10-29-2014, 16:21 | #1 (permalink) |
No Life Poster Join Date: Aug 2012 Location: Chile
Member: 1797183 Status: Offline Thanks Meter: 149 | SPD CA6530A died after phone reset...(Solved) Read Info: Internal version: SPRD3 Boot downloaded. Start boot please wait a moment.... Spreadtrum Boot Block version 1.2 CPU TYPE:SC6530 [65300000] FLASH ID: 00C8006000170000 Flash Type:[GD] 25LG64bWL Size:0x800000(8MB) --------------------------------------. Phone imei lists. IMEI1:354531053580607 IMEI2:354531053580615 IMEI3:358570010103893 Read Info finish... Read Flash: Detection initiated... Vcc: 10 Gnd: 1 Analyzing D+ and D-... D+ = 9, D- = 8 Detection D+/D- with 1.34 seconds. Continue to detect BOOT pin... Found [SPD] USB device: SCI USB2Serial,(VID_1782&PID_4D00) BOOT(Pull Down) = 6 Setting... Find USB device:SCI USB2Serial (COM68), (VID_1782&PID_4D00) Pinouts setting complete! Internal version: SPRD3 Boot downloaded. Start boot please wait a moment.... Spreadtrum Boot Block version 1.2 CPU TYPE:SC6530 [65300000] FLASH ID: 00C8006000170000 Flash Type:[GD] 25LG64bWL Size:0x800000(8MB) Reading completed. The data has been saved in C:\A-Software\Software\volcano\variado\YEZZ CHICO2C_FullFlash.bin, size: 8 M. Read flash finish.... Phone Reset: Detection initiated... Vcc: 10 Gnd: 1 Analyzing D+ and D-... D+ = 9, D- = 8 Detection D+/D- with 1.34 seconds. Continue to detect BOOT pin... Found [SPD] USB device: SCI USB2Serial,(VID_1782&PID_4D00) BOOT(Pull Down) = 6 Setting... Find USB device:SCI USB2Serial (COM68), (VID_1782&PID_4D00) Pinouts setting complete! Internal version: SPRD3 Boot downloaded. Start boot please wait a moment.... Spreadtrum Boot Block version 1.2 CPU TYPE:SC6530 [65300000] FLASH ID: 00C8006000170000 Flash Type:[GD] 25LG64bWL Size:0x800000(8MB) Set to Factory successfully. and here the phone will not start .... now... Detection initiated... Vcc: 10 Gnd: 1 4 Analyzing D+ and D-... D+ = 9, D- = 8 Analyzing USB device, please wait... Find USB device:SCI USB2Serial (COM68), (VID_1782&PID_4D00) Internal version: SPRD3 Boot downloaded. Start boot please wait a moment.... Spreadtrum Boot Block version 1.2 CPU TYPE:SC6530 [65300000] FLASH ID: 00C8006000170000 Flash Type:[GD] 25LG64bWL Size:0x800000(8MB) Writing completed. Flash file C:\A-Software\Software\volcano\variado\YEZZ CHICO2C_FullFlash.bin has been written. turn on well but even with password.... Last edited by AniAxn; 10-29-2014 at 17:11. |
10-29-2014, 17:02 | #2 (permalink) |
Member: 1797183 Status: Offline Thanks Meter: 149 | Solved solved when I give in .... read flash and keep changing the name, for example putting the phone model ... and then give in unlock code and it throws me: Internal version: SPRD3 Boot downloaded. Start boot please wait a moment.... Spreadtrum Boot Block version 1.2 CPU TYPE:SC6530 [65300000] FLASH ID: 00C8006000170000 Flash Type:[GD] 25LG64bWL Size:0x800000(8MB) Writing completed. Flash file C:\A-Software\Software\volcano\variado\YEZZ CHICO2C_FullFlash.bin has been written. Screen Lock input order: ¢ظ ¢ع ¢غ ¢ـ ¢ف ¢ق ¢ك ¢à ¢ل but instead of saving the file without changing the name .. and doing the same process I pulled this. Looking for passwords,please wait... [Phone Lock] 2604 Good [Phone Lock] 1234 >>Looking for passwords complete. |
