10-02-2012, 05:37 | #1 (permalink) |
Freak Poster Join Date: Aug 2012 Location: Mardan, Pakistan
Member: 1803303 Status: Offline Thanks Meter: 24 | Charge pin Understanding? (Answered) I am not understanding charge pin option in volcano, i have watched the post qaiser mehmood post about charge pin but it could not help me to know why we use charge pin and what is its advantage, and how i choose the right cable from the detect tab and after getting result how to use the pin i found? |
10-02-2012, 06:40 | #2 (permalink) |
No Life Poster Join Date: Jan 2006 Location: Pakistan
Member: 226457 Status: Offline Sonork: No more used Thanks Meter: 14,934 | @Amigo*mobiles Some Phone Not Connect With out Find Charging Pin Same Like Mstar CPU G,Five E620 or MTK USB Method First Find Charging Pin & Select VCC Pin Manually (Charging Pin) then select cpu type (D+ D-) Mstar (Do Find Boot) click detect button and Press & hold power button then you See Phone Connected Successfully BR Qaisar Mahmood Last edited by Qaisar Mahmood; 10-02-2012 at 07:05. |
The Following 4 Users Say Thank You to Qaisar Mahmood For This Useful Post: |
10-02-2012, 08:40 | #3 (permalink) |
Member: 1803303 Status: Offline Thanks Meter: 24 | Quote: Thanks so much sir and 1 more question that there is an option pull down 1 so we have to pull down 1 to 13? |
10-03-2012, 11:20 | #5 (permalink) |
Member: 226457 Status: Offline Sonork: No more used Thanks Meter: 14,934 | @ Amigo*mobiles when you find VCC after detect pull down auto select no need to select manually br Qaisar Mahmood |
The Following User Says Thank You to Qaisar Mahmood For This Useful Post: |
06-04-2015, 07:05 | #7 (permalink) |
No Life Poster Join Date: May 2006 Location: aizawl
Member: 282510 Status: Offline Thanks Meter: 33 | Quote: i cnt see image, my net slow or image had been removed? |
