08-22-2020, 14:58 | #16 (permalink) |
No Life Poster Join Date: Apr 2014 Location: istanbul
Member: 2171555 Status: Offline Thanks Meter: 129 | Bootloader unlocked: NO FB unlocked: NO Battery voltage: 3.68 V Phone model: POT-LX1 Build number: POT-LX1 10.0.0.229(C432E3R1P3) Vendor/Country: hw/eu System version: Skipped Android version: 10 Base version: POT-LGRP2-OVS 10.0.0.229 Custom version: POT-LX1-CUST 10.0.0.3(C432) Preload version: POT-L21-PRELOAD 10.0.0.3(C432R1) Huawei-Over-the-Air info: C_version: C121 D_version: D000 PLMN: 28601 BoardID: 7646 DeviceName: POT-L21 Done |
08-23-2020, 10:04 | #17 (permalink) | |
Freak Poster Join Date: Apr 2007 Location: algeria
Member: 481774 Status: Offline Sonork: [email protected] Thanks Meter: 174 | Quote:
https://drive.google.com/file/d/1Uh9...608kEE_RL/view | |
08-23-2020, 10:18 | #18 (permalink) |
No Life Poster Join Date: Jun 2011 Location: earth
Member: 1591394 Status: Offline Thanks Meter: 552 | Build number: POT-LX1 10.0.0.229(C432E3R1P3) download this stock and flash in fatsboot, if u dont mess with oem phone shopuld have working fastboot after flash this, also charge batery |
08-23-2020, 10:19 | #19 (permalink) | |
Member: 1591394 Status: Offline Thanks Meter: 552 | Quote:
and why board all can be solved by simply stock | |
08-24-2020, 07:22 | #20 (permalink) |
Junior Member Join Date: Jun 2016 Location: Ukraine
Member: 2585413 Status: Offline Thanks Meter: 0 | POT-LX1 Bricked program test point Включил програмный тестпоинт считал OEM считал зону безопасности Выключить програмный теспоинт уже не получается Мне нужно востановить телефон без потери информации SigmaKey 2.38.05 HiSi: Программный тестпоинт вкл.../выкл. HUAWEI USB COM 1.0 (COM3), Провайдер: HUAWEI Incorporated, Версия драйвера: 2.0.6.725, Дата: 05.12.2014, USB\VID_12D1&PID_3609&REV_0100 HiSilicon: Kirin 710 Модель телефона: POT-LX1 Версия: POT-LX1 10.0.0.229(C432E3R1P3) Проверка....Не найдено |
08-24-2020, 08:17 | #21 (permalink) |
Freak Poster Join Date: Dec 2007 Location: somewhere in KENYA
Member: 648607 Status: Offline Sonork: 100.1638674 Thanks Meter: 23 | connect testpoint click load fastboot flash stock rom with same build number no need of board firmware Thats how i unbricked my P30(ELE-L29) |
08-24-2020, 08:28 | #22 (permalink) |
Member: 2585413 Status: Offline Thanks Meter: 0 | После включения програмного тестпоинта отключить его не получается, я думаю что проблема в загрузчике на серверах сигмы. при прошивке прошивкой платы получаю звук приветсвия телефон определяется нормально но дисплей не работает. при прошивке прошивкой 9.*.*.*** телефон постоянно висит в ерекавери, обновления через ерекавери не находит, хард ресет не помогает. при прошивке прошивкой 10.*.*.*** получаю ошибку verification failed красная надпись на черном фоне. |
08-24-2020, 08:32 | #23 (permalink) | |
Member: 2171555 Status: Offline Thanks Meter: 129 | Quote:
guys my problem is solved. The device I have got some water. you can lock the subject. | |
08-24-2020, 08:47 | #24 (permalink) | |
Member: 2585413 Status: Offline Thanks Meter: 0 | POT-LX1 Bricked program test point Quote:
Я одолжил такойже апарат включил програмный тестпоинт скалал с него OEM info и IMEI для проверки на первом апарате и отключил програмный тестпоинт и получил ошибку, мне нужно его востановить без потери. | |
08-24-2020, 11:07 | #25 (permalink) | |
Congratulations to slove this problem Most of the problems are in Huawei phones hang in logo in Carte Board Charge or flex | |
08-24-2020, 14:48 | #26 (permalink) |
Product Supporter Join Date: Feb 2005 Location: GSMserver Team
Member: 121052 Status: Offline Sonork: 100.107126 Thanks Meter: 80,766 | @ rywbm, Post here full log files from the operations you have performed to this phone, along with the firmware files you have used for the flashing purposes. Current case will be deeply analyzed by product developers. Best Regards GSMServer team |
08-24-2020, 15:58 | #27 (permalink) |
Member: 2585413 Status: Offline Thanks Meter: 0 | подключил телефон в режиме usb update и включил программный тестпоинт (update файл взял из прошивки fullota POT-LX1 10.0.0.229 C432) мой телефон: Модель телефона: POT-LX1 Версия: POT-LX1 10.0.0.229(C432E3R1P3) потом сделал Чтение OEM и Чтение защищенных данных после чтения информации, телефон был в режиме adb Я перезагрузил 3 кнопками телефон определился как HUAWEI USB COM 1.0 после я нажал выключить программный тестпоинт, и получил: --------- 2020-08-23 23:44:51 --------- SigmaKey 2.38.05 HiSi: Программный тестпоинт вкл.../выкл. HUAWEI USB COM 1.0 (COM3), Провайдер: HUAWEI Incorporated, Версия драйвера: 2.0.6.725, Дата: 05.12.2014, USB\VID_12D1&PID_3609&REV_0100 HiSilicon: Kirin 710 Модель телефона: POT-LX1 Версия: POT-LX1 10.0.0.229(C432E3R1P3) Проверка....Не найдено |
08-24-2020, 21:11 | #28 (permalink) |
Member: 2585413 Status: Offline Thanks Meter: 0 | востановил апараты при помощи mrt но не могу востановить имеі на первом апарате, у меня был в наличии бекап только от второго и сейчас на первом тот имеи что и на втором. помогите пожалуйста востановить имеи на первом апарате вот их нужно залить в апарат POT-LX1 10.0.0.197(C432E3R1P3) SN: 39V7N19509000240 hw/eu IMEI1: 868828042****** IMEI2: 868828042****** Last edited by rywbm; 08-24-2020 at 21:19. |
12-20-2020, 19:30 | #29 (permalink) |
Member: 2585413 Status: Offline Thanks Meter: 0 | Connecting.... Android Adapter PCUI (COM42), Provider: HUAWEI Technologies CO.,LTD, Driver ver.: 1.0.26.0, Date: 18.05.2016, USB\Vid_12D1&Subclass_13&Prot_22 ....Baseband Processor: Missing response from phone |
