10-23-2021, 10:11 | #31 (permalink) |
Freak Poster Join Date: Sep 2017 Location: Rawalpindi
Member: 2755459 Status: Offline Thanks Meter: 46 | FB unlocked: NO Battery voltage: 4.00 V Phone model: JNY-LX1 Build number: JNY-L21 10.1.0.350(C185E5R3P1) Vendor/Country: hw/meafnaf System version: Skipped Android version: 10 Base version: JNY-LGRP2-OVS 10.1.0.350 Custom version: JNY-L21-CUST 10.1.0.5(C185) Preload version: JNY-L21-PRELOAD 10.0.1.1(C185R3) Huawei-Over-the-Air info: C_version: C185 D_version: D000 PLMN: 42004 BoardID: 1940 DeviceName: JNY-L21 Done can i use test point on this modle or i need modified cable for it?? |
10-23-2021, 10:26 | #32 (permalink) | |
No Life Poster Join Date: May 2013 Location: Far From Home..:(
Member: 1948608 Status: Offline Thanks Meter: 1,744 | Quote:
use Modified cable, normal TP not working wit this Build. | |
10-23-2021, 17:23 | #35 (permalink) |
Junior Member Join Date: Jun 2016 Location: Georgia
Member: 2590969 Status: Offline Thanks Meter: 29 | As said upper, Factory Reset Function will be very helpful, without entering recovery menu manually |
The Following User Says Thank You to greggh For This Useful Post: |
10-25-2021, 08:02 | #40 (permalink) | |
Product Supporter Join Date: Feb 2003 Location: gsmserver
Member: 21077 Status: Offline Thanks Meter: 116,337 | Quote:
The Following User Says Thank You to Gsmserver For This Useful Post: |
10-25-2021, 11:52 | #42 (permalink) |
Major Poster Join Date: Jul 2021 Location: China
Member: 2992628 Status: Offline Thanks Meter: 5 | Nova8 in February 2021 (ANG-AN00), Nova8Pro in April 2021 (BRQ-AN00), Nova8Pro in February 2021 (BRQ-AN00), Nova8Pro in March 2021 (BRQ-AN00), 2021 P40Pro (ELS-AN00) in January, Mate40E (OCE-AN50) in April 2021, etc., can not complete the "load FastBoot"! |
10-25-2021, 11:57 | #43 (permalink) |
Member: 2992628 Status: Offline Thanks Meter: 5 | The main manifestation is that when writing the first file, the progress bar is stuck at 90%, and then it prompts "Failed to write to the port". In the IDT tool, the factory file can be written! |
10-25-2021, 13:59 | #44 (permalink) | ||
We have just tested load fastboot service operation using our modified USB cable Quote:
10-26-2021, 04:39 | #45 (permalink) | |
Member: 2992628 Status: Offline Thanks Meter: 5 | Quote:
The Following User Says Thank You to awsaxf For This Useful Post: |
