11-05-2020, 16:19 | #1 (permalink) |
Freak Poster Join Date: Nov 2008 Location: uk
Member: 912802 Status: Offline Thanks Meter: 19 | P30 Pro VOG L29 I am trying to remove frp from p30 pro vog l29 Base version: VOG-LGRP2-OVS 10.1.0.161 Custom version: VOG-L29-CUST 10.0.0.23(C431) Preload version: VOG-L29-PRELOAD 10.0.0.5(C431R2) Getting data retention error on software test point on / off stage Any Help Kind Regards |
11-05-2020, 16:31 | #2 (permalink) |
Product Supporter Join Date: Feb 2005 Location: GSMserver Team
Member: 121052 Status: Offline Sonork: 100.107126 Thanks Meter: 80,766 | @ bitta24, What firmware you are trying to use for software testpoint operation? Also, post here full log file from an operation you are trying to perform, it would spread some light at your case. Best Regards GSMServer team |
11-05-2020, 16:45 | #3 (permalink) |
Member: 912802 Status: Offline Thanks Meter: 19 | SigmaKey 2.39.04b1 HiSi: Get device info Bootloader unlocked: NO FB unlocked: NO Battery voltage: 3.91 V Phone model: VOG-L29 Build number: VOG-L29 10.1.0.161(C431E23R2P5) Vendor/Country: hw/eea System version: Skipped Android version: 10 Base version: VOG-LGRP2-OVS 10.1.0.161 Custom version: VOG-L29-CUST 10.0.0.23(C431) Preload version: VOG-L29-PRELOAD 10.0.0.5(C431R2) Huawei-Over-the-Air info: C_version: C431 D_version: D000 PLMN: 23420 BoardID: 8559 DeviceName: VOG-L29 Done SigmaKey 2.39.04b1 HiSi: Software testpoint On.../Off DBAdapter Reserved Interface (COM243), Provider: HUAWEI Technologies CO.,LTD, Driver ver.: 1.0.26.0, Date: 18/05/2016, USB\Vid_12D1&Subclass_13&Prot_23 Using extended heuristic method... Hardware IMEI: 020304050607080 Flash file D:\VOGUE-L29C 10.1.0.150(C431E19R2P5)_Firmware_EMUI10.1.0_05015T HP\Software\dload\update_sd_base\UPDATE.APP Please send C:\Users\admin\Documents\SigmaKey\temporary backup\0766595829\VOG-LGRP2-OVS 10_1_0_1 (5).skb file to [email protected] Data retention error |
11-05-2020, 17:04 | #4 (permalink) |
Member: 121052 Status: Offline Sonork: 100.107126 Thanks Meter: 80,766 | @ bitta24, According to the provided data you are trying to use lower firmware version. Download same firmware version as your phone has or higher one and repeat operation once again. Best Regards GSMServer team |
11-05-2020, 19:42 | #5 (permalink) |
No Life Poster Join Date: Sep 2013 Location: Mongolia
Member: 2022955 Status: Offline Sonork: 100.1646687 Thanks Meter: 418 | Huawei P30 Pro VOG-L29 hw eea VOGUE-L29C 10.1.0.161(C431E23R2P5)_Firmware_EMUI10.1.0_05017B HV [androidhost.ru].zip https://androidhost.ru/1O2N Dated Uploaded: 05/11/2020 Filesize: 4.48 GB |
11-06-2020, 13:11 | #7 (permalink) |
Member: 912802 Status: Offline Thanks Meter: 19 | Still giving same error SigmaKey 2.39.04b1 HiSi: Software testpoint On.../Off DBAdapter Reserved Interface (COM243), Provider: HUAWEI Technologies CO.,LTD, Driver ver.: 1.0.26.0, Date: 18/05/2016, USB\Vid_12D1&Subclass_13&Prot_23 Using extended heuristic method... Hardware IMEI: 020304050607080 Flash file D:\VOGUE-L29C 10.1.0.161(C431E23R2P5)_Firmware_EMUI10.1.0_05017B HV\Software\dload\update_sd_base\UPDATE.APP Please send C:\Users\admin\Documents\SigmaKey\temporary backup\0766595829\VOG-LGRP2-OVS 10_1_0_1 (8).skb file to [email protected] Data retention error Any Phone with lower firmware are working fine, looks like all updates are getting tight. |
