Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > Volcano Box
Old 11-03-2014, 14:42   #1 (permalink)
Member: 1607116
Sonork: 100.1617729
Thanks Meter: 52
Help Volcano Box Not Found Please Connect Box and Run Software Again [ Solved ]
I have more than three months and no one gives a solution, nor corrected this error!!!
The Following User Says Thank You to dj-eg For This Useful Post:
Old 11-04-2014, 05:24   #2 (permalink)
Member: 1769022
Thanks Meter: 4
brother remove volcano tools and reinstal and update driver
Old 11-04-2014, 10:31   #3 (permalink)
Member: 557473
Sonork: 100.1627500
Thanks Meter: 2,284
Remove/Uninstall all previous drivers
Download this...and install..
Download Smk Oldest Driver rar
connect box...and post result.
bR.
Old 11-07-2014, 06:58   #4 (permalink)
unlock in nepal's Avatar
Member: 1686564
Sonork: PM me
Thanks Meter: 157
bR.
I also face same problam i format by pc & your your driver same problam
& also tray with w7 formated pc but same how can solv it
Old 11-07-2014, 07:02   #5 (permalink)
Member: 557473
Sonork: 100.1627500
Thanks Meter: 2,284
Arrow
contact me on sonork . .
bR.
Old 11-07-2014, 16:15   #6 (permalink)
Member: 1607116
Sonork: 100.1617729
Thanks Meter: 52
bR.
without result
Old 01-05-2015, 10:24   #7 (permalink)
Akhtar Ali Jatt's Avatar
Member: 953334
Sonork: 100.1614005
Thanks Meter: 15,424
Change Port Number from Device manager to port # 3 or plus or install Volcano box to another usb port .
The Following 4 Users Say Thank You to Akhtar Ali Jatt For This Useful Post:
Old 02-16-2015, 17:48   #8 (permalink)
EjazATF's Avatar
Member: 2192499
Sonork: Stopped using..
Thanks Meter: 1,763
Thanks dear, I was also facing this problem after buying new VOLCANO in RED Color...
After changing the port # into 3 my box is in working condition now.
It look like fire Thanks Buddy
Old 10-07-2015, 09:10   #9 (permalink)
him82's Avatar
Member: 646646
Sonork: 100.1664464
Thanks Meter: 240
how solove same problem to me i m using w7 oprating 64 bit oparting
''volcano vox not found error ''
Old 10-07-2015, 12:28   #10 (permalink)
hitech care's Avatar
Member: 1834832
Thanks Meter: 1,450
Check Power Switch Volcano Box... Red Power Button....
Old 10-07-2015, 14:44   #11 (permalink)
gunit1's Avatar
Member: 2041210
Thanks Meter: 541
i have re instal driver after Change Port Number from Device manager to port # 3 working 100/100
Old 12-09-2015, 16:03   #12 (permalink)
Member: 483440
Thanks Meter: 191
Salem
i have the same problem , i can't solve this problem !!!
is there any solution?
Old 12-09-2015, 16:08   #13 (permalink)
ij_cell's Avatar
Member: 1937038
Sonork: QQ 2045657399
Thanks Meter: 4,492
Originally Posted by hicvb7 View Post
Salem
What same problem?.
post screenshot or error.
Every Volcano Box / Merapi User Read This Carefully To Receive Support From Team
Old 12-10-2015, 06:52   #14 (permalink)
Member: 483440
Thanks Meter: 191
Here is the same problem !
The Following User Says Thank You to hicvb7 For This Useful Post:
Old 12-10-2015, 07:00   #15 (permalink)
ij_cell's Avatar
Member: 1937038
Thanks Meter: 4,492
2 Things can create this issu.
1>Volcano box red button is pressed.
2>Your box COM PORT over 100.
Solution.
check volcano button if its press than switch of.
If com port is over 100 than reduce com port under 20.
The Following 2 Users Say Thank You to ij_cell For This Useful Post:
Page generated in 0.22943 seconds with 9 queries
