: Remove Huawei ID HUAWEI USB COM 1.0 (COM120), Provider: HUAWEI Incorporated, Driver ver.: 2.0.6.725, Date: 11/5/2015, USB\VID_12D1&PID_3609&REV_0100 HiSilicon: Kirin 960 Phone model: LON-AL00 Version: LON-LGRP1-CHN 9.0.1.179 Removing Huawei ID...Skipped Try removing Huawei ID from manufacture mode. --------- 2023-01-09 22:41:03 --------- SigmaKey 2.46.00b1 HiSi: Remove Huawei ID Android Adapter PCUI (COM48), Provider: Huawei Incorporated, Driver ver.: 2.0.6.725, Date: 12/27/2015, USB\Vid_12D1&Subclass_13&Prot_22 Connecting.... Android Adapter PCUI (COM48), Provider: Huawei Incorporated, Driver ver.: 2.0.6.725, Date: 12/27/2015, USB\Vid_12D1&Subclass_13&Prot_22 Firmware: System 9.0.1.25(03OF), Date: Fri Apr 12 21:10:28 CST 2019 Boot Version: (unknow), FastBoot Version: Chipset-CHICAGO9.0.1.6(04ZL)_FASTBOOT Recovery Version: (unknow), System Version: System 9.0.1.25(03OF) Removing firmware protection...This Android security patch level is not supported. Please wait for future updates. |
01-10-2023, 08:45 | #2 (permalink) |
Product Supporter Join Date: Feb 2003 Location: gsmserver
Member: 21077 Status: Offline Thanks Meter: 116,340 | I advise you to downgrade the firmware version (flash lower firmware version), and then repeat the procedure for removing the Huawei ID through the manufacture mode. |
01-10-2023, 10:17 | #3 (permalink) | |
Member: 449991 Status: Offline Thanks Meter: 933 | Quote:
LON-AL00C00E62R1P12B178 (9.0.1.178) LON-AL00C00E61R1P8B150 (9.0.1.150) LON-AL00C00E61R1P8B150 (9.0.1.150) | |
01-10-2023, 11:45 | #4 (permalink) |
Member: 21077 Status: Offline Thanks Meter: 116,340 | I would try to flash the lowest version available. So you can try 9.0.1.150 or even lower. Don't forget to select both files from the package. Run "Enable Downgrade" operation on service tab. |
01-12-2023, 17:11 | #5 (permalink) | |
UPDATE.APP USERDATA.APP PTABLE.APP so can i use UPDATE.APP and USERDATA.APP is enough ? | |
