07-02-2020, 18:21 | #32 (permalink) |
No Life Poster Join Date: Mar 2006 Location: Central Europe Age: 39
Member: 239548 Status: Offline Thanks Meter: 2,781 | Ab1009, you can use this file. Read the manual first! It is described in it. The customization doesn't matter. |
The Following User Says Thank You to mcandre For This Useful Post: |
07-02-2020, 18:38 | #33 (permalink) | |
Freak Poster Join Date: Feb 2013 Location: Polska
Member: 1881160 Status: Offline Thanks Meter: 31 | Quote:
I have the same problem, there is no error when loading the software, I have already tested on many boxes, I think it is Huawei security, oeminfo checksum or something like that | |
07-02-2020, 20:28 | #37 (permalink) |
Member: 1881160 Status: Offline Thanks Meter: 31 | After uploading the copy of oeminfo there are errors with the seller reading it comes, on all models with Kirin 980, uploading system files does not help, restoring the data and cache settings also does not help Problem Model -> Vendor > Country Code: Vendor/Country: Skipped System version: Skipped Code: --------- 2020-07-02 21:16:47 --------- SigmaKey 2.36.01 HiSi: Write OEM Info... HUAWEI USB COM 1.0 (COM57), Provider: Huawei Incorporated, Driver ver.: 2.0.6.725, Date: 08.04.2015, USB\VID_12D1&PID_3609&REV_0100 HiSilicon: Kirin 980 Version: LYA-L29 9.0.0.171(C461E10) Writing data...Done --------- 2020-07-02 21:19:13 --------- SigmaKey 2.36.01 HiSi: Get device info IMEI1: 86166904407xxxx IMEI2: 86166904407xxxx MEID: A000009CBxxxx Bootloader unlocked: YES FB unlocked: YES Battery voltage: 3.80 V Phone model: LYA-L29 Build number: LYA-L29 9.1.0.346(C432E10R1P16) Vendor/Country: Skipped System version: Skipped Android version: 9 Base version: LYA-LGRP2-OVS 9.1.0.346 Custom version: LYA-L29-CUST 9.0.0.10(C432) Preload version: LYA-L29-PRELOAD 9.0.0.16(C432R1) Huawei-Over-the-Air info: C_version: C432 D_version: D000 PLMN: 24201 BoardID: 8426 Done |
07-02-2020, 22:58 | #41 (permalink) | |
Product Supporter Join Date: Feb 2003 Location: gsmserver
Member: 21077 Status: Offline Thanks Meter: 116,131 | Quote:
The Following User Says Thank You to Gsmserver For This Useful Post: |
