01-10-2013, 12:25 | #1 (permalink) |
No Life Poster Join Date: Nov 2006 Location: Bangladesh
Member: 387110 Status: Offline Sonork: Not Use Thanks Meter: 630 | Nokia L8 Coolsand cpu User Code Log here Code: Volcano Updated: 2013-01-08 Connecting... Connection successful,connected state! Version: V3.8 SN:xxxxxxxxxxxxx Port:COM21 After format or Flash you have to press & hold power button for at least 1.30 mins. Available Ports:COM1 COM21 Detection initiated, connect the phone and power on it... Failed to detect. Pinouts are not fonud! Analysis of USB port,Press 0 key and insert the data cable. Found CoolSand device,initializing the port. Reading completed. The data has been saved in E:\Firmware Chinese\CoolSand CPU\Nokia\L8.bin, size: 4 M. Analysis of USB port,Press 0 key and insert the data cable. Found CoolSand device,initializing the port. Flash Len: 0x400000(4M) Reading password completed. Not find password: Password: Dilip |
The Following User Says Thank You to Dilip_Nath For This Useful Post: |
01-12-2013, 14:42 | #5 (permalink) |
No Life Poster Join Date: Dec 2009
Member: 1194176 Status: Offline Thanks Meter: 203 | dear faisal bhai i have also face this problem today flash id show this name gd25QL064 i have try many way but not done then i have try with other tool in mode one imei change sucesfully also read code sucesfully but have no try with usb i have use with rx tx cabile and set the pin out manually |
01-13-2013, 06:15 | #7 (permalink) |
Member: 387110 Status: Offline Sonork: Not Use Thanks Meter: 630 | Another same phone Code: Volcano Updated: 2013-01-08 Connecting... Connection successful,connected state! Version: V3.8 SN:xxxxxxxxxxxx Port:COM21 After format or Flash you have to press & hold power button for at least 1.30 mins. Available Ports:COM1 COM21 Analysis of USB port,Press 0 key and insert the data cable. Analysis of USB port,Press 0 key and insert the data cable. Analysis of USB port,Press 0 key and insert the data cable. Found CoolSand device,initializing the port. Flash Len: 0x400000(4M) Reading password completed. Password: 1233 >> Any idea? wbr Dilip |
01-13-2013, 07:53 | #10 (permalink) |
No Life Poster Join Date: Jan 2006 Location: Pakistan
Member: 226457 Status: Offline Sonork: No more used Thanks Meter: 14,934 | @Dilip_Nath @ravipal_82 Make Back up first then Do Format after format hold power button at least 3mints. i hope your problem will be solved BR Qaisar Mahmood |
The Following User Says Thank You to Qaisar Mahmood For This Useful Post: |
