![]() | #61 (permalink) |
Freak Poster ![]() ![]() ![]() ![]() Join Date: Jan 2018 Location: Dar es salaam, Tanzania
Member: 2804958 Status: Offline Thanks Meter: 91 ![]() | Reading info.....OK Device Model: KOZ-AL00 Device Firmware: KOZ-AL00 4.0.0.225(C00E40R1P16) Base Firmware: :KOZ-LGRP1-CHN 4.0.0.225 Custom Firmware: :KOZ-AL00-CUST 4.0.0.40(C00) Preload Firmware: :KOZ-AL00-PRELOAD 4.0.0.16(C00R1) Device FB Lock: LOCKED Device USER Lock: LOCKED Device Lock: INFO locked Operation {Read info} ID: 111CB3C4EE883F70 Elapsed time 00:01 -- Version 4.7.2 Build 001 ad solution for this devices pls |
![]() | #62 (permalink) |
Product Supporter ![]() ![]() ![]() Join Date: Feb 2003 Location: gsmserver
Member: 21077 Status: Offline Thanks Meter: 117,322 | KOZ-AL00 runs on the Unisoc Tiger T610 chipset. To perform service operations, you can follow the manual provided in this manual and select the necessary T610 Universal Loader from the drop-down list. |
![]() | #63 (permalink) |
Member: 2804958 Status: Offline Thanks Meter: 91 ![]() | Checking fastboot device.....OK Reading info.....OK Device Model: KOZ-AL00 Device Firmware: KOZ-AL00 4.0.0.225(C00E40R1P16) Base Firmware: :KOZ-LGRP1-CHN 4.0.0.225 Custom Firmware: :KOZ-AL00-CUST 4.0.0.40(C00) Preload Firmware: :KOZ-AL00-PRELOAD 4.0.0.16(C00R1) Device FB Lock: LOCKED Device USER Lock: LOCKED Device Lock: INFO locked Operation {Read info} ID: 111CB3C4EE883F70 Elapsed time 00:01 -- Version 4.7.2 Build 001 ad solution for this devices pls |
![]() | #64 (permalink) | |
Member: 2804958 Status: Offline Thanks Meter: 91 ![]() | Quote:
Device have Huawei ID and Sigma support only frp | |
![]() | #65 (permalink) |
Member: 2804958 Status: Offline Thanks Meter: 91 ![]() | SigmaPlus v.1.00.03 build 01 168089633 Sigma+ dongle 3.00, Initializing...OK --------- 2024-04-15 04:43:12 --------- SigmaPlus 1.00.03b1 Sprd: Remove FRP / Huawei ID Model: (UNISOC) Tiger T610 64Bit Getting info...Error writing to serial port Here's logs when i use unisoc t610 |
![]() | #66 (permalink) |
Member: 2804958 Status: Offline Thanks Meter: 91 ![]() | Bootloader unlocked: NO FB unlocked: NO Battery voltage: 4.11 V Phone model: ANA-AN00 Build number: ANA-AN00 3.0.0.208(C00E191R3P8) Vendor/Country: all/cn System version: Skipped Android version: 12 Base version: ANA-LGRP3-CHN 103.0.0.208 Custom version: ANA-AN00-CUST 103.0.0.191(C00) Preload version: ANA-AN00-PRELOAD 103.0.0.8(C00R3) Huawei-Over-the-Air info: C_version: C00 D_version: D000 PLMN: 46000 BoardID: 9582 DeviceName: ANA-AN00 Done Device have huawei ID, everything go correctly but HUAWEI ID still active |
![]() | #68 (permalink) | |
Final i do my own solution to rebrand device to ANA-N29 and pass but device loose OEM INFO Remember i'm not beginner, i'm expert on HUAWEI DEVICES | |
The Following User Says Thank You to Agapito86 For This Useful Post: |
![]() | #69 (permalink) | |
Member: 21077 Status: Offline Thanks Meter: 117,322 | Quote:
![]() | #70 (permalink) | |
Freak Poster ![]() ![]() ![]() ![]() Join Date: Jan 2018 Location: Philippines
Member: 2798247 Status: Offline Thanks Meter: 31 | Quote:
youve lost the reputation you had team for no update there so many concern in this box now seems you cant addres it all user youv had will be gone like weve lost all our pack weve paid | |
The Following User Says Thank You to chezzter ash For This Useful Post: |
![]() | #71 (permalink) | |
And what about HUAWEI EVE-LX9 HUAWEI ID & FRP REMOVE | |
![]() | #73 (permalink) |
Member: 2798247 Status: Offline Thanks Meter: 31 | To the sigma team whats yourplan of update does your user can take update or no long time no real update youve been in industry a long time now your silince is killing the tools |
![]() | #74 (permalink) |
Member: 2804958 Status: Offline Thanks Meter: 91 ![]() | SigmaPlus v.1.00.03 build 01 168089633 Sigma+ dongle 3.00, Initializing...OK --------- 2024-06-04 17:26:43 --------- SigmaPlus 1.00.03b1 HiSi: Get device info Bootloader unlocked: NO FB unlocked: NO Battery voltage: 4.15 V Phone model: EBG-AN10 Build number: EBG-AN10 2.0.0.168(C00E160R6P6) Vendor/Country: all/cn System version: Skipped Android version: 10 Base version: EBG-LGRP1-CHN 102.0.0.168 Custom version: EBG-AN10-CUST 102.0.0.160(C00) Preload version: EBG-AN10-PRELOAD 102.0.0.6(C00R6) Huawei-Over-the-Air info: C_version: C00 D_version: D000 PLMN: 64004 BoardID: 9869 DeviceName: EBG-AN10 Done Unable to connect to the server. Please check your network. --------- 2024-06-04 17:37:20 --------- SigmaPlus 1.00.03b1 HiSi: Remove Huawei ID HUAWEI USB COM 1.0 (COM130), Provider: HUAWEI Incorporated, Driver ver.: 2.0.6.725, Date: 10/08/2014, USB\VID_12D1&PID_3609&REV_0100 The battery must be connected to the phone's board and fully charged. [YES] HiSilicon: P40/P40Pro 5G (boot 2) Sending boot...Error writing to serial port --------- 2024-06-04 17:43:17 --------- SigmaPlus 1.00.03b1 HiSi: Remove Huawei ID HUAWEI USB COM 1.0 (COM130), Provider: HUAWEI Incorporated, Driver ver.: 2.0.6.725, Date: 10/08/2014, USB\VID_12D1&PID_3609&REV_0100 The battery must be connected to the phone's board and fully charged. [YES] HiSilicon: Kirin 990 5G Sending boot...Error writing to serial port --------- 2024-06-04 17:46:25 --------- SigmaPlus 1.00.03b1 HiSi: Remove Huawei ID HUAWEI USB COM 1.0 (COM130), Provider: HUAWEI Incorporated, Driver ver.: 2.0.6.725, Date: 10/08/2014, USB\VID_12D1&PID_3609&REV_0100 The battery must be connected to the phone's board and fully charged. [YES] HiSilicon: Kirin 990 Sending boot....Error writing to serial port --------- 2024-06-04 17:49:04 --------- SigmaPlus 1.00.03b1 HiSi: Remove Huawei ID HUAWEI USB COM 1.0 (COM130), Provider: HUAWEI Incorporated, Driver ver.: 2.0.6.725, Date: 10/08/2014, USB\VID_12D1&PID_3609&REV_0100 The battery must be connected to the phone's board and fully charged. [YES] HiSilicon: Kirin 990 E Sending boot...Error writing to serial port UPDATE FOR HUAWEI AND HONOR PLS!!! |
![]() | #75 (permalink) |
Member: 2804958 Status: Offline Thanks Meter: 91 ![]() | SigmaPlus 1.00.03b1 HiSi: Remove Huawei ID HUAWEI USB COM 1.0 (COM131), Provider: HUAWEI Incorporated, Driver ver.: 2.0.6.725, Date: 10/08/2014, USB\VID_12D1&PID_3609&REV_0100 The battery must be connected to the phone's board and fully charged. [YES] HiSilicon: Kirin 820/985 Phone model: TEL-AN00 Version: TEL-AN00 2.0.0.270(C00E230R8P5) SN: BPHVB20B19002770 OEM Info IMEI1: 862957044959599 OEM Info IMEI2: 862957044990396 MEID: A00000BE706E28 Phone model: TEL-AN00 Build number: TEL-AN00 2.0.0.270(C00E230R8P5) Security area saved to "C:\Users\agapi\OneDrive\Documents\SigmaPlus\secur ity backup\0168089633\862957044959599_862957044990396_ Huawei_TEL-AN00_TEL-AN00 2_0_0_270(C00E230R8P5).skb" This phone has a specific firmware version. If Huawei ID will still persist, read the manual on the official website for additional steps to be performed. Huawei ID is not installed. Removing Huawei ID...Skipped THI IS BULLSHIIT, DEVICE HAVE HUAWEI ID BUT SIGMA DIDN'T SEE IT!!! |
