11-08-2020, 19:58 | #1 (permalink) |
No Life Poster Join Date: Sep 2013 Location: KERALA, INDIA
Member: 2035802 Status: Offline Sonork: 100.1675827 Thanks Meter: 789 | worlds first Kirin 990 5G LIO-N29 (10.1.0.240(C185E2R2P1) Huawei ID remove done New version 2.39.04b1 is available on www.sigmakey.com. We strongly recommend to update SigmaKey! 939157242 Sigma dongle 2.39, Initializing...OK Pack 1: Activated Pack 2: Activated Pack 3: Activated Pack 4: Activated Pack 5: Activated --------- 2020-11-08 11:10:49 --------- SigmaKey 2.39.04 HiSi: Get device info Bootloader unlocked: NO FB unlocked: NO Battery voltage: 4.31 V Phone model: LIO-N29 Build number: LIO-N29 10.1.0.240(C185E2R2P1) Vendor/Country: hw/meafnaf System version: Skipped Android version: 10 Base version: LIO-LGRP4-OVS 10.1.0.240 Custom version: LIO-N29-CUST 10.0.0.2(C185) Preload version: LIO-N29-PRELOAD 10.0.0.1(C185R2) Huawei-Over-the-Air info: C_version: C185 D_version: D000 PLMN: 42403 BoardID: 9470 DeviceName: LIO-N29 Done --------- 2020-11-08 12:35:51 --------- SigmaKey 2.39.04 HiSi: Get device info Bootloader unlocked: NO FB unlocked: NO Battery voltage: 4.28 V Phone model: LIO-N29 Build number: LIO-N29 10.1.0.240(C185E2R2P1) Vendor/Country: hw/meafnaf System version: Skipped Android version: 10 Base version: LIO-LGRP4-OVS 10.1.0.240 Custom version: LIO-N29-CUST 10.0.0.2(C185) Preload version: LIO-N29-PRELOAD 10.0.0.1(C185R2) Huawei-Over-the-Air info: C_version: C185 D_version: D000 PLMN: 42403 BoardID: 9470 DeviceName: LIO-N29 Done --------- 2020-11-08 12:37:04 --------- SigmaKey 2.39.04 HiSi: Software testpoint On.../Off DBAdapter Reserved Interface (COM85), Provider: HUAWEI Technologies CO.,LTD, Driver ver.: 1.0.26.0, Date: 18-05-2016, USB\Vid_12D1&Subclass_13&Prot_23 Using extended heuristic method... Hardware IMEI: 020304050607080 Flash file C:\Users\anees\Downloads\Compressed\LIO-N29 10.1.0.236(C636E2R3P1)_Firmware_EMUI10.1.0_05016KX R File By (Support.**************)\Software\dload\update_sd_ base\UPDATE.APP Enabling diagnostic port...Done We strictly recommend performing "Enable Downgrade" on "Flash" tab, as the first service operation on this device! --------- 2020-11-08 12:37:51 --------- SigmaKey 2.39.04 HiSi: Remove FRP / Huawei ID HUAWEI USB COM 1.0 (COM34), Provider: Huawei Incorporated, Driver ver.: 2.0.6.725, Date: 28-11-2016, USB\VID_12D1&PID_3609&REV_0100 HiSilicon: Kirin 990 5G Phone model: LIO-N29 Version: LIO-N29 10.1.0.240(C185E2R2P1) Removing FRP lock...Done Removing Huawei ID....Done --------- 2020-11-08 12:39:45 --------- SigmaKey 2.39.04 HiSi: Software testpoint On.../Off Using extended heuristic method... This operation may brick the phone if the phone firmware version does not EXACTLY match the software testpoint firmware version! If you are unsure, better completely reflash the firmware. Are you sure you want to proceed? [YES] Repairing.........Done |
The Following 4 Users Say Thank You to technomak For This Useful Post: |
