Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > GSMServer Products > SigmaKey
Old 10-28-2020, 09:52   #1 (permalink)
darmobiles's Avatar
Member: 1675429
Sonork: 1609235
Thanks Meter: 174
Mate 20 Pro not going into testpoint mode [solved]
I am trying to remove Google account and Network lock using test point on/off function but showing this error
i emiled but no response
SigmaKey 2.39.04 HiSi: Software testpoint On.../Off
Android Adapter PCUI (COM1754), Provider: HUAWEI Technologies CO.,LTD, Driver ver.: 1.0.24.0, Date: 12/18/2015, USB\Vid_12D1&Subclass_13&Prot_22
Connecting...Please send
C:\Users\DELL\Documents\SigmaKey\temporary backup\0514223872\LYA-LGRP2-OVS 9_0_0_155.skb
file to [email protected]
Missing response from boot
Old 10-28-2020, 10:13   #2 (permalink)
GSM_Support's Avatar
Member: 121052
Sonork: 100.107126
Thanks Meter: 80,766
@ darmobiles,
Fully charge phone's battery, ensure that it is properly connected, select DBA port and repeat operation.
Best Regards
GSMServer team
The Following User Says Thank You to GSM_Support For This Useful Post:
Old 10-28-2020, 12:17   #3 (permalink)
darmobiles's Avatar
Member: 1675429
Sonork: 1609235
Thanks Meter: 174
ok thanks i will try and port result. one thing more
Cam-L21 is realy unsupported ?
--------- 2020-10-28 16:16:07 ---------
SigmaKey 2.39.04 MTK: Remove FRP
Phone model: CAM-L21
Version: CAM-L21C185B162
Removing FRP lock...Unsupported
Old 10-28-2020, 12:54   #4 (permalink)
Member: 121052
Sonork: 100.107126
@ darmobiles,
Select HSilicon platform and repeat operation according to the manual.
Best Regards
GSMServer team
Old 10-28-2020, 13:03   #5 (permalink)
darmobiles's Avatar
Member: 1675429
Sonork: 1609235
Thanks Meter: 174
i select all but same
SigmaKey 2.39.04 HiSi: Remove FRP / Huawei ID
Preparing....Command not allowed
--------- 2020-10-28 16:07:40 ---------
SigmaKey 2.39.04 Qcom: Remove FRP / Huawei ID
^ Android Bootloader InterfaceCommand not allowed
--------- 2020-10-28 16:09:45 ---------
Old 10-28-2020, 13:31   #6 (permalink)
Member: 121052
Sonork: 100.107126
@ darmobiles,
Here you can find successful report on a phone with the same firmware version.
Charge battery, re-connect phone, re-install drivers and repeat operation.
Best Regards
GSMServer team
Old 10-28-2020, 13:41   #7 (permalink)
Shensohau's Avatar
Member: 1377783
Sonork: 100.1611724
Thanks Meter: 3,336
Hi, put it manually... you will need dissamble device and try...
Old 10-29-2020, 07:51   #8 (permalink)
darmobiles's Avatar
Member: 1675429
Sonork: 1609235
Thanks Meter: 174
Originally Posted by GSM_Support View Post
@ darmobiles,
Best Regards
GSMServer team
Can i use this file for testmode ?
Huawei Mate 20 Pro LYA-L29 hw eu HLRCF Laya-L29C 9.1.0.358(C432E10R1P16) Firmware EMUI9.1.0 05015KYS [androidhost.ru]
phone version is
Android version: 9
Base version: LYA-LGRP2-OVS 9.1.0.358
Custom version: LYA-L09-CUST 9.0.0.10(C432)
Preload version: LYA-L09-PRELOAD 9.0.0.16(C432R1)
previously i use LYA-L29 file for this phone to downgrade (sd card) and remove frp, that's why i am asking.
thanks
Old 10-29-2020, 08:53   #9 (permalink)
Gsmserver's Avatar
Member: 21077
Thanks Meter: 116,340
darmobiles, yes, this file should fit for software TP.
Alternative file
The Following User Says Thank You to Gsmserver For This Useful Post:
Old 10-29-2020, 09:15   #10 (permalink)
darmobiles's Avatar
Member: 1675429
Sonork: 1609235
Thanks Meter: 174
Alternative file
Thanks a lot Sir
i will download file you recommend,
for example if any case, phone not turn on after unlock then can use 1 of these files for flash in same test point mode and phone will be perfectly turn on?
Old 10-29-2020, 09:17   #11 (permalink)
Gsmserver's Avatar
Member: 21077
The device will turn on
Regarding flashing. You should use all files from the SD-Firmware package.
Old 10-29-2020, 09:59   #12 (permalink)
darmobiles's Avatar
Member: 1675429
Sonork: 1609235
Thanks Meter: 174
You are 100% Right. Phone is Unlocked
Really wonderful and cooperative Team. Thanks A Lot
HUAWEI USB COM 1.0 (COM92), Provider: HUAWEI Incorporated, Driver ver.: 2.0.6.725, Date: 8/10/2014, USB\VID_12D1&PID_3609&REV_0100
HiSilicon: Kirin 980
Phone model: LYA-L09
Version: LYA-L09 9.1.0.358(C432E10R1P16)
This operation may brick the phone if the phone firmware version does not EXACTLY match the software testpoint firmware version!
If you are unsure, better completely reflash the firmware. Are you sure you want to proceed? [YES]
Repairing.........Done
The Following User Says Thank You to darmobiles For This Useful Post:
Page generated in 0.22249 seconds with 9 queries
