08-27-2013, 05:32 | #1 (permalink) |
Freak Poster Join Date: Jan 2007
Member: 422887 Status: Offline Thanks Meter: 19 | invalid.the operation cannot be running because massage says these invalid.the operation cannot be running but volcano tool v2.0.9 is ok it is can run what is problome please help me |
The Following User Says Thank You to mobileconcern For This Useful Post: |
08-27-2013, 07:45 | #4 (permalink) |
No Life Poster Join Date: Jul 2011 Location: Pakistan Lahore
Member: 1608878 Status: Offline Sonork: 100.1608233 Thanks Meter: 378 | Volcano Losser team not solv problum me also same problum here 1 month but not reply volcan team all |
The Following User Says Thank You to mubasharsoft For This Useful Post: |
09-03-2013, 19:27 | #6 (permalink) |
No Life Poster Join Date: Nov 2010 Location: Atif mobile,goal, faisalabad
Member: 1434736 Status: Offline Sonork: 100.1607275 Thanks Meter: 5,377 | Already post suction many time , just use magic search button |
The Following User Says Thank You to sweet4hamza For This Useful Post: |
09-07-2013, 13:59 | #8 (permalink) | |
No Life Poster Join Date: Aug 2009 Location: India, W.B, Kolkata
Member: 1093574 Status: Offline Sonork: 100.1646163 Thanks Meter: 474 | Quote:
Update Driver OR" Try with next update version. | |
10-01-2013, 18:42 | #9 (permalink) | |
Insane Poster Join Date: Sep 2007 Location: Nairobi , Notikuo kwao
Member: 595815 Status: Offline Thanks Meter: 12 | Quote:
change installation c\volcanobox to C:\Program Files\VolcanoBox | |
The Following User Says Thank You to MBATIA For This Useful Post: |
11-18-2013, 20:07 | #12 (permalink) |
Member: 1434736 Status: Offline Sonork: 100.1607275 Thanks Meter: 5,377 | Detailed info about Invalid License DATA !! Let me Tell you, Now VolcanoBox is using Server as you all knows that and we have some data store into your pc via server which is in your Registry, If somehow your Antivirus / Fireware / Malware Detector / or any thing is protecting your windows will not allow Volcanobox software verify registry keys and results is Invalid license data. there could be some solution of this problem, Solution # 1 Download this file Extract it Run it after Run Volcanobox will be fine Solution # 2 Download this file Uninstall Completely Your antivirus/malware detector or any kind of shield Extract that file run it restart pc redownload 2.2.3 from internet run it Solution # 3 Download VolcanoBox 2.1.9 Download this file Run volcanoBox 2.1.9 go to System Click on System Self-Test Click on System Recovery Extract that file Run that file Restart system Redownload 2.2.3 Extract it Run it Solution # 4 Click on start Click on Turn Off Computer Click on Turn Off Insert Windows Cd/DVD Format windows ( C Drive or where you install windows ) Install Windows Install Drivers Do not Install any kind of Shield Download 2.2.3 Run Invalid License DATA in log windows !! Run VolcanoBox 2.2.3 go to System Click on System Self Test Click on System Recover Restart System Should be ok |
03-03-2014, 06:01 | #13 (permalink) |
Major Poster Join Date: Jan 2010 Location: kanpur up
Member: 1209927 Status: Offline Sonork: [email protected] Thanks Meter: 5 | i have a problem but not any solution volcano team what volcano team are sleeping |
The Following User Says Thank You to dikkugupta For This Useful Post: |
03-05-2014, 20:57 | #15 (permalink) |
Member: 595815 Status: Offline Thanks Meter: 12 | 100% invalid.the operation cannot be running SOLUTION. download the latest full INSTALLER and UPDATE from. http://gpgindustries.com/download/ VolcanoBox/index.php?dir= UNINSTALL AND DELETE ANY VOLCANO. Install the full installer and update it. then burn the volcano exe (17.1mb) in a CD. for later use when ever it shows 'invalid.the operation cannot be running' just delete the VOLCANO EXE THEN COPY PASTE FROM THE CD |
