09-30-2021, 14:03 | #1 (permalink) |
No Life Poster Join Date: Oct 2003 Location: Poland Age: 47
Member: 42387 Status: Offline Sonork: 1573735 Thanks Meter: 407 | NEED Help, DRA-L21 after FRP is in META mode [solved] Code: SigmaKey 2.41.02 MTK: Remove FRP Phone model: DRA-L21 Version: DRA-L21 1.0.0.145(C738) Removing FRP lock...Done After this, phone goes into META Mode, cannot boot it. Need Help asap. Last edited by Gsmserver; 09-30-2021 at 14:42. |
09-30-2021, 14:08 | #2 (permalink) |
Product Supporter Join Date: Feb 2003 Location: gsmserver
Member: 21077 Status: Offline Thanks Meter: 116,340 | Try pressing power on button for 20-30 seconds. Or press vol+ and power on for the same time period. |
The Following User Says Thank You to Gsmserver For This Useful Post: |
09-30-2021, 14:17 | #3 (permalink) |
Member: 42387 Status: Offline Sonork: 1573735 Thanks Meter: 407 | Thank you very much, when I pressed power button, it reboots to meta mode. Problem was, I have connected USB cable. Without cable, after pressing POWER ON for 15 sec, phone reboots and finishing resetting frp now (format) .. All OK. |
09-30-2021, 14:20 | #4 (permalink) |
No Life Poster Join Date: Aug 2011 Location: bagmati pradesh
Member: 1626780 Status: Offline Thanks Meter: 1,275 | Until you close sigma key software sigma send all mtk port to meta mode ..(unwanted function ) separate reboot to meta mode option will be good close sigma software and restart phone by pressing keys |
The Following 2 Users Say Thank You to malka4u For This Useful Post: |
09-30-2021, 14:29 | #6 (permalink) |
Member: 21077 Status: Offline Thanks Meter: 116,340 | Most likely, the phone turns on for a long time after the data format. By the way, I would recommend removing FRP on this device using SPFT method. Manual: Remove FRP for Huawei/Alcatel/Moto and other MTK devices This is the correct servicing manual. |
