05-01-2022, 07:44 | #1 (permalink) |
Junior Member Join Date: Apr 2022 Location: Germany Age: 34
Member: 3010458 Status: Offline Thanks Meter: 9 | P40 pro Flash Sigmakey i tried to downgrade my p40 pro to ealier version. I did the following: Flash OEM Info: OEM_INFO_Huawei_ELS-NX9_ELS-N29 10.1.0.114(C432E8) Flash Via Upgrade Mode: Elsa-N29D 10.1.0.176(C432E8R6P1) Firmware EMUI10.1.0 05016PSR Current Version is: Version: ELS-N29 12.0.0.228(C432E3) Here is device info: Battery voltage: 3.81 V Phone model: Skipped Build number: ELS-N29 12.0.0.228(C432E3) Vendor/Country: Skipped System version: Skipped Android version: 10 Base version: ELS-LGRP4-OVS 10.1.0.159 Custom version: ELS-N29-CUST 10.1.0.9(C185) Preload version: ELS-N29-PRELOAD 10.1.0.1(C185R6) Huawei-Over-the-Air info: C_version: C185 D_version: D000 PLMN: 65510 BoardID: 9592 Sigmakey sais that version doesnt fit, I tried with different oem version Flash filed but allways same result. what am i doing wrong? |
05-01-2022, 13:45 | #3 (permalink) |
Member: 3010458 Status: Offline Thanks Meter: 9 | Downgrade is needed in order to cleanly install google playservices. Actually it was a retail demo device. I need to flash oem info in order to be able to flash a ‚normal‘ version number (like c432). I did same procedure with a Huawei p20 recently and everything was fine. |
05-01-2022, 14:25 | #4 (permalink) |
No Life Poster Join Date: Jun 2011 Location: earth
Member: 1591394 Status: Offline Thanks Meter: 552 | its not need flash oeminfo, just fix country vendor thats it. first u can try flash downgrade stock by test point com1.0, if it new security it will not work anymore |
