05-31-2013, 07:30 | #2 (permalink) |
Insane Poster Join Date: Apr 2013 Location: tamilnadu,madurai
Member: 1916112 Status: Offline Sonork: [email protected] Thanks Meter: 8 | file here Volcano Updated: 2013-05-22 Connecting... Connection successful,connected state! Version: V3.8 SN:001-696-199 Port:COM3 After format or Flash you have to press & hold power button for at least 1.30 mins. Note for win7 users : Start your Win 7 64bit with F8 key and choose 'Disable Driver Signature Enforcement'. After that the spd drivers will have the ability to be loaded. Available Ports:COM3 Current Port:COM3 Detection initiated... Vcc: 6 8 10 Gnd: 3 5 7 9 12 Analyzing D+ and D-... Failed to detect. Pinouts are not fonud! Available Ports:COM3 Detection initiated... Vcc: 6 8 10 11 13 Gnd: 3 5 7 9 12 Analyzing D+ and D-... Failed to detect. Pinouts are not fonud! For many phones, charge pins need to be set in order to identify USB devices. Detecting D+ and D-... Vcc: 10 Gnd: 3 5 7 9 12 Detection initiated... Failed to detect. SPD U Disk Error Flash files password is = VolcanoAheadOfAllEVER Detection initiated... Vcc: 10 Gnd: 3 5 7 9 12 Analyzing D+ and D-... Failed to detect. Pinouts are not fonud! Detection initiated... Vcc: 10 11 Gnd: 1 12 Analyzing D+ and D-... D+ = 7, D- = 6 Analyzing USB device, please wait... Found [SPD] USB device: SCI USB2Serial,(VID_1782&PID_4D00) Setting... Set the Pinouts failed,please reconnect and try again! Detection initiated... Vcc: 10 11 Gnd: 1 12 Analyzing D+ and D-... D+ = 7, D- = 6 Analyzing USB device, please wait... Found [SPD] USB device: SCI USB2Serial,(VID_1782&PID_4D00) Setting... Set the Pinouts failed,please reconnect and try again! Reset USB device and search it... Time-out, try again, or re-plug your phone, or re-defined pinouts. For many phones, charge pins need to be set in order to identify USB devices. Detecting D+ and D-... Vcc: 10 11 Gnd: 1 12 Detection initiated... Found: D+ = 7, D- = 6 Detection D+/D- with 4.78 seconds! Analyzing USB device, please wait... Found [SPD] USB device: SCI USB2Serial,(VID_1782&PID_4D00) Detection completed. Detection initiated... Vcc: 10 11 Gnd: 1 12 Analyzing D+ and D-... D+ = 7, D- = 6 Analyzing USB device, please wait... Found [SPD] USB device: SCI USB2Serial,(VID_1782&PID_4D00) Setting... Set the Pinouts failed,please reconnect and try again! SPD U Disk Error Flash files password is = VolcanoAheadOfAllEVER Detection initiated... Vcc: 10 11 Gnd: 1 12 Analyzing D+ and D-... D+ = 7, D- = 6 Analyzing USB device, please wait... Found [SPD] USB device: SCI USB2Serial,(VID_1782&PID_4D00) Setting... Set the Pinouts failed,please reconnect and try again! Detection initiated... Vcc: 10 11 Gnd: 1 12 Analyzing D+ and D-... D+ = 7, D- = 6 Analyzing USB device, please wait... Found [SPD] USB device: SCI USB2Serial,(VID_1782&PID_4D00) Setting... Find USB device:SCI USB2Serial (COM4), (VID_1782&PID_4D00) Pinouts setting complete! Internal version: SPRD3 Boot downloaded. Start boot please wait a moment.... Spreadtrum Boot Block version 1.2 CPU TYPE:SC6530 [65300000] FLASH ID: 00EF004000180000 Flash Type: SF_W25Q128CV Size:0x1000000(16MB) Detection initiated... Vcc: 10 11 Gnd: 1 12 Analyzing D+ and D-... D+ = 7, D- = 6 Analyzing USB device, please wait... Find USB device:SCI USB2Serial (COM4), (VID_1782&PID_4D00) Internal version: SPRD3 Boot downloaded. Start boot please wait a moment.... Spreadtrum Boot Block version 1.2 CPU TYPE:SC6530 [65300000] FLASH ID: 00EF004000180000 Flash Type: SF_W25Q128CV Size:0x1000000(16MB) Reading completed. The data has been saved in D:\china\rokea\r820 spd 6530.bin, size: 16 M. Detection initiated... Vcc: 10 11 Gnd: 1 12 Analyzing D+ and D-... D+ = 7, D- = 6 Analyzing USB device, please wait... Find USB device:SCI USB2Serial (COM4), (VID_1782&PID_4D00) Internal version: SPRD3 Boot downloaded. Start boot please wait a moment.... Spreadtrum Boot Block version 1.2 CPU TYPE:SC6530 [65300000] FLASH ID: 00EF004000180000 Flash Type: SF_W25Q128CV Size:0x1000000(16MB) >>Set to Factory successfully. |
05-31-2013, 07:30 | #3 (permalink) |
Member: 1916112 Status: Offline Sonork: [email protected] Thanks Meter: 8 | Volcano Updated: 2013-05-22 Connecting... Connection successful,connected state! Version: V3.8 SN:001-696-199 Port:COM3 After format or Flash you have to press & hold power button for at least 1.30 mins. Note for win7 users : Start your Win 7 64bit with F8 key and choose 'Disable Driver Signature Enforcement'. After that the spd drivers will have the ability to be loaded. Available Ports:COM3 Current Port:COM3 Detection initiated... Vcc: 6 8 10 Gnd: 3 5 7 9 12 Analyzing D+ and D-... Failed to detect. Pinouts are not fonud! Available Ports:COM3 Detection initiated... Vcc: 6 8 10 11 13 Gnd: 3 5 7 9 12 Analyzing D+ and D-... Failed to detect. Pinouts are not fonud! For many phones, charge pins need to be set in order to identify USB devices. Detecting D+ and D-... Vcc: 10 Gnd: 3 5 7 9 12 Detection initiated... Failed to detect. SPD U Disk Error Flash files password is = VolcanoAheadOfAllEVER Detection initiated... Vcc: 10 Gnd: 3 5 7 9 12 Analyzing D+ and D-... Failed to detect. Pinouts are not fonud! Detection initiated... Vcc: 10 11 Gnd: 1 12 Analyzing D+ and D-... D+ = 7, D- = 6 Analyzing USB device, please wait... Found [SPD] USB device: SCI USB2Serial,(VID_1782&PID_4D00) Setting... Set the Pinouts failed,please reconnect and try again! Detection initiated... Vcc: 10 11 Gnd: 1 12 Analyzing D+ and D-... D+ = 7, D- = 6 Analyzing USB device, please wait... Found [SPD] USB device: SCI USB2Serial,(VID_1782&PID_4D00) Setting... Set the Pinouts failed,please reconnect and try again! Reset USB device and search it... Time-out, try again, or re-plug your phone, or re-defined pinouts. For many phones, charge pins need to be set in order to identify USB devices. Detecting D+ and D-... Vcc: 10 11 Gnd: 1 12 Detection initiated... Found: D+ = 7, D- = 6 Detection D+/D- with 4.78 seconds! Analyzing USB device, please wait... Found [SPD] USB device: SCI USB2Serial,(VID_1782&PID_4D00) Detection completed. Detection initiated... Vcc: 10 11 Gnd: 1 12 Analyzing D+ and D-... D+ = 7, D- = 6 Analyzing USB device, please wait... Found [SPD] USB device: SCI USB2Serial,(VID_1782&PID_4D00) Setting... Set the Pinouts failed,please reconnect and try again! SPD U Disk Error Flash files password is = VolcanoAheadOfAllEVER Detection initiated... Vcc: 10 11 Gnd: 1 12 Analyzing D+ and D-... D+ = 7, D- = 6 Analyzing USB device, please wait... Found [SPD] USB device: SCI USB2Serial,(VID_1782&PID_4D00) Setting... Set the Pinouts failed,please reconnect and try again! Detection initiated... Vcc: 10 11 Gnd: 1 12 Analyzing D+ and D-... D+ = 7, D- = 6 Analyzing USB device, please wait... Found [SPD] USB device: SCI USB2Serial,(VID_1782&PID_4D00) Setting... Find USB device:SCI USB2Serial (COM4), (VID_1782&PID_4D00) Pinouts setting complete! Internal version: SPRD3 Boot downloaded. Start boot please wait a moment.... Spreadtrum Boot Block version 1.2 CPU TYPE:SC6530 [65300000] FLASH ID: 00EF004000180000 Flash Type: SF_W25Q128CV Size:0x1000000(16MB) Detection initiated... Vcc: 10 11 Gnd: 1 12 Analyzing D+ and D-... D+ = 7, D- = 6 Analyzing USB device, please wait... Find USB device:SCI USB2Serial (COM4), (VID_1782&PID_4D00) Internal version: SPRD3 Boot downloaded. Start boot please wait a moment.... Spreadtrum Boot Block version 1.2 CPU TYPE:SC6530 [65300000] FLASH ID: 00EF004000180000 Flash Type: SF_W25Q128CV Size:0x1000000(16MB) Reading completed. The data has been saved in D:\china\rokea\r820 spd 6530.bin, size: 16 M. Detection initiated... Vcc: 10 11 Gnd: 1 12 Analyzing D+ and D-... D+ = 7, D- = 6 Analyzing USB device, please wait... Find USB device:SCI USB2Serial (COM4), (VID_1782&PID_4D00) Internal version: SPRD3 Boot downloaded. Start boot please wait a moment.... Spreadtrum Boot Block version 1.2 CPU TYPE:SC6530 [65300000] FLASH ID: 00EF004000180000 Flash Type: SF_W25Q128CV Size:0x1000000(16MB) >>Set to Factory successfully. |
05-31-2013, 07:49 | #4 (permalink) |
Member: 1916112 Status: Offline Sonork: [email protected] Thanks Meter: 8 | |
The Following User Says Thank You to deen.pandybazar For This Useful Post: |
