Where is Huawei Y6 pro TIT Series in Sigma Addons for TIT Series found in bootloader.com but model not listed in Sigmakey https://i.postimg.cc/7Zc34N7C/Untitled.png |
I want to perform frp remove operation. Not network unlock. |
Follow this manual: FRP Remove for Huawei smartphones |
Remove FRP for Alcatel, Moto and Huawei devices: Download special files: Download special MTK addons from boot-loader.com (Sigma free section) and put them into My Documents\SigmaKey\addons\<your Sigma card number> folder. Alternative: Install SigmaKeyAddons_All_In_One.exe (it contains all additional files required for Sigma, packed in one installer). Settings: Select "MTK" platform from the tab menu in the upper left side of the software Go to "Service" tab Select "USB (autodetect)" in the serial ports selection tab Select your phone model in the "MTK boot" drop-down menu <<<Phone model not listed in sigmakey Press "Remove FRP" button |
Read this: Service - FRP Remove for Huawei smartphones
Warning: This feature will erase all phone’s data and accounts If after FRP removal user data was not wiped automatically, perform this procedure manually in the recovery mode. |
Volume keys not working and cannot enter fastboot so want to use SPFT Method I have HuaweiTIT-U.msf file in hand and need to use SPFT Method |
Set the phone to fastboot mode using the keys, and only then connect the phone to PC |
Read post #7...................................... |
If I can't perform this operation using SPFT Method, then what is the purpose of the HuaweiTIT-U.msf and HuaweiTIT-AL.msf at bootloader.com for? Or is it a planned feature for this phone model in next update? |
1 Attachment(s) Quote:
1. find this model da and use in sigma 2. for mtk you can use this button if u have this tool to go to fastboot mode click do connect usb cable as soon as fastboot apear in mobile remove cable close this tool open sigma and connect cable remove frp in fastboot mode http://forum.gsmhosting.com/vbb/atta...1&d=1568298626 you know which tool if not pm me. i hope one day sigma also add this button to go fastboot mode for mtk |
1 Attachment(s) |
SigmaKey 2.33.06 MTK: Remove FRP (Smartphone DA 2000…) DownloadAgent: TIT-U02_DA_SWSEC.bin Baseband Processor:MT6582, HW Rev. A.01, SW Rev. 0.01 Testing external RAM...DRAM, 1 Gb Detecting flash...eMMC, Flash size: 14.69 Gb Reading data....Not found --------- 2019-09-11 17:07:17 --------- SigmaKey 2.33.06 MTK: Remove FRP (Smartphone DA 2000…) DownloadAgent: TIT-U02_DA_SWSEC.bin Baseband Processor:MT6582, HW Rev. A.01, SW Rev. 0.01 Testing external RAM...DRAM, 1 Gb Detecting flash...eMMC, Flash size: 14.69 Gb Reading data....Not found Already have da and is done with other tool. Sigmakey cannot do with same da I wanted to try HuaweiTIT-U.msf file using SPFT Method and see result but Sigmakey not up to date with this feature. Work done since yesterday with other tool |
The main problem of sigma is old style gui Software get confused itself which loader to use in which model.. Why note make clean smart looking sigmakey gui |
Added Remove FRP support for some old MTK smartphones without gpt partition table. Repeat the operation using the latest Sigma version |
