07-25-2017, 11:53 | #1 (permalink) |
No Life Poster Join Date: Jun 2014 Location: GSM FORUM ♥
Member: 2207555 Status: Offline Thanks Meter: 1,622 | LYF_Water_8_LS5015|QLM MSM8936|Write Sparse Firmware Done By Inferno Unitool[SUCCESS] Write Sparse Firmware In EDL Mode Code: >>Current Task: LYF>>Qualcomm>>Write Flash>>Select Factory Boot >>Getting Info From Factory File,Please Wait... >>Get Factory Info Fail >>Operation: 1.Remove battery and insert battery back. 2.Press and hold 'VolumeUp' and 'VolumeDown' keys. 3.Please insert USB cable within 50 seconds. Some phones need to use edl cable or special card slot. >>Port Found[COM5]. >>Status: 6 The handle is invalid. >>Not find matched CPU,Please Select CPU manually >>Current Task: LYF>>Qualcomm>>Write Flash>>Select Factory Boot >>Operation: 1.Remove battery and insert battery back. 2.Press and hold 'VolumeUp' and 'VolumeDown' keys. 3.Please insert USB cable within 50 seconds. Some phones need to use edl cable or special card slot. >>Phone Connect TimeOut. >>Current Task: LYF>>Qualcomm>>Write Flash>>Select Factory Boot >>Operation: 1.Remove battery and insert battery back. 2.Press and hold 'VolumeUp' and 'VolumeDown' keys. 3.Please insert USB cable within 50 seconds. Some phones need to use edl cable or special card slot. >>Port Found[COM5]. >>Hardware Id:0090b0e1 >>Selected Boot File is:C:\Users\Rehan\Downloads\Compressed\LYF_Water_8_LS5015_5.1.1_(Repairmymobile.in)\LYF_Water_8_LS5015_5.1.1\Firmware\prog_emmc_firehose_8936.mbn >>Waiting for flash programmer to boot. >>Size: 16Gb >>Backup modemst1... >>Backup modemst2... >>Storage Path:D:\Volcano Inferno Tool\InfernoTool_UniTool_EXT_Volcano_V1.3.0_20170721\UniTool_Vol_EXT\SecurityBackup\Data0725160144 Write modem Success. Write sbl1 Success. Write sbl1bak Success. Write rpm Success. Write rpmbak Success. Write tz Success. Write tzbak Success. Write hyp Success. Write hypbak Success. Write splash Success. Write sec Success. Write aboot Success. Write abootbak Success. Write boot Success. Write recovery Success. Write system Success. Write system Success. Write system Success. Write system Success. Write system Success. Write system Success. Write system Success. Write system Success. Write system Success. Write system Success. Write system Success. Write system Success. Write system Success. Write system Success. Write system Success. Write system Success. Write system Success. Write system Success. Write system Success. Write system Success. Write system Success. Write system Success. Write system Success. Write system Success. Write system Success. Write system Success. Write system Success. Write system Success. Write system Success. Write system Success. Write system Success. Write system Success. Write system Success. Write system Success. Write system Success. Write system Success. Write system Success. Write system Success. Write system Success. Write system Success. Write system Success. Write system Success. Write system Success. Write system Success. Write system Success. Write system Success. Write system Success. Write system Success. Write system Success. Write cache Success. Write cache Success. Write cache Success. Write persist Success. Write config Success. Write userdata Success. Write userdata Success. Write userdata Success. Write userdata Success. Write userdata Success. Write userdata Success. Write userdata Success. Write userdata Success. Write userdata Success. Write userdata Success. Write userdata Success. Write userdata Success. Write userdata Success. Write userdata Success. Write userdata Success. Write userdata Success. Write userdata Success. Write userdata Success. Write userdata Success. Write userdata Success. >>Write FirmWare Finished Rehan GPG_Team |
The Following 2 Users Say Thank You to rehansk8879 For This Useful Post: |
