09-07-2020, 07:58 | #1 (permalink) |
No Life Poster Join Date: Feb 2008 Location: Philippines
Member: 696820 Status: Offline Sonork: 100.1684793 Thanks Meter: 269 | Nova 5 Pro SEA-AL10 Huawei ID.. badly needing guide on how to remove huawei id.. Found Phone : SEA-AL10 Model : Huawei phone in fastboot mode Serial NR. : 6HJDU19828019081 Firmware : SEA-AL10 10.0.0.154(C00E21R2P3 thanks! |
09-08-2020, 04:54 | #4 (permalink) |
Member: 696820 Status: Offline Sonork: 100.1684793 Thanks Meter: 269 | Update: Code: SigmaKey v.2.38.06 xxxxxxxxx Sigma dongle 2.38, Initializing...OK Pack 1: Not activated Pack 2: Activated Pack 3: Activated Pack 4: Activated --------- 2020-09-08 11:46:27 --------- SigmaKey 2.38.06 HiSi: Software testpoint On.../Off DBAdapter Reserved Interface (COM83), Provider: Huawei Incorporated, Driver ver.: 2.0.6.725, Date: 12/28/2015, USB\Vid_12D1&Subclass_13&Prot_23 Using extended heuristic method... Hardware IMEI: 020304050607080 Flash file C:\Users\Hayyan\Documents\Seattle-AL10 10.0.0.103(C00E19R5P3)_Firmware_EMUI10.0.0_05015WGQ File By (Support.**************)\Software\dload\update_sd_base\UPDATE.APP Enabling diagnostic port...Done We strictly recommend performing "Enable Downgrade" on "Flash" tab, as the first service operation on this device! --------- 2020-09-08 11:48:07 --------- SigmaKey 2.38.06 HiSi: Remove FRP / Huawei ID HUAWEI USB COM 1.0 (COM89), Provider: HUAWEI Incorporated, Driver ver.: 2.0.6.725, Date: 11/6/2015, USB\VID_12D1&PID_3609&REV_0100 HiSilicon: Kirin 980 Phone model: SEA-AL10 Version: SEA-AL10 10.0.0.154(C00E21R2P3) Removing FRP lock...Done Removing Huawei ID....Done Restarting phone...OK fone is now dead.. only HUAWEI USB COM 1.0 on device manager.. now im dead.. is there a way to make this come back to life? |
09-08-2020, 08:23 | #5 (permalink) | |
No Life Poster Join Date: Apr 2013 Location: DRC KINSHASA
Member: 1917228 Status: Offline Sonork: 100.1645067 Thanks Meter: 290 | Quote:
This is for you bro: Change region as you're in huawei 1.0 so you can write this file easily to unbrick your device | |
The Following 2 Users Say Thank You to kiusnga For This Useful Post: |
09-08-2020, 09:09 | #6 (permalink) | |
No Life Poster Join Date: Nov 2006 Location: (United States Of Islam) Age: 37
Member: 399832 Status: Offline Sonork: Faheem Anjum Thanks Meter: 24,310 | Quote:
now again press testpoint on off button and your will be back to normal from COM1 | |
The Following 3 Users Say Thank You to Faheem Anjum For This Useful Post: |
09-09-2020, 02:47 | #8 (permalink) |
Member: 696820 Status: Offline Sonork: 100.1684793 Thanks Meter: 269 | Update: Handset is now ok.. i just overlooked step 3.. Code: SigmaKey v.2.38.06 xxxxxxxxx Sigma dongle 2.38, Initializing...OK Pack 1: Not activated Pack 2: Activated Pack 3: Activated Pack 4: Activated --------- 2020-09-08 11:46:27 --------- SigmaKey 2.38.06 HiSi: Software testpoint On.../Off DBAdapter Reserved Interface (COM83), Provider: Huawei Incorporated, Driver ver.: 2.0.6.725, Date: 12/28/2015, USB\Vid_12D1&Subclass_13&Prot_23 Using extended heuristic method... Hardware IMEI: 020304050607080 Flash file C:\Users\Hayyan\Documents\Seattle-AL10 10.0.0.103(C00E19R5P3)_Firmware_EMUI10.0.0_05015WGQ File By (Support.**************)\Software\dload\update_sd_base\UPDATE.APP Enabling diagnostic port...Done We strictly recommend performing "Enable Downgrade" on "Flash" tab, as the first service operation on this device! --------- 2020-09-08 11:48:07 --------- SigmaKey 2.38.06 HiSi: Remove FRP / Huawei ID HUAWEI USB COM 1.0 (COM89), Provider: HUAWEI Incorporated, Driver ver.: 2.0.6.725, Date: 11/6/2015, USB\VID_12D1&PID_3609&REV_0100 HiSilicon: Kirin 980 Phone model: SEA-AL10 Version: SEA-AL10 10.0.0.154(C00E21R2P3) Removing FRP lock...Done Removing Huawei ID....Done --------- 2020-09-08 11:56:09 --------- SigmaKey 2.38.06 HiSi: Software testpoint On.../Off HUAWEI USB COM 1.0 (COM89), Provider: HUAWEI Incorporated, Driver ver.: 2.0.6.725, Date: 11/6/2015, USB\VID_12D1&PID_3609&REV_0100 HiSilicon: Kirin 980 Phone model: SEA-AL10 Version: SEA-AL10 10.0.0.154(C00E21R2P3) Using extended heuristic method... This operation may brick the phone if the phone firmware version does not EXACTLY match the software testpoint firmware version! If you are unsure, better completely reflash the firmware. Are you sure you want to proceed? [YES] Repairing.........Done |
