09-17-2013, 15:49 | #1 (permalink) |
No Life Poster Join Date: Aug 2008 Location: pakistan
Member: 828294 Status: Offline Sonork: 100.1615866 Thanks Meter: 124 | does qmobile a600 format supported? Connecting... CPU TYPE:6583/89 Hardware version:CA01 Software version:0001 Boot downloading complete! Analysis of USB port,Please insert phone USB cable. Connecting... CPU TYPE:6583/89 Hardware version:CA01 Software version:0001 Boot downloading complete! Available Ports:COM1 COM3 COM8 Analysis of USB port,Please insert phone USB cable. Connecting... CPU TYPE:6583/89 Hardware version:CA01 Software version:0001 Boot downloading complete! Analysis of USB port,Please insert phone USB cable. Connecting... CPU TYPE:6583/89 Hardware version:CA01 Software version:0001 >>Boot downloading complete! does this cpu support to format/read flash/write flash in volcano? i need to remove pattern lock, i try to read flash or read info,but volcano just read at above info and that's all. i try with baud rate low also, how to work with cpu?plz guide me |
09-17-2013, 18:35 | #3 (permalink) |
No Life Poster Join Date: Nov 2010 Location: Atif mobile,goal, faisalabad
Member: 1434736 Status: Offline Sonork: 100.1607275 Thanks Meter: 5,377 | not supported for format yet do hardreset if phone go on factory mode then use option clear emmc for factory reset but care full wifi is not on after hardreset , i try on A20 and A500 , and it upon your luck about wifi solution of wifi is read and write same phone nv data |
09-18-2013, 07:32 | #5 (permalink) |
Member: 828294 Status: Offline Sonork: 100.1615866 Thanks Meter: 124 | there is no option for clear emmc, after enter factory mode,these are available options here under, tpupgrade pcba test essential test full test item test test report signaling test gps reboot these options are available in factory mode, what to do to hard reset? |
09-18-2013, 08:07 | #6 (permalink) |
Member: 828294 Status: Offline Sonork: 100.1615866 Thanks Meter: 124 | i find the hard reset menu but can't do that, no need to go in factory mode it is in recovery mode, press vol- and vol+ and power until you see two options recovery mode factory mode vol+ to recovery mode(you see andriod logo with red tri-angel) then press vol- or vol+(one of them with power) you can see the hard reset menu now, here i face the problem now when i select wipe data/factory reset then press power button, it goes back to android logo and that's all, nothing to format,just still at there, if anyone did it then plz share with me, i post all details here to hard reset this model,but not complete yet. |
09-19-2013, 08:28 | #8 (permalink) | |
Member: 828294 Status: Offline Sonork: 100.1615866 Thanks Meter: 124 | Quote:
may be someone solve in future,i try with different combination of all keys and nothing to work atm, but one thing is sure that if the wipe option is given then it must be wipe/factory reset, so waiting now,,,,,,,,,,,no other way. | |
09-22-2013, 09:44 | #10 (permalink) | |
No Life Poster Join Date: Dec 2005 Location: IN_BATTLE_FIELD.
Member: 214340 Status: Offline Thanks Meter: 906 | Quote:
TESTED_SOLUTION_OF_HARD_RESET_BY_ME In 2 different Sets. 1. VOL UP & PWR after qmobile logo release pwr button. 2. Then Android sign with sign of ! dont worry. 3. Press PWR button to go on factory mode. 4. Select Wipe data/factory reset with volum button. 5. Press Vol up for selecting wipe data. 6. Select Yes with volum button. 7. Again Vol up for selecting factory reset. All done Tested by me in 2 sets. BR | |
10-21-2013, 13:31 | #12 (permalink) | |
Freak Poster Join Date: Nov 2006 Location: Lahore pakistan
Member: 387116 Status: Offline Sonork: 100.1650000 Thanks Meter: 176 | Quote:
How to factory reset Qmobile NOIR if you have forgotten the lock | |
