08-10-2020, 14:24 | #1 (permalink) |
No Life Poster Join Date: Feb 2003 Location: In the dark side ;) Age: 44
Member: 21508 Status: Offline Thanks Meter: 186 | P30 PRO VOG-L29 10.1.0.133 software testpoint sporblem SigmaKey 2.38.04b1 HiSi: Software testpoint On.../Off DBAdapter Reserved Interface (COM573), Provider: HUAWEI Technologies CO.,LTD, Driver ver.: 1.0.26.0, Date: 18/05/2016, USB\Vid_12D1&Subclass_13&Prot_23 Hardware IMEI: 020304050607080 Flash file E:\C\___gsm\____huawei\VOG-L29\VOGUE-L29C 10.1.0.123(C431E19R2P5patch02)_Firmware_EMUI10.1.0 _05016DYH\dload\update_sd_base\UPDATE.APP Version mismatch. Use "Enable downgrade" action first, then retry flashing. SigmaKey 2.38.04b1 HiSi: Get device info Bootloader unlocked: NO FB unlocked: NO Battery voltage: 3.88 V Phone model: VOG-L29 Build number: VOG-L29 10.1.0.123(C431E19R2P5) Vendor/Country: hw/eea System version: Skipped Android version: 10 Base version: VOG-LGRP2-OVS 10.1.0.133 Custom version: VOG-L29-CUST 10.0.0.19(C431) Preload version: VOG-L29-PRELOAD 10.0.0.5(C431R2) Huawei-Over-the-Air info: C_version: C431 D_version: D000 PLMN: 20801 BoardID: 8542 DeviceName: VOG-L29 Done |
08-10-2020, 15:17 | #2 (permalink) |
Product Supporter Join Date: Feb 2005 Location: GSMserver Team
Member: 121052 Status: Offline Sonork: 100.107126 Thanks Meter: 80,766 | @ equinoksб More likely that update.app file you are trying to use is modified/ not original. Try using another SD_update file and post results in a current thread. Best Regards GSMServer team |
08-10-2020, 15:25 | #3 (permalink) | |
Member: 21508 Status: Offline Thanks Meter: 186 | Quote:
best regards! | |
08-13-2020, 14:36 | #4 (permalink) | |
No Life Poster Join Date: Dec 2015 Location: hossting
Member: 2501288 Status: Offline Thanks Meter: 328 | same problem here i have same firmware but give me message Version mismatch SigmaKey 2.38.04 HiSi: Software testpoint On.../Off DBAdapter Reserved Interface (COM73), Provider: HUAWEI Technologies CO.,LTD, Driver ver.: 1.0.26.0, Date: 18-May-16, USB\Vid_12D1&Subclass_13&Prot_23 Hardware IMEI: 020304050607080 Flash file G:\VOGUE-L29C 10.1.0.123(C431E19R2P5patch02)_Firmware_EMUI10.1.0 _05016DYH\Software\dload\update_sd_base\UPDATE.APP Version mismatch. Use "Enable downgrade" action first, then retry flashing. Quote:
08-13-2020, 15:06 | #5 (permalink) |
Member: 121052 Status: Offline Sonork: 100.107126 Thanks Meter: 80,766 | @ Steve-1, Upload file you are trying to use to any filesharing web site and post link for it in a current thread. Best Regards GSMServer team |
08-13-2020, 17:31 | #6 (permalink) | |
Member: 2501288 Status: Offline Thanks Meter: 328 | Quote:
https://easy-firmware.com/index.php?...file&id=278954 | |
