06-10-2022, 20:48 | #1 (permalink) |
Freak Poster Join Date: May 2018 Location: Baku Age: 37
Member: 2836410 Status: Offline Thanks Meter: 97 | P-Smart 2021 Downgrade Problem [SOLVED] Last edited by Gsmserver; 06-12-2022 at 08:39. |
06-11-2022, 08:43 | #2 (permalink) | |
Product Supporter Join Date: Feb 2003 Location: gsmserver
Member: 21077 Status: Offline Thanks Meter: 116,131 | Quote:
Don't forget to note actual information about the phone, like firmware version and so on. Doing the backup of the firmware is also a recommendation. | |
06-11-2022, 08:52 | #3 (permalink) | |
Member: 2836410 Status: Offline Thanks Meter: 97 | Quote:
06-11-2022, 09:06 | #4 (permalink) |
Member: 21077 Status: Offline Thanks Meter: 116,131 | Connect the phone to PC using USB cable in the FACTORY mode. It should be detected as HUAWEI USB COM 1.0 device (VID12D1 PID3609) in the System. In most cases Testpoint has to be used to force the device to FACTORY mode You can use SOFTWARE TESTPOINT for low firmware and security versions. Last edited by Gsmserver; 06-11-2022 at 09:13. |
06-11-2022, 09:45 | #5 (permalink) | |
06-11-2022, 09:47 | #6 (permalink) |
Member: 2836410 Status: Offline Thanks Meter: 97 | Downgraded via HiSuite Proxy 3.02 method, thanks. But please fix this poblem, because UFS models needs 7th file - .skf downgrade file, but nowhere such file- "STEP 5: Select lower fw version + downgrade file: Open HiSilicon tab and go to Flash bookmark Select DBA adapter port in the ports tab Select files for flashing: Important! You need to select 7 files for downgrading exactly in this order. FLASH FILE 1: PTABLE.APP from update_sd_base folder FLASH FILE 2: PTABLE.APP from update_sd_cust folder FLASH FILE 3: PTABLE.APP from update_sd_preload folder FLASH FILE 4: UPDATE.APP from update_sd_base folder FLASH FILE 5: UPDATE.APP from update_sd_cust folder FLASH FILE 6: UPDATE.APP from update_sd_preload folder FLASH FILE 7: Special downgrade file in *.skf format that fits to your actual model, phone's firmware version and customization version. We prepared it in step 3." |
06-11-2022, 10:21 | #7 (permalink) |
No Life Poster Join Date: Jun 2011 Location: earth
Member: 1591394 Status: Offline Thanks Meter: 551 | U dont need downgrade button, select all flash files and write button, if files are ok and match to phone all be ok. In some cases need reflash in upgrade mode after write in com1 |
06-11-2022, 11:51 | #10 (permalink) |
Member: 2836410 Status: Offline Thanks Meter: 97 | SOLVED! I had another P Smart 2021 that needed to be downgraded. Used write button in SigmaKey, and downgraded successefully! Thanks. |
The Following 2 Users Say Thank You to Rauf86 For This Useful Post: |
