10-28-2020, 09:52 | #1 (permalink) |
No Life Poster Join Date: Oct 2011 Location: Punjab
Member: 1675429 Status: Offline Sonork: 1609235 Thanks Meter: 174 | Mate 20 Pro not going into testpoint mode [solved] i emiled but no response SigmaKey 2.39.04 HiSi: Software testpoint On.../Off Android Adapter PCUI (COM1754), Provider: HUAWEI Technologies CO.,LTD, Driver ver.: 1.0.24.0, Date: 12/18/2015, USB\Vid_12D1&Subclass_13&Prot_22 Connecting...Please send C:\Users\DELL\Documents\SigmaKey\temporary backup\0514223872\LYA-LGRP2-OVS 9_0_0_155.skb file to [email protected] Missing response from boot Last edited by Gsmserver; 10-29-2020 at 12:33. |
10-28-2020, 10:13 | #2 (permalink) |
Product Supporter Join Date: Feb 2005 Location: GSMserver Team
Member: 121052 Status: Offline Sonork: 100.107126 Thanks Meter: 80,766 | @ darmobiles, Fully charge phone's battery, ensure that it is properly connected, select DBA port and repeat operation. Best Regards GSMServer team Last edited by GSM_Support; 10-28-2020 at 11:09. |
The Following User Says Thank You to GSM_Support For This Useful Post: |
10-28-2020, 12:17 | #3 (permalink) |
Member: 1675429 Status: Offline Sonork: 1609235 Thanks Meter: 174 | ok thanks i will try and port result. one thing more Cam-L21 is realy unsupported ? --------- 2020-10-28 16:16:07 --------- SigmaKey 2.39.04 MTK: Remove FRP Phone model: CAM-L21 Version: CAM-L21C185B162 Removing FRP lock...Unsupported |
10-28-2020, 12:54 | #4 (permalink) |
Member: 121052 Status: Offline Sonork: 100.107126 Thanks Meter: 80,766 | @ darmobiles, Select HSilicon platform and repeat operation according to the manual. Best Regards GSMServer team |
10-28-2020, 13:03 | #5 (permalink) |
Member: 1675429 Status: Offline Sonork: 1609235 Thanks Meter: 174 | i select all but same SigmaKey 2.39.04 HiSi: Remove FRP / Huawei ID Preparing....Command not allowed --------- 2020-10-28 16:07:40 --------- SigmaKey 2.39.04 Qcom: Remove FRP / Huawei ID ^ Android Bootloader InterfaceCommand not allowed --------- 2020-10-28 16:09:45 --------- SigmaKey 2.39.04 MTK: Remove FRP Phone model: CAM-L21 Version: CAM-L21C185B162 Removing FRP lock...Unsupported |
10-28-2020, 13:31 | #6 (permalink) |
Member: 121052 Status: Offline Sonork: 100.107126 Thanks Meter: 80,766 | @ darmobiles, Here you can find successful report on a phone with the same firmware version. Charge battery, re-connect phone, re-install drivers and repeat operation. Best Regards GSMServer team |
10-29-2020, 07:51 | #8 (permalink) | |
Member: 1675429 Status: Offline Sonork: 1609235 Thanks Meter: 174 | Quote:
Huawei Mate 20 Pro LYA-L29 hw eu HLRCF Laya-L29C 9.1.0.358(C432E10R1P16) Firmware EMUI9.1.0 05015KYS [androidhost.ru] phone version is Android version: 9 Base version: LYA-LGRP2-OVS 9.1.0.358 Custom version: LYA-L09-CUST 9.0.0.10(C432) Preload version: LYA-L09-PRELOAD 9.0.0.16(C432R1) previously i use LYA-L29 file for this phone to downgrade (sd card) and remove frp, that's why i am asking. thanks | |
10-29-2020, 09:15 | #10 (permalink) | |
Member: 1675429 Status: Offline Sonork: 1609235 Thanks Meter: 174 | Quote: i will download file you recommend, for example if any case, phone not turn on after unlock then can use 1 of these files for flash in same test point mode and phone will be perfectly turn on? | |
10-29-2020, 09:17 | #11 (permalink) |
Product Supporter Join Date: Feb 2003 Location: gsmserver
Member: 21077 Status: Offline Thanks Meter: 116,329 | The device will turn on Regarding flashing. You should use all files from the SD-Firmware package. |
The Following User Says Thank You to Gsmserver For This Useful Post: |
10-29-2020, 09:59 | #12 (permalink) |
Member: 1675429 Status: Offline Sonork: 1609235 Thanks Meter: 174 | You are 100% Right. Phone is Unlocked Really wonderful and cooperative Team. Thanks A Lot SigmaKey 2.39.04 HiSi: Software testpoint On.../Off HUAWEI USB COM 1.0 (COM92), Provider: HUAWEI Incorporated, Driver ver.: 2.0.6.725, Date: 8/10/2014, USB\VID_12D1&PID_3609&REV_0100 HiSilicon: Kirin 980 Phone model: LYA-L09 Version: LYA-L09 9.1.0.358(C432E10R1P16) This operation may brick the phone if the phone firmware version does not EXACTLY match the software testpoint firmware version! If you are unsure, better completely reflash the firmware. Are you sure you want to proceed? [YES] Repairing.........Done |
The Following User Says Thank You to darmobiles For This Useful Post: |
