10-20-2012, 14:10 | #1 (permalink) |
Junior Member Join Date: Oct 2010
Member: 1411123 Status: Offline Sonork: 100.1620560 Thanks Meter: 1 | MTK USB IMEI change (Solved) http://imageshack.us/photo/my-images...anomtkusb.jpg/ Last edited by Ozyris; 10-20-2012 at 14:12. Reason: image added |
10-20-2012, 14:21 | #2 (permalink) |
No Life Poster Join Date: Aug 2012 Location: India Age: 39
Member: 1792140 Status: Offline Sonork: 100.1618782,gaba Thanks Meter: 6,087 | work with volcano box jig go to detect tab select cpu type (D+ D-) Mstar (Do Find Boot) connect phone click detect button and don't hold power button then click on set pinout tick after Setting switches to platform now go back to mtk tab untick auto pinouts detect select operation you want ( imei tools) and click run ( dont touch power button) try and post result. if any problem, contact me on sonork br umesh gaba |
The Following User Says Thank You to Umesh_Arora For This Useful Post: |
10-20-2012, 14:39 | #3 (permalink) |
Member: 1411123 Status: Offline Sonork: 100.1620560 Thanks Meter: 1 | The same: Code: Volcano Updated: 2012-10-13 Connecting... Connection successful,connected state! Version: V3.8 SN:088-406-642 Port:COM210 Available Ports:COM146 COM152 COM210 Analysis of USB port,Please insert phone USB cable. For many phones, charge pins need to be set in order to identify USB devices. Detecting D+ and D-... Vcc: null Gnd: 5 Detection initiated... D+ = 3, D- = 2 Detection D+/D- with 1,34 seconds. Continue to detect BOOT pin... New USB device: (VID_0E8D&PID_0003) BOOT(Pull Up) = 1 Detection completed. Setting pinouts... Find USB device:MTK USB Port (COM165), (VID_0E8D&PID_0003) Pinout setting complete. >>Analysis of USB port,Please insert phone USB cable. |
10-20-2012, 14:47 | #5 (permalink) |
Member: 1792140 Status: Offline Sonork: 100.1618782,gaba Thanks Meter: 6,087 | your mtk phone port is 165 and volcano box port 210, downgrade both port |
10-20-2012, 14:59 | #6 (permalink) |
Member: 1411123 Status: Offline Sonork: 100.1620560 Thanks Meter: 1 | [code] Volcano Updated: 2012-10-13 Connecting... Connection successful,connected state! Version: V3.8 SN:088-406-642 Port:COM210 For many phones, charge pins need to be set in order to identify USB devices. Detecting D+ and D-... Vcc: null Gnd: 5 Detection initiated... D+ = 3, D- = 2 Detection D+/D- with 1,34 seconds. Continue to detect BOOT pin... New USB device: (VID_0E8D&PID_0003) BOOT(Pull Up) = 1 Detection completed. Setting pinouts... Find USB device:MTK USB Port (COM165), (VID_0E8D&PID_0003) Pinout setting complete. Available Ports:COM210 Available Ports:COM210 Waiting for phone's response,press the Power on the phone. Fail to connect. >>Error 342830128 [code] |
10-20-2012, 15:32 | #8 (permalink) | |
No Life Poster Join Date: Jan 2006 Location: Pakistan
Member: 226457 Status: Offline Sonork: No more used Thanks Meter: 14,934 | Quote:
then tomorrow Contact me or umesh gaba BR Qaisar Mahmood | |
10-20-2012, 16:26 | #9 (permalink) |
Member: 1792140 Status: Offline Sonork: 100.1618782,gaba Thanks Meter: 6,087 | problem solve imei change done with usb at mode br umesh gaba Last edited by Umesh_Arora; 10-20-2012 at 16:41. |
The Following 2 Users Say Thank You to Umesh_Arora For This Useful Post: |
10-20-2012, 16:38 | #10 (permalink) |
Member: 1411123 Status: Offline Sonork: 100.1620560 Thanks Meter: 1 | Problem solved with write IMEI option and USB connection. http://imageshack.us/a/img201/6597/volcanoq.jpg |
