Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > GSMServer Products > SigmaKey
Old 08-10-2020, 12:47   #5476 (permalink)
Member: 1713864
unlock frp DUB-LX1 test point
--------- 2020-08-10 16:12:26 ---------
SigmaKey 2.35.00 Qcom: Remove FRP / Huawei ID
Phone model: Y7 2019 (DUB-LX1)
Getting info...65001500E1A00900-6BC369511DA9CADB3A7AF61574F89DB385003D6241BDD1FF57 3DBA61BF6AE119-00000000
Serial number: 4287773935
Baseband Processor: 8953
Detecting flash...eMMC
Removing FRP lock....Done
Old 08-11-2020, 09:16   #5477 (permalink)
dr_moosavi's Avatar
Member: 814775
Sonork: 100.1587334
Thanks Meter: 973
P10 lite Successful Unlock done
P10 lite Unlock sucessfull done
--------- 2020-08-11 12:19:15 ---------
SigmaKey 2.38.02 HiSi: Direct unlock
Android Adapter PCUI (COM134), Provider: HUAWEI Technologies CO.,LTD, Driver ver.: 1.0.26.0, Date: 5/18/2016, USB\Vid_12D1&Subclass_13&Prot_22
Connecting....
Testing external RAM...4 Gb
Detecting flash...eMMC, Flash size: 32 Gb
Firmware: NRD90M test-keys, Date: Thu Apr 13 14:54:20 CST 2017, Provider: hw/meafnaf
Boot Version: Dallas-Trunk_BOOT, FastBoot Version: Chipset-dallas 5.1.0.1(04PU)_FASTBOOT
Recovery Version: (unknow), System Version: System 5.1.0.63(0GO0)
Getting info....
Removing firmware protection...Skipped
Software IMEI1: 866148037277340
Software IMEI2: 866148037302353
Unlocking phone...Done
Restarting phone...Done
Old 08-11-2020, 17:08   #5478 (permalink)
dr_moosavi's Avatar
Member: 814775
Sonork: 100.1587334
Thanks Meter: 973
Honor 4X Che2-L11 Bricked Fixed
--------- 2020-08-11 20:27:15 ---------
SigmaKey 2.38.02 HiSi: Write firmware
Wrong selection of firmware files can damage the phone.
Are you sure you want to proceed? [YES]
Flash file C:\Users\PADIDE117\Desktop\Honor 4X_Che2-L11_Firmware_Andriod 6.0_EMUI4.0_C185B505_Iraq_Algeria_Egypt_Jordan_Lebanon_Morocco_Tunisia_Channel-Others\dload\UPDATE.APP
Phone model: Che2-L11
Version: Che2-L11 V100R001C636B070
Writing flash modemimage...OK
Writing flash modemnvm1.0...OK
Writing flash mcuimage...OK
Writing flash hifi...OK
Writing flash dsp...OK
Writing flash dtimage...OK
Writing flash teeos...OK
Writing flash trustfirmware...OK
Writing flash securetystorage.0...OK
Writing flash nvme...OK
Writing flash fastboot1...OK
Writing flash fastboot...OK
Writing flash recovery...OK
Writing flash recovery2...OK
Writing flash boot...OK
Writing flash system.0...OK
Writing flash system.1...OK
Writing flash system.2...OK
Writing flash system.3...OK
Writing flash system.4...OK
Writing flash system.5...OK
Writing flash cache.0...OK
Writing flash cust.0...OK
Writing flash userdata.0...OK
Writing flash...Done
Old 08-12-2020, 14:20   #5479 (permalink)
Member: 4627
Sonork: 57528:debeliamark
Thanks Meter: 1,034
Huawei Mate 20 latest 10.1.0.270 service - FRP and OEM
This phone can't be downgraded to any 10.0.x.xxx or earlier version (without to open it) - do not tested only with MRToKey. SigmaKey itself cannot downgrade it [HMA-L09CA_10.0.0_C432.skf is incompatible] also.
I wasn't find a full flash HMA-L29 10.1.0.270(C432E8R1P5) and use via easy-firmware_dot_com 10.1.0.273(C185E5R2P4) to extract the main version update.app. In fact - it's working [ fast SW testpoint / enable diagnostic mode / unlocked Bootloader ] using it and go back to working phone:
--------- 2020-08-12 16:01:11 ---------
SigmaKey 2.38.04b1 HiSi: Software testpoint On.../Off
DBAdapter Reserved Interface (COM121), Provider: HUAWEI Technologies CO.,LTD, Driver ver.: 1.0.26.0, Date: 18.5.2016 ã., USB\Vid_12D1&Subclass_13&Prot_23
Using extended heuristic method...
Hardware IMEI: 020304050607080
Flash file ...\Huawei\HMA-L29\Hima-L29C 10.1.0.273(C185E5R2P4)_Firmware_EMUI10.1.0_05015KJU\Software\dload\UPDATE.APP
Enabling diagnostic port...Done
We strictly recommend performing "Enable Downgrade" on "Flash" tab, as the first service operation on this device!
--------- 2020-08-12 16:02:03 ---------
SigmaKey 2.38.04b1 HiSi: Read OEM Info...
HUAWEI USB COM 1.0 (COM44), Provider: Huawei Incorporated, Driver ver.: 2.0.6.725, Date: 8.4.2015 ã., USB\VID_12D1&PID_3609&REV_0100
HiSilicon: Kirin 980
Phone model: HMA-L29
Version: HMA-L29 10.1.0.270(C432E8R1P5)
SN: MUN02189280xxxx7
IMEI1: 8694250315xxxx2
IMEI2: 8694250315xxxx2
MEID: A000009B2CF341
Build number: HMA-L29 10.1.0.270(C432E8R1P5)
Reading data...Done
--------- 2020-08-12 16:03:59 ---------
SigmaKey 2.38.04b1 HiSi: Get device info
Bootloader unlocked: YES
FB unlocked: YES
Battery voltage: -
Vendor/Country: hw/eu
System version: Skipped
Android version: 10
Base version: HMA-LGRP2-OVS 10.1.0.270
Custom version: HMA-L29-CUST 10.0.0.8(C432)
Preload version: HMA-L29-PRELOAD 10.0.0.5(C432R1)
Huawei-Over-the-Air info:
	C_version: C432
	D_version: D000
	PLMN: 28405
	BoardID: 8413
	DeviceName: HMA-L29
Done
--------- 2020-08-12 16:04:15 ---------
SigmaKey 2.38.04b1 HiSi: Remove FRP / Huawei ID
Removing Huawei ID....Done
Removing FRP lock...Done
Restarting phone...OK
--------- 2020-08-12 16:04:50 ---------
This operation may brick the phone if the phone firmware version does not EXACTLY match the software testpoint firmware version!
If you are unsure, better completely reflash the firmware. Are you sure you want to proceed? [YES]
Repairing.........Done
Tnx for SigmaKey HiSi solution. Keep hard working.
WBR, DebeliaMark, BG
Old 08-12-2020, 14:20   #5480 (permalink)
Member: 4627
Thanks Meter: 1,034
Reading data...Done
FB unlocked: YES
Battery voltage: -
Android version: 10
	C_version: C432
	D_version: D000
	PLMN: 28405
	BoardID: 8413
	DeviceName: HMA-L29
Done
Old 08-15-2020, 13:55   #5481 (permalink)
Dilip_Nath's Avatar
Member: 387110
Sonork: Not Use
Thanks Meter: 630
Huawei STK-L21 FRP unlock
SigmaKey v.2.38.05
49700xxxx Sigma dongle 2.38, Initializing...OK
Pack 1: Activated
Pack 2: Activated
Pack 3: Activated
Pack 4: Activated
--------- 2020-08-15 18:49:03 ---------
SigmaKey 2.38.05 HiSi: Remove FRP / Huawei ID
HUAWEI USB COM 1.0 (COM23), Provider: HUAWEI Incorporated, Driver ver.: 2.0.6.725, Date: 11/6/2015, USB\VID_12D1&PID_3609&REV_0100
Cancelled
--------- 2020-08-15 18:50:20 ---------
HiSilicon: Kirin 710
Phone model: STK-L21
Version: STK-L21M 9.0.1.155(C185E8R2P1)
Old 08-15-2020, 15:02   #5482 (permalink)
Member: 1713864
Thumbs up unlock frp Honor 8S KSA-LX9 test point
unlock frp Honor 8S KSA-LX9 MTK test point
--------- 2020-08-15 18:14:00 ---------
SigmaKey 2.35.00 MTK: Remove FRP (Huawei KSA-LX9)
Baseband Processor:MT6761, HW Rev. A.01, SW Rev. 2.00
Testing external RAM...DRAM, 2 Gb
Detecting flash...eMMC, Flash size: 29.14 Gb
Software IMEI1: 86758904000000
Software IMEI2: 86758904000000
Security area saved to "C:\Users\MobileRoya\Documents\SigmaKey\securi ty backup\0637620275\867589000000_Huawei KSA-LX9.skb"
.Done
Old 08-16-2020, 17:41   #5483 (permalink)
genci titi 2002's Avatar
Member: 193804
Sonork: 100.1684818
Thanks Meter: 1,690
Wink
--------- 2020-08-16 18:35:34 ---------
SigmaKey 2.37.00b3 MTK: Remove FRP (Huawei MRD-LX1)
Software IMEI1: 861683040619059
Software IMEI2: 861683040659063
Security area saved to "C:\Users\Geti\Documents\SigmaKey\security backup\0467689932\861683040619059_Huawei MRD-LX1.skb"
.Done
Old 08-17-2020, 05:30   #5484 (permalink)
Member: 2266108
HUAWEI USB COM 1.0 (COM75), Proveedor:: HUAWEI Incorporated, Versión de drivers:: 2.0.6.725, Fecha: 05/11/2015, USB\VID_12D1&PID_3609&REV_0100
HiSilicon: Kirin 65x
Modelo del teléfono: RNE-L03
Versión: RNE-L03 8.0.0.344(C69)
SN: V3XDU1830xxxxxx
IMEI1: 866200000069302
IMEI2: 866225030000302
MEID: 00000000000000
Build number: RNE-L03 8.0.0.344(C69)
Leyendo bloque de seguridad......Archivo incorrecto ""
why?
Old 08-18-2020, 08:57   #5485 (permalink)
Dilip_Nath's Avatar
Member: 387110
Sonork: Not Use
Thanks Meter: 630
Huawei LDN-LX2 FRP unlock
SigmaKey v.2.38.05
Pack 1: Activated
Pack 2: Activated
Pack 3: Activated
Pack 4: Activated
--------- 2020-08-18 13:52:50 ---------
SigmaKey 2.38.05 Qcom: Remove FRP / Huawei ID
^ Android Bootloader Interface, Version 0.5, Name: QC_REFERENCE_PHONE, Serial number: JYNBB18514156306
Phone model: LDN-LX2
Version: LDN-LX2 8.0.0.163(C636)
Old 08-18-2020, 09:20   #5486 (permalink)
Gsmserver's Avatar
Member: 21077
Thanks Meter: 116,274
why?
Security block on your phone is damaged, so Sigma can not read it from your phone. So, the operation is stopped at this point.
Old 08-18-2020, 15:16   #5487 (permalink)
Dilip_Nath's Avatar
Member: 387110
Sonork: Not Use
Thanks Meter: 630
Huawei POT-LX1AF FRP unlock done
SigmaKey v.2.38.05
Pack 1: Activated
Pack 2: Activated
Pack 3: Activated
Pack 4: Activated
--------- 2020-08-18 19:57:30 ---------
HUAWEI USB COM 1.0 (COM11), Provider: HUAWEI Incorporated, Driver ver.: 2.0.6.725, Date: 11/6/2015, USB\VID_12D1&PID_3609&REV_0100
Phone model: POT-LX1AF
Version: POT-LX1AF 9.1.0.317(C185E8R1P11)
Old 08-19-2020, 14:49   #5488 (permalink)
Member: 216446
Thanks Meter: 220
huawei g620s-L01 unlock success
SigmaKey v.2.38.02
New version 2.38.05 is available on www.sigmakey.com. We strongly recommend to update SigmaKey!
201607041 Sigma dongle 2.38, Initializing...OK
Pack 1: Activated
Pack 2: Activated
Pack 3: Activated
Pack 4: Activated
--------- 2020-08-19 14:45:24 ---------
SigmaKey 2.38.02 ADB: Direct unlock
* daemon not running. starting it now *
* daemon started successfully *
^ Android Adapter ADB Interface
Version: Linux version 3.10.28-g6b49849 (jenkins@wuhcitculx00284) (gcc version 4.7 (GCC) ) #1 SMP PREEMPT Tue Mar 17 15:03:06 CST 2015
Phone model: HUAWEI G620S-L01
Android 4.4.4; Firmware: HuaweiG620S-L01; Date: Tue Mar 17 14:41:40 CST 2015
Version: G620S-L01V100R001C00B256
Baseband Firmware: 11060009
Baseband Processor: Qualcomm Technologies, Inc MSM8916
Security area saved to "C:\Users\ETRONICS\Documents\SigmaKey\security backup\0201607041\HUAWEI_G620S-L01_HuaweiG620S-L01_Tue Mar 17 144140 CST 2015.skb"
Old 08-22-2020, 13:06   #5489 (permalink)
Member: 2466919
Thanks Meter: 5
HRY-L21 oeminfo chaned and official flashing
SigmaKey v.2.38.05
966618436 Sigma dongle 2.38, Initializing...OK
Huawei Edition
PowerPack: Activated
--------- 2020-08-22 16:22:55 ---------
SigmaKey 2.38.05 HiSi: Read secure data...
HUAWEI USB COM 1.0 (COM63), Provider: HUAWEI Incorporated, Driver ver.: 2.0.6.725, Date: 10/08/2014, USB\VID_12D1&PID_3609&REV_0100
Version: HRY-BD 1.0.0.60
Build number: HRY-BD 1.0.0.60
Reading security block......Inconsistent file ""
--------- 2020-08-22 16:27:18 ---------
SigmaKey 2.38.05 HiSi: Repair
Reading data...Security area saved to "C:\Users\AL-Aqsa_Lenovo\Documents\SigmaKey\service files\0966618436\HRY-BD 1_0_0_60.skb"
Repairing... Vendor/Country: hw/eu
Repairing... Model: HRY-L21
Repairing...Done
--------- 2020-08-22 16:37:38 ---------
SigmaKey 2.38.05 HiSi: Write firmware
DBAdapter Reserved Interface (COM39), Provider: HUAWEI Technologies CO.,LTD, Driver ver.: 1.0.26.0, Date: 18/05/2016, USB\Vid_12D1&Subclass_13&Prot_23
Allow Full OTA files
Flash file E:\FIRMWARES\HUAWEI\HRY\HRY-L21\update_sd_base\PTABLE.APP
Writing flash SHA256RSA OK
Writing flash CRC OK
Writing flash BASE_VERLIST OK
Writing flash BASE_VER OK
Writing flash PACKAGE_TYPE OK
Writing flash HISIUFS_GPT OK
Flash file E:\FIRMWARES\HUAWEI\HRY\HRY-L21\update_sd_cust_HRY-L21_hw_eu\PTABLE.APP
Writing flash CUST_VERLIST OK
Writing flash CUST_VER OK
Writing flash PTABLE_CUST OK
Flash file E:\FIRMWARES\HUAWEI\HRY\HRY-L21\update_sd_preload_HRY-L21_hw_eu_R3\PTABLE.APP
Writing flash PRELOAD_VERLIST OK
Writing flash PRELOAD_VER OK
Writing flash PTABLE_PRELOAD OK
Flash file E:\FIRMWARES\HUAWEI\HRY\HRY-L21\update_sd_base\UPDATE.APP
Writing flash XLOADER OK
Writing flash FASTBOOT OK
Writing flash HHEE OK
Writing flash DTS OK
Writing flash TRUSTFIRMWARE OK
Writing flash FW_LPM3 OK
Writing flash DTO OK
Writing flash KERNEL OK
Writing flash TEEOS OK
Writing flash ISP_FIRMWARE OK
Writing flash VECTOR OK
Writing flash SENSORHUB OK
Writing flash FW_HIFI OK
Writing flash VBMETA OK
Writing flash MODEMNVM_UPDATE OK
Writing flash MODEMNVM_CUST OK
Writing flash RECOVERY_RAMDISK OK
Writing flash RECOVERY_VENDOR OK
Writing flash RECOVERY_VBMETA OK
Writing flash ERECOVERY_KERNEL OK
Writing flash ERECOVERY_RAMDISK OK
Writing flash ERECOVERY_VENDOR OK
Writing flash ERECOVERY_VBMETA OK
Writing flash ENG_VENDOR OK
Writing flash ENG_SYSTEM OK
Writing flash CACHE OK
Writing flash SYSTEM OK
Writing flash CUST OK
Writing flash MODEM_FW OK
Writing flash HISEE_IMG OK
Writing flash HISEE_FS OK
Writing flash VENDOR OK
Writing flash ODM OK
Writing flash PRODUCT OK
Writing flash PREAS OK
Writing flash PREAVS OK
Writing flash PATCH OK
Writing flash USERDATA OK
Flash file E:\FIRMWARES\HUAWEI\HRY\HRY-L21\update_sd_cust_HRY-L21_hw_eu\UPDATE.APP
Writing flash VERSION OK
Flash file E:\FIRMWARES\HUAWEI\HRY\HRY-L21\update_sd_preload_HRY-L21_hw_eu_R3\UPDATE.APP
Writing flash PRELOAD OK
Done
Old 08-24-2020, 08:36   #5490 (permalink)
Member: 2466919
Thanks Meter: 5
P30 Pro Update 9 to 10
SigmaKey v.2.38.05
Huawei Edition
--------- 2020-08-24 12:16:56 ---------
DBAdapter Reserved Interface (COM69), Provider: HUAWEI Technologies CO.,LTD, Driver ver.: 1.0.26.0, Date: 18/05/2016, USB\Vid_12D1&Subclass_13&Prot_23
Hardware IMEI: 020304050------
Flash file E:\FIRMWARES\HUAWEI\VOG\HUAWEI P30 PRO VOG-L29 HW EU VOGUE-L29C 10.0.0.168(C432E19R2P5) Firmware NA\dload\update_sd_base\PTABLE.APP
Flash file E:\FIRMWARES\HUAWEI\VOG\HUAWEI P30 PRO VOG-L29 HW EU VOGUE-L29C 10.0.0.168(C432E19R2P5) Firmware NA\dload\update_sd_cust_VOG-L29_hw_eu\PTABLE.APP
Flash file E:\FIRMWARES\HUAWEI\VOG\HUAWEI P30 PRO VOG-L29 HW EU VOGUE-L29C 10.0.0.168(C432E19R2P5) Firmware NA\dload\update_sd_preload_VOG-L29_hw_eu_R2\PTABLE.APP
Flash file E:\FIRMWARES\HUAWEI\VOG\HUAWEI P30 PRO VOG-L29 HW EU VOGUE-L29C 10.0.0.168(C432E19R2P5) Firmware NA\dload\update_sd_base\UPDATE.APP
Writing flash MODEM_DRIVER OK
Writing flash HDCP OK
Writing flash RAMDISK OK
Writing flash SUPER OK
Writing flash VBMETA_SYSTEM OK
Writing flash VBMETA_VENDOR OK
Writing flash VBMETA_ODM OK
Writing flash VBMETA_HW_PRODUCT OK
Writing flash VBMETA_CUST OK
Writing flash UFSFW OK
Flash file E:\FIRMWARES\HUAWEI\VOG\HUAWEI P30 PRO VOG-L29 HW EU VOGUE-L29C 10.0.0.168(C432E19R2P5) Firmware NA\dload\update_sd_cust_VOG-L29_hw_eu\UPDATE.APP
Flash file E:\FIRMWARES\HUAWEI\VOG\HUAWEI P30 PRO VOG-L29 HW EU VOGUE-L29C 10.0.0.168(C432E19R2P5) Firmware NA\dload\update_sd_preload_VOG-L29_hw_eu_R2\UPDATE.APP
Done
Unlocking 5190 Ryu Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 23 01-07-2018 17:14
how the **** do i make wintesla 6.03 work Ravetrancer Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 0 06-16-1999 08:41
Page generated in 0.32757 seconds with 10 queries
