Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > Volcano Box
Old 05-20-2014, 07:09   #1 (permalink)
sahed07860's Avatar
Member: 648453
Thanks Meter: 82
gmail id password
i touch tab
problems-gmail id and password
pc device manager not show any driver
but
with press power+ vol up tab show android logo, but not go to recovery like wipe data etc
when tab show android logo this time pc device manager shown android phone/ android adb interface
i try this here is log
Available Ports:COM1 COM12 COM43 COM56
Current Port:COM56
Device has not got Root privileges, please get Root privileges.
Device found.
Connect the device successfully, the information of the device is as follows:
Model: - exec '/system/bin/sh' failed: No such file or directory (2) -
Android version: - exec '/system/bin/sh' failed: No such file or directory (2) -
Baseband: - exec '/system/bin/sh' failed: No such file or directory (2) -
The above information is for reference only.
>>Connecting device...
no respond long time
please help
Old 05-20-2014, 12:18   #2 (permalink)
Member: 1740134
Thanks Meter: 52
only solution : search for tab firmware and flash it. I guess it's allwinner tab.
or try different hardware keys to do hard reset/
Old 05-20-2014, 12:31   #3 (permalink)
Registered User
Member: 726546
Sonork: 100.1578784
Thanks Meter: 555
Originally Posted by sahed07860 View Post
i touch tab
but
Current Port:COM56
Device found.
please help
go in device manager check there if its debbuger is and then its taken android driver if its taken then 1st root urs tablet then u will be able to do reset gmail id
Old 05-20-2014, 14:35   #4 (permalink)
Member: 226457
Sonork: No more used
Thanks Meter: 14,934
power on your tab if usb debug is enable then do remove gmail
if not usb debug not enable then write firmware
Qaisar Mahmood
Old 05-21-2014, 06:08   #5 (permalink)
sahed07860's Avatar
Member: 648453
Thanks Meter: 82
Qaisar Mahmood
thanks sir for reply
i can"t read flash, if i get same firmware (flash file) by searching or collect.
how the flash procedure step by step
like select android tool bottom, battery or without battery.
i remove gmail id more then 100 tab (adb driver) using volcano box
but not flash any tab yet.
please sir help
Old 05-21-2014, 13:39   #6 (permalink)
Member: 557473
Sonork: 100.1627500
Thanks Meter: 2,284
only solution >>> search for tab firmware on internet and flash it.
bR.
Old 05-22-2014, 06:49   #7 (permalink)
sahed07860's Avatar
Member: 648453
Thanks Meter: 82
bR.
Qaisar Mahmood
please sir help
Old 05-23-2014, 07:37   #8 (permalink)
Member: 557473
Sonork: 100.1627500
Thanks Meter: 2,284
First u need to check which cpu inside.
if its Allwinner or Broadcom then u cant flash it with volcano tool.
bR.
Page generated in 0.16542 seconds with 8 queries
