07-10-2018, 13:02 | #1 (permalink) |
No Life Poster Join Date: Feb 2012
Member: 1718440 Status: Offline Thanks Meter: 620 | CAT S30 Removed FRP and Factory file backup 13:51:17 Current Task: COOLPAD>>Qualcomm>>Clear FRP>>Select Factory Boot 13:51:17 Operation: 1.Remove battery and insert battery back. 2.Press and hold 'VolumeUp' and 'VolumeDown' keys. 3.Please insert USB cable within 50 seconds. Some phones need to use edl cable or special card slot. 13:51:56 Port Found[COM10]. 13:51:56 Hardware Id:009600e1 13:51:56 Selected Boot File is:E:\China Qualcom Loaders\Qualcomm bootloaders\Qualcomm bootloaders\Qualcomm_Factory_Loader_MSM8909s_Cat_S 30.mbn 13:51:56 Waiting for flash programmer to boot. 13:52:00 Loading Build Info,Please Wait... 13:52:07 Name: CatS30 13:52:07 Brand: Cat 13:52:07 Device: CatS30 13:52:07 Release Version 5.1 13:52:07 BaseBand CPU: msm8909 13:52:07 Project Version: LTE_S0201121.0_S30_0.018.01 13:52:07 Ext Info: S30 13:52:07 Size: 8GB 13:52:07 Done. 13:52:07 Clearing FRP lock... 13:52:10 Clear FRP lock success 13:54:27 Ver:1.6.2 13:54:27 Current Task: COOLPAD>>Qualcomm>>Backup Factory Files>>Select Factory Boot 13:54:27 Operation: 1.Remove battery and insert battery back. 2.Press and hold 'VolumeUp' and 'VolumeDown' keys. 3.Please insert USB cable within 50 seconds. Some phones need to use edl cable or special card slot. 13:54:39 Port Found[COM10]. 13:54:39 Hardware Id:009600e1 13:54:39 Selected Boot File is:E:\China Qualcom Loaders\Qualcomm bootloaders\Qualcomm bootloaders\Qualcomm_Factory_Loader_MSM8909s_Cat_S 30.mbn 13:54:39 Waiting for flash programmer to boot. 13:54:44 Loading Build Info,Please Wait... 13:54:50 Name: CatS30 13:54:50 Brand: Cat 13:54:50 Device: CatS30 13:54:50 Release Version 5.1 13:54:50 BaseBand CPU: msm8909 13:54:50 Project Version: LTE_S0201121.0_S30_0.018.01 13:54:50 Ext Info: S30 13:54:50 Size: 8GB 13:54:50 Done. 13:54:51 Reading modem... 13:54:55 Reading sbl1... 13:54:56 Reading sbl1bak... 13:54:57 Reading rpm... 13:54:59 Reading rpmbak... 13:55:00 Reading tz... 13:55:02 Reading tzbak... 13:55:03 Reading pad... 13:55:04 Reading modemst1... 13:55:06 Reading modemst2... 13:55:07 Reading misc... 13:55:09 Reading fsc... 13:55:10 Reading ssd... 13:55:11 Reading splash... 13:55:13 Reading DDR... 13:55:14 Reading fsg... 13:55:16 Reading sec... 13:55:17 Reading persist... 13:55:20 Reading persistbak... 13:55:23 Reading rsv... 13:55:24 Reading devinfo... 13:55:25 Reading keystore... 13:55:27 Reading oem... 13:55:31 Reading config... 13:55:32 Reading aboot... 13:55:34 Reading abootbak... 13:55:35 Reading recovery... 13:55:38 Reading boot... 13:55:41 Reading cache... 13:55:42 Reading system... 13:57:12 Reading userdata... 13:57:15 Reading PrimaryGPT... 13:57:17 Reading BackupGPT... 13:57:19 Storage Path:E:\China Qualcom Files\msm8909_Cat_CatS30_5.1_LTE_S0201121.0_S30_0. 018.01 |
The Following 6 Users Say Thank You to Bell666 For This Useful Post: |
