02-23-2021, 01:43 | #186 (permalink) |
Junior Member Join Date: May 2019 Location: Douala
Member: 2909085 Status: Offline Thanks Meter: 3 | Fake imei The certificate written with sigma is useless then after reading the info it is always the old imei which appears sigma should make an update to remedy this |
02-23-2021, 08:21 | #187 (permalink) |
Product Supporter Join Date: Feb 2005 Location: GSMserver Team
Member: 121052 Status: Offline Sonork: 100.107126 Thanks Meter: 80,766 | @ abdoullaye1997, IMEI number that is written the certificate is getting send to the network, even if software shows an old IMEI number. Sigma reads the original IMEI that was in the phone, because original IMEI stores in the phone. Best Regards GSMServer team Last edited by Gsmserver; 02-23-2021 at 09:37. |
04-08-2021, 18:50 | #188 (permalink) |
Junior Member Join Date: Nov 2015 Location: poland
Member: 2494126 Status: Offline Thanks Meter: 3 | Does the Software TP require you to enable "debug mode" inside Android or can the "EDL-mode" (TP) be accessed from e.g. a powered off device (e.g. similarly to shorting TP after disassembling the device)? With other words, do I need to unlock Android (pin/pw/pattern) on the device in order to get to EDL-mode? |
04-08-2021, 19:04 | #189 (permalink) |
Member: 2494126 Status: Offline Thanks Meter: 3 | Nevermind, found the answer on your webpage: https://sigmakey.com/en/supportedfea...?phone_id=5816 |
The Following User Says Thank You to sepulchral For This Useful Post: |
04-26-2021, 13:39 | #191 (permalink) | |
Product Supporter Join Date: Feb 2003 Location: gsmserver
Member: 21077 Status: Online Thanks Meter: 116,340 | Quote:
Huawei Edition + PowerPack gives you 3000 authorizations per month. If you need more, you can buy Counter reset pack. | |
04-27-2021, 03:21 | #192 (permalink) |
Junior Member Join Date: Jan 2015
Member: 2328238 Status: Offline Thanks Meter: 0 | I have huawei edition with power pack but i cannot find anywhere (Enable secure data (certificate) ) can you please explain where can i find that option or where can i find shared cert by other box |
04-27-2021, 08:06 | #193 (permalink) |
Member: 121052 Status: Offline Sonork: 100.107126 Thanks Meter: 80,766 | @ myjunaid, Read/Write Huawei certificate operation allows to restore IMEI number that is stored in the certificate file. Users with pack 3+4+5 (Huawei Power Pack) can share their certificate files and use certificate files read by other boxes. You can as other users to share their certificate files. More detailed manual on the Read/Write Huawei certificate operation can be found by this link. Best Regards GSMServer team |
