01-02-2014, 18:50 | #1 (permalink) | |
No Life Poster Join Date: Nov 2008 Location: ¡¡InFiNiTy CM2 For EvER!!
Member: 901711 Status: Offline Sonork: 100.1606138 Thanks Meter: 427 | ★★ ORINOQUIA U5120-53 [HUAWEI U5120] DIRECT UNLOCK [Sigma Team] ★★ HUAWEI U5120 DIRECT UNLOCK PHONE FROM MOVILNET - VENEZUELA Quote:
GOOOOD!!!!!!!! >>MaO<< KrazY_LaB | |
The Following 3 Users Say Thank You to maomatrix For This Useful Post: |
01-04-2014, 22:22 | #3 (permalink) |
Junior Member Join Date: Jun 2013 Age: 42
Member: 1968886 Status: Offline Thanks Meter: 8 | hola el procedimiento ami parecer por el log que muestra es poner el equipo en modo ¨debug ¨primero. para que te reconosca el puerto com.. 1.- enciendes el equipo sin chip y presionas ¨sos¨ 2.- marcas ##497613 y tecla ¨verde ¨(send)de llamadas 3.- seleccionas ¨debug¨ 4.- selecciona ¨diag debug¨ 5.- selecciona ¨on¨ el equipo se reinicia y asi podra reconocer puerto com...ahora seleccionas modelo de manera manual y probar. comenta resultados.. saludos |
The Following User Says Thank You to apunegro For This Useful Post: |
01-05-2014, 19:12 | #4 (permalink) |
Member: 901711 Status: Offline Sonork: 100.1606138 Thanks Meter: 427 | @FABICEL... its Easy... 1. Plug USB cable in PHONE..((CPU detect phone and isntall some drivers)) 2. After this detection.. unplug USB cable and insert again.. ((phone in power on all time)) 3. Go to windows and open devices.. See your phone and doble click...The system install the correct drivers and phone be detectect in COM MODE... you can select them... 4. Continue to correct process and finish.... |
01-06-2014, 07:57 | #5 (permalink) |
Product Supporter Join Date: Feb 2005 Location: GSMserver Team
Member: 121052 Status: Offline Sonork: 100.107126 Thanks Meter: 80,766 | @ apunegro, You can check detailed, step-by-step, unlock manual for U5120 and other supported Qualcomm based Huawei handsets by following this link. Best Regards GSMServer team Last edited by Gsmserver; 01-25-2018 at 14:58. |
The Following User Says Thank You to GSM_Support For This Useful Post: |
01-10-2014, 04:24 | #9 (permalink) |
Member: 901711 Status: Offline Sonork: 100.1606138 Thanks Meter: 427 | STEP BY STEP UNLOCK ORINOQUIA U5120 It`s EASY..... 1. 2. 3. 4. UNLOCKED IN WIN7 ONLY............. >>mAo<< |
The Following 2 Users Say Thank You to maomatrix For This Useful Post: |
09-04-2014, 00:00 | #10 (permalink) |
No Life Poster Join Date: Jul 2008 Location: ESPAÑA
Member: 808967 Status: Offline Thanks Meter: 155 | --- 2014-09-03 17:59:03 --- SigmaKey 2.05.00 Qcom: Liberación directa ORINOQUIA FP Handset - Application Interface (COM161), Proveedor:: ORINOQUIA Incorporated, Versión de drivers:: 2.0.6.7, Fecha: 04/01/2012, USB\Vid_12d1&Pid_1810&Rev_0000&MI_01 Error B7D10451:221A |
01-08-2015, 20:13 | #13 (permalink) |
Member: 121052 Status: Offline Sonork: 100.107126 Thanks Meter: 80,766 | @ james cb, Write posts in English, please. Otherwise your post will be deleted next time. Best Regards GSMServer team |
