01-15-2019, 10:54 | #1 (permalink) |
Freak Poster Join Date: Sep 2005 Location: quantity or quality? :)
Member: 179142 Status: Offline Thanks Meter: 42 | Need help: Motorola e5 play after unlock i unlock it using sigmakey but always error like this [Spoiler]SigmaKey v.2.29.15 xxxxxxxx Sigma dongle 2.29, Initializing...OK Pack 1: Not activated Pack 2: Activated Pack 3: Not activated Unique promotional offer for our best clients. Buy Sigma Pack 1+3 Activation for special price - 129.99 USD only. Get maximum functionality from your Sigma. --------- 2019-01-11 18:43:15 --------- SigmaKey 2.29.15 Qcom: Get unlock codes Motorola QC Diag Port (COM152), Provider: Motorola, Driver ver.: 5.1.0.0, Date: 3/1/2013, USB\VID_22B8&PID_2EC5&REV_0318&MI_00 Phone model: Moto E5 Play (Verizon) Firmware: MPSS.JO.3.0.c11-00024-8937_GENNS_PACK-1.161849.0.162123.1 Date: Jul 30 2018 04:30:23, Jul 27 2018 05:00:00, 8937.gen Software IMEI: 351838091124820 Bluetooth address: 000000000000 Reading data...Unexpected response from the phone[/Spoiler] then i figured it out it has to be enter the locked sim, then it goes like this [Spoiler]--------- 2019-01-12 06:02:37 --------- SigmaKey 2.29.15 Qcom: Get unlock codes Motorola QC Diag Port (COM102), Provider: Motorola, Driver ver.: 5.1.0.0, Date: 3/1/2013, USB\VID_22B8&PID_2EC5&REV_0318&MI_00 Phone model: Moto E5 Play (Verizon) Firmware: MPSS.JO.3.0.c11-00024-8937_GENNS_PACK-1.161849.0.162123.1 Date: Jul 30 2018 04:30:23, Jul 27 2018 05:00:00, 8937.gen Software IMEI: 351838091124820 Bluetooth address: 000000000000 Security area saved to "C:\Users\derryeuy\Documents\SigmaKey\security backup\0947820596\351838091124820_MPSS_JO_3_0_c11-00024-8937_GENNS_PACK-1_161849_0_162123_1.skb" Connecting....^ Motorola ADB InterfaceSmart-card state is "removed" [/Spoiler] at the middle of the progress has eror and when i power on it has imei 0 then i try to unlock again [Spoiler]--------- 2019-01-12 13:29:31 --------- SigmaKey 2.29.15 Qcom: Get unlock codes Motorola QC Diag Port (COM183), Provider: Motorola, Driver ver.: 5.1.0.0, Date: 3/1/2013, USB\VID_22B8&PID_2EC5&REV_0318&MI_00 Phone model: Moto E5 Play (Verizon) Firmware: MPSS.JO.3.0.c11-00024-8937_GENNS_PACK-1.161849.0.162123.1 Date: Jul 30 2018 04:30:23, Jul 27 2018 05:00:00, 8937.gen Software IMEI: Not found Bluetooth address: 000000000000 Security area saved to "C:\Users\derryeuy\Documents\SigmaKey\security backup\0947820596\MPSS_JO_3_0_c11-00024-8937_GENNS_PACK-1_161849_0_162123_1.skb" Reading unlock codes...Done [/Spoiler] it was done and imei was normal again, i reboot the phone but the phone wasnt asking for a code and yeet the signal bar was missing, so i flash the phone using fastboot mode using this command [Spoiler]fastboot oem fb_mode_set fastboot flash partition gpt.bin fastboot flash dsp adspso.bin fastboot flash bootloader bootloader.img fastboot flash recovery recovery.img fastboot flash logo logo.bin fastboot flash boot boot.img fastboot flash modem NON-HLOS.bin fastboot erase modemst1 fastboot erase modemst2 fastboot flash fsg fsg.mbn fastboot flash system system.img_sparsechunk.0 fastboot flash system system.img_sparsechunk.1 fastboot flash system system.img_sparsechunk.2 fastboot flash system system.img_sparsechunk.3 fastboot flash system system.img_sparsechunk.4 fastboot erase DDR fastboot erase cache fastboot erase userdata fastboot flash oem oem.img fastboot flash vendor vendor.img fastboot oem fb_mode_clear [/Spoiler] the flashing progress was done but when it boot, it gives error 1. "Motorola Modem Service has stopped x cloase app", then 2. "There's an internal problem your device, and it may be unstable until you factory data reset." and cannot enter menu i was try flash again using Software Upgrade Assistant but the problems still remain. 1. do you have solution for this? 2. How do we restore the backup file with .skb extension? and can it restore using fastboot mode? as when the last procedure was writing file on fastboot mode. because i cant enter menu to enable adb and diag to repeat the unlock progress 3. does moto e5 play bootloader can be unlocked? pardon me it seems that spoiler doesnt work |
01-15-2019, 13:09 | #2 (permalink) | |
Freak Poster Join Date: Feb 2017 Location: D.R
Member: 2684440 Status: Offline Thanks Meter: 218 | Quote:
the only thing you needed to do was to try the unlock process again, since it saves a backup and when you unlock it in the second step it restores it and the phone is perfectly functioning ... another thing to keep in mind before unlocking you must ensure that all drivers are correctly installed because when you do the second restart if you updated the drivers manually and not installed correctly it is disabled and Sigma does not recognize the phone when reconnecting and for this error the phone is left without imei, but this is resolved by trying again to restore security from the copy made by the program Enviado desde mi iPhone utilizando Tapatalk | |
The Following User Says Thank You to GSM_FIX For This Useful Post: |
01-15-2019, 15:52 | #3 (permalink) | |
Member: 179142 Status: Offline Thanks Meter: 42 | Quote:
a lot of user have the same problem look here http://forum.gsmhosting.com/vbb/f719...opped-2524282/ https://forum.xda-developers.com/mot...rizon-t3875624 | |
The Following User Says Thank You to derrytea For This Useful Post: |
01-15-2019, 18:50 | #4 (permalink) |
Member: 2684440 Status: Offline Thanks Meter: 218 | If I read correctly, the problem was that when I gave you an error the phone stopped asking for the unlock code, proceeded to flash the corresponding firmware and left you with the error of the modem, what I told you that you should have done was to try the process again and that I could solve it in that way because it restored the backup copy, the imei asked for the code again ... after that everything worked normally for me Enviado desde mi iPhone utilizando Tapatalk |
01-15-2019, 21:59 | #5 (permalink) | |
01-15-2019, 22:28 | #6 (permalink) |
Member: 2684440 Status: Offline Thanks Meter: 218 | when you try to do the unlock again sigma restores the backup that you saved... try to do the UNLOCK process again, I think you dont need the ADB be activated sigma will use the phone in factory mode and the ADB will be activad by the factory mode option. Enviado desde mi iPhone utilizando Tapatalk |
01-15-2019, 23:53 | #7 (permalink) | |
if it was detected by the computer, i wont be making this thread and looking for a solution. | |
01-16-2019, 16:56 | #10 (permalink) |
Product Supporter Join Date: Feb 2005 Location: GSMserver Team
Member: 121052 Status: Offline Sonork: 100.107126 Thanks Meter: 80,766 | @ derrytea At the moment, security backups are getting saved for the development purposes only. It can not be flashed back onto the phone. In order to restore phone try performing following operations:
Best Regards GSMServer team |
09-20-2021, 14:09 | #11 (permalink) | |
No Life Poster Join Date: Sep 2012 Location: dhaka
Member: 1816848 Status: Offline Thanks Meter: 103 | Quote:
